Old 08-25-2013, 09:26 PM   #10636
150ron
150ron's Avatar
Oddometer: 1,302
Originally Posted by dirty_sanchez View Post
My '12 with stock gearing and a 606 on the front and a Heidi K60 on the rear at 75 mph (GPS) turns right at 5.5k if I remember correctly. The engine is turning this fast the second I hit 75
A buddy with an earlier year model says he's hit 116 on the speedo. I don't believe it though.
Dirty
Wow, 75mph at 5.5 rpm is great, my current bike is at 7k rpm at 75mph, thanks for the info, much appreciated.
Just some dude...
150ron is offline   Reply With Quote
Old 08-25-2013, 09:33 PM   #10637
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,713
Trying to tweak my sad suspension tonight. The shock rebound adjuster only has 13 clicks and then it stops/seizes. Any tricks to freeing it or do I need to send it off to a shop?
v8toilet is offline   Reply With Quote
Old 08-25-2013, 10:39 PM   #10638
folknride
Old Adventurer
folknride's Avatar
Oddometer: 667
Shift Lever Leak
I have a bit of oil oozing from around the shift lever shaft - presume it is the Shift Seal Ring (0760142461) that is the culprit. Does anyone know if this is an easy replacement - just pop out the old seal and push in a new one - could it be that easy????
folknride is offline   Reply With Quote
Old 08-26-2013, 01:37 AM   #10639
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,105
There is a good chance it has already broken not the best design ,
The seizure is is one side mashing against the other
Birth of a Rally Bike - KTM525
Mudguts is offline   Reply With Quote
Old 08-26-2013, 09:23 AM   #10640
v8toilet
v8toilet's Avatar
Oddometer: 1,713
Yeah you're probably right, the hourglass shaped screw has separated internally. I'd be interested in the Tractive stuff but $1700 USD is a bit rich for this kid.
Old 08-26-2013, 09:28 AM   #10641
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,454
I need to check but I think I ran 15/42 gearing on my 690 when I raced in australia and the bike topped out at 102 mph. i was running a Michelin rally tire and rally Mousse on the back which is a heavy setup and may have cost a little top speed. I was running Beanie's efi map on the stock computer and it might not have been fully tuned for 9000 rpm running. I have the head off the bike right now and there are no signs of damage or detonation etc so I don't think there were any lean running issues.
Seth S
Seth S is offline   Reply With Quote
Old 08-26-2013, 09:36 AM   #10642
v8toilet
v8toilet's Avatar
Oddometer: 1,713
Mr. Seth how many miles on your bike now?
Old 08-26-2013, 09:45 AM   #10643
burmbuster
burmbuster's Avatar
Oddometer: 1,429
Originally Posted by Bigbugberg View Post
I presume you meant you're wrong.
Sent from my SCH-I605 using Tapatalk 4
Yes. The iPad presumes to be smarter than I am from time to time.
_______________
2013 KTM 690 Enduro R
burmbuster is offline   Reply With Quote
Old 08-26-2013, 10:04 AM   #10644
zxrider11
Oddometer: 185
2012 with stock gearing at 60mph = 4,500 rpms.
When I switched to a 42 rear sprocket, 60mph = 4,000 rpms.
zxrider11 is offline   Reply With Quote
Old 08-26-2013, 12:25 PM   #10645
DirtJack
DirtJack's Avatar
Oddometer: 1,459
Originally Posted by DirtJack View Post
Calculated speed at various rpm. The 2127mm circumference may not be accurate for your rear tire. Changing the vary last entry on the browser URL, 15r45, to reflect your final drive ratios, for example 14r48 [the gearing I used in Colorado last week], will show the new speeds for each rpm. Apologies for being a geek.
Hope people didn't miss the two links in this post.
Here is a link showing the speeds for rpm using 15/42 gearing.
Just changed the last entry in the browser URL to 15r42 to get the new speeds. zxrider11 is correct, 15/42 gearing gives 59 mph at 4000 rpm.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 08-26-2013, 01:58 PM   #10646
Seth S
Seth S's Avatar
Oddometer: 4,454
about 10,000 miles
Seth S
Old 08-26-2013, 02:01 PM   #10647
Seth S
Seth S's Avatar
Oddometer: 4,454
I'll take a look tonight...I definitely wasn't running 126 mph. I am likely wrong on the ratios.
Checked last night and I have a 44 sprocket on the rear. Pretty sure I have a 15 tooth on the front. The bike topped out at 102 mph on the ICO and I am not 100% sure of the rpm but it was near the top of the range.
Seth S
Seth S screwed with this post 08-27-2013 at 08:11 AM
Old 08-26-2013, 02:30 PM   #10648
Hoots
Hoots's Avatar
Oddometer: 1,376
I use 16:44 and run about 4,000rpm at 100kph (60mph) ...
Can cruise comfortably at about 110-115kph, with the motor just chugging along ...
Good dual sport gearing for this bike IMO ...
Makes 1st-3rd more useable for fire trails ...
Hoots is offline   Reply With Quote
Old 08-26-2013, 02:32 PM   #10649
StuInFH
Oddometer: 411
KTM690 owners, on a STOCK KTM690R, with stock gearing, while you are doing 75mph on the fwy for LONG stretches at a time, what is the RPM at?
And, how about a real world top speed please, i know the bike is great off road, trying to see about its fwy and top speed characters, assuming the rider weighs 160 pounds, thanks.
Best gearing site I've seen. Unfortunately I don't see the post-09 690s on here, but bit of searching (or comparing your rpms/speed to what is shown for '09's results) and you could likely learn if they are different. Lots of info on this site, different combos, chain lengths, chain/sprocket wear, etc. Load the rpm chart to see what rpm is at different speeds in different gears.
http://www.gearingcommander.com/
StuInFH is offline   Reply With Quote
Old 08-26-2013, 06:11 PM   #10650
saintfish
Oddometer: 12
If you take the sprocket off and lay them both down flat, you'll quickly find that the sprocket you have (which is actually from the exc) is a couple of mm narrower (the spacer part, not the actual teeth). It doesn't matter how tight the bolt is done up, it's designed to only go so far and then get locked in place by folding the lock washer up. Find a sprocket that actly fits or a washer that will fit and act as the spacer. Or take it ur dealer and them uve got a broken bike
Originally Posted by OneEffinName View Post
I find the gearing a little too tall for my gnarly backroads stuff so my easy option is a 14T front sprocket. I have a few of them in the box from my 350 excf and my old 450 excr.
I googled around and there is no rubber damped 14T, so guys are using the 14T from the exc bikes. Cool - I got those.
BUT when I mounted it and torqued up the bolt it does not tighten the sprocket down - it just "floats". Is this right? If so will it hit the swing arm? Its soooo close.
thanks!
saintfish is offline   Reply With Quote
Times are GMT -7.   It's 05:02 AM.
