Old 07-15-2013, 05:32 AM   #9721
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,815
Originally Posted by JustBob View Post
Who said I wanted your bike?
You have to buy my bike, to get my tires.
Old 07-15-2013, 07:32 AM   #9722
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 843
anti vibe inserts
Has anyone used HDB's anti vibe threaded insert? If so, did they help much?
sdd04 is online now   Reply With Quote
Old 07-15-2013, 08:17 AM   #9723
burmbuster
burmbuster's Avatar
Oddometer: 1,432
Ordered the comm cable from CJ Designs. Will perform the de-cat this week and I need to tweek a few things in the EFI maps. Now everyone seems to be out of the service manuals. Can one of you FF's share the correct values for the THAD and PPAD so I can check them for the proper voltage readings? I think the manual is a few weeks out. 2013 model.
_______________
2013 KTM 690 Enduro R
burmbuster is offline   Reply With Quote
Old 07-15-2013, 09:32 AM   #9724
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,962
Originally Posted by motoged View Post
which "kit" do I need??
The super mosfet kit FH020AA.
Only thing you need to decide is whether you prefer the maxi fuse (big blade fuse) or circuit breaker option. 3 ft of wire is plenty.
Bruno T . is offline   Reply With Quote
Old 07-15-2013, 09:56 AM   #9725
Uller
Uller's Avatar
Oddometer: 1,689
Do I just need the RR....or one of the kits with the wires and connectors....I haven't removed the Safari tank yet and haven't eyeballed the situation yet....which "kit" do I need??
If I got one of his "kits" I would get the The Super Mosfet Kit FH020AA with the maxifuse holder. That way the only soldering (or crimping) you need to do is the three wires from the stator.
It won't be as clean of an install due to the premade wire harness being longer than needed but, it limits the amount of soldering you need to do and would greatly speed up the installation time.
Uller is offline   Reply With Quote
Old 07-15-2013, 10:15 AM   #9726
BIG-E
AKA; Mongo-E
BIG-E's Avatar
Oddometer: 2,106
Hello Everyone,
What is the hot ticket in lighting? The HID or the LED? I used to think the HID was the way to go, but not so sure anymore.
What say you?
KTM Twins has a complete HID set-up with a Duke wind screen,
Thanks for any help, Eric.
"If my Technique Improves, so will my riding"!
BIG-E is offline   Reply With Quote
Old 07-15-2013, 10:29 AM   #9727
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 819
Well dang. Always a catch and here I am trying to be helpful.
Bob Hancock
'14 R1200GSW; '14 F800GSA
'10 690 EnduroR; '88 R100RS
JustBob is offline   Reply With Quote
Old 07-15-2013, 11:15 AM   #9728
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 1,044
Originally Posted by BIG-E View Post
Hello Everyone,
What say you?
The trailtech HID's have had their share of reliability issues (mostly short lived ballast's.) The kit in your picture isn't DOT approved anyway, so an 8" HID race light would be a better option... you could even convert it to 7" DOT hi/low and then convert to HID to make an "almost legal" race light. That is the route that I went, but honestly after seeing some higher end LED's, they throw nearly the same distance while having better flood, no warm up time, more compact, similar power draw, stock(ish) appearance, and a dimmer can be mounted to give a "low" setting (aim will still be the same, just less intense output... again, "almost legal")
If I had it to do over again, I would go with this: http://www.bajadesigns.com/ProductDe...mNumber=497061 with a dimmer
I can ride my bike with no handlebars, no handlebars, no handlebars - Jamie Laurie
The Letter J is offline   Reply With Quote
Old 07-15-2013, 12:00 PM   #9729
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,239
Hello Everyone,
What say you?
I'm a big fan of the BD Squadron, put one on my Husaberg 390 and it has been very reliable and rugged.
http://www.advrider.com/forums/showthread.php?t=784908
Takes a bit of wiring trickery but not bad. The Skene Designs is the best dimmer to integrate with the existing switchgear. The Squadron is too bright for use on highways and oncoming car, but knocking it down to 20% to 30% or so makes it tolerable for the cars and easily the equivalent of "Low beam" Halogen to play nice with cars.
If you do go with the Skene Designs, it's best to get at least the IQ-150-A and add a high beam "flasher" button to program it and also allow you to use the Alert! feature, which is awesome for vehicles getting ready to pull out in front of you.
cyborg is offline   Reply With Quote
Old 07-15-2013, 12:33 PM   #9730
poondangle
Slow
poondangle's Avatar
Oddometer: 1,584
Looks great, I just called and they are saying the units are about 2-3 weeks out right now. There's a circuit board on back order. He did say that the KTM dimmer box kit 66-0088 makes the whole shootin' match a plug and play affair with the bike's high beam/low beam switch.
poondangle is online now   Reply With Quote
Old 07-15-2013, 01:00 PM   #9731
The Letter J
Oddometer: 1,044
That BD dimmer would be the perfect option for someone like me who absolutely SUCKS at electrical/ wiring! Plug and play goes a long way with me!
Old 07-15-2013, 01:04 PM   #9732
poondangle
Slow
poondangle's Avatar
Oddometer: 1,584
Here I was thinking I was the only electrical moran here.
Old 07-15-2013, 01:30 PM   #9733
Hoots
Hoots's Avatar
Oddometer: 1,574
The lights would be great, but the polisport shell looks a bit odd IMO ...
Hoots is offline   Reply With Quote
Old 07-15-2013, 02:06 PM   #9734
Okieboy2
Oddometer: 35
[QUOTE=Bruno T .;21870438]The super mosfet kit FH020AA.
Only thing you need to decide is whether you prefer the maxi fuse (big blade fuse) or circuit breaker option. 3 ft of wire is plenty. ]
And how to mount it. I ended up having to move mine to the opposite side of the bike.
12 500 XC-W
10 690 Enduro R
07 525 EXC
Okieboy2 is offline   Reply With Quote
Old 07-15-2013, 02:07 PM   #9735
The Letter J
Oddometer: 1,044
That's why I gave a link to the one with the OEM KTM headlight mask
Times are GMT -7.   It's 03:28 PM.
