Old 09-10-2013, 07:42 PM   #10876
palmstatecrawler
palmstatecrawler's Avatar
Oddometer: 489
Dirty, if I can do it anyone can. I did it by myself but it would be easier to have someone else help. Make sure you have it on a centerstand not a swingarm lift. Dont ask how I know this...
'13 KTM 690 Enduro R w/ full akrapovic exhaust, Evo1 lid, uni filter, Renazco seat, hard parts windshield and footpad, scotts damper with BRP submount, hammerhead shifter, flatlands skidplate, lost dog centerstand, Touratech engine guards, r&g front and rear axle and exhaust sliders, piaa 1100's, Doubletake mirrors, G2cam system,
'07 Kawasaki KLX250, '86 Yamaha BW80
palmstatecrawler is offline   Reply With Quote
Old 09-10-2013, 07:58 PM   #10877
pookguy88
Oddometer: 107
so if I get it back in do I then use an impact wrench to remove that bolt?
pookguy88 is offline   Reply With Quote
Old 09-10-2013, 08:10 PM   #10878
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,692
yes. Or, if you can get it back in, you might try putting the other bolt in.. sometimes you can "switch" which one tightens... and which one comes loose.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 09-10-2013, 08:16 PM   #10879
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,991
As in On a bike lift stand that gets both wheels off the ground?
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 09-10-2013, 09:47 PM   #10880
palmstatecrawler
Oddometer: 489
Yep. The front doesnt really matter but you need to have the rear off the ground.
Old 09-11-2013, 01:39 AM   #10881
vander
full-time dreamer
vander's Avatar
Oddometer: 918
Originally Posted by v8toilet View Post
Check it with the bike level and at operating temperature.
you can download the user's manual from KTMUSA.com
Great. Many thanks!
Manuals LINK
XTZ
vander is offline   Reply With Quote
Old 09-11-2013, 03:51 AM   #10882
ktmmitch
Oddometer: 692
Originally Posted by ohauitirod View Post
Hi , does the collar come with the spring ?
No, the stiffer spring comes with a specially machined KTM OEM alloy collar, our Stainless Collar is available seperately.
ktmmitch is offline   Reply With Quote
Old 09-11-2013, 08:24 AM   #10883
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,313
Well after over 26K miles my Regulator finally crapped out.
Ordered up a new Super Mosfet from Jack.
This winter I am going to open up the top end and do some preventive parts replacement. Roller rockers, piston and rings.
KTMMitch, will you have the bigbore kits available by then?
You mentioned them some time ago along with a billet clutch cover.
Any info would be appreciated.
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is online now   Reply With Quote
Old 09-11-2013, 08:29 AM   #10884
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,662
Originally Posted by dirty_sanchez View Post
I mean, my Dad has the ultimate set of tools
My Dad's a TV Repairman, he has an AWESOME set of tools, we can fix it!
When they say Harleys are for 1%ers, I don't think they mean guys who sell crank and get in bar fights any more.
Roadracer_Al is offline   Reply With Quote
Old 09-11-2013, 08:47 AM   #10885
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,737
Basically you put it back in and then try tightening and loosening the bolts opposing each other until you get the one in question to come loose. The impact wrench is simply one option when you attempt to loosen the bolt. My 08 was the same way I had to fight it back and forth until I got the bolt on the left hand side to loosen.
v8toilet is online now   Reply With Quote
Old 09-11-2013, 09:45 AM   #10886
ktmmitch
Oddometer: 692
Our pistons wont be big-bore, just std or higher compression, made by Cosworth in UK.
Billet cover next job on milling machine.
Old 09-11-2013, 09:48 AM   #10887
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,313
Sweet, thanks for the info, and please let me/us know when they will be available, put me on the list, I'm in when they are ready.
Old 09-11-2013, 01:44 PM   #10888
rdkyote
rdkyote's Avatar
Oddometer: 70
Should one apply anti-seize to these? On a related note, I need to remove a mangled rear brake lever and noticed that this bolt had a little corrosion on it. It came off easy enough though.
2012 KTM 690 Enduro R
2007 KTM 250 XC
rdkyote is offline   Reply With Quote
Old 09-11-2013, 01:45 PM   #10889
chrislitt
B-KTM-W
chrislitt's Avatar
Oddometer: 94
big bore option
Hmmm, though I have no interest, for the harder to please group I wonder if the 2013 full 690 top end fits on the earlier bottom?
Donate to your causes 'cause your enemies are outspending you! 2011 R1200GS Adventure,2009 KTM 300XCW, 2009 KTM 690R, Rotarian, Member of AMA / D36, NRA, CRPA, BRC, BMW MOA 174799. Happy to still be working though it interferes with riding!
chrislitt is offline   Reply With Quote
Old 09-11-2013, 02:01 PM   #10890
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 954
Wiring scheme show a list of 44 wire/pins into the EFI unit on the 690. But shows them as a flat line of 1,2,3,....,43,44 positions, but the EFI unit has two rows of what should be 22+22.
Anyone knows how is aligned?
1,2, ...,21,22
23,24..., 43,44
maybe i'm missing something obvious, but couldn't find further info on it.
Need to verify continuity between a connector and the EFI unit and i'm trying to avoid stripping the harness
690R
Times are GMT -7.   It's 08:39 PM.
