Old 11-01-2013, 07:32 PM   #11851
DirtJack
DirtJack's Avatar
Oddometer: 1,449
Originally Posted by Night Falcon View Post
I am looking at replacing my already replaced speedo (under warranty) on my 09 as the digital display is failing. Been looking at theses : http://www.trailtech.net/digital-gauges/vapor They don't have one listed to fit the 690 but I emailed Trailtech and they said they could probably get one to fit. I wanted one with a rev counter which the enduro type ones don't have. Not sure how the fault codes work though....more investigation needed.
Here's how to do the Vapor installation Maurizio's way He used a Vector, but the installation would be virtually the same except for the tach input which is easy to do.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 11-01-2013, 10:56 PM   #11852
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 1,833
Cheers DJ
My EXC530 Adventure
2008 Beta Rev3 - Trials with lots of errors
Night Falcon is online now   Reply With Quote
Old 11-02-2013, 12:31 AM   #11853
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,660
Originally Posted by .chris View Post
Just whipped the rocker cover off and it appears everything is still there (phew).
But the decompression shaft did side out as I took the cover off (possibly because the bike is on its side-stand. Would that be normal?
No, this is not normal. The shaft should not slide out.. it should be held in place by the copper clip. If it slides out, it won't engage.. making it nearly impossible for the starter motor to turn your bike over.
You need to slide the cam out like you would if you were changing your valve shims in order to get at the copper clip. Hopefully it will still be on the top of your motor somewhere. When this happened to me, the clip stayed on the shaft but was pushed toward the lobe of the cam shaft. So it was not doing its job retaining the shaft, but it did not fall in the engine.
You can see where the shaft contacted my valve cover.
The worn out clip. Luckily it stayed on the shaft.
I would recommend replacing the weight, spring, screw and clip. They are cheap parts and it will hopefully save this from happening again. Any slop in the weight will eat through the clip.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 11-02-2013, 03:14 AM   #11854
.chris
690 Advenduro
.chris's Avatar
Oddometer: 93
Thanks, I think that is EXACTLY the problem, I will have a search for that pin tomorrow. And will order the replacements on Monday.
My rocker cover has the exact same marks on it.
EDIT: Found the clip, and promptly dropped it onto my messy floor and lost it, but one side of the clip was visibly worn.
Thanks everyone for your assistance.
I am interested in the future, because it's where I am going to live
.chris screwed with this post 11-02-2013 at 03:37 PM
.chris is offline   Reply With Quote
Old 11-02-2013, 06:39 AM   #11855
sprouty115
sprouty115's Avatar
Oddometer: 1,353
So Chris had this issue with 65,000 Km. Noah, do remember the approximate mileage when you had the problem? just curious if it was around the same time.
sprouty115 is offline   Reply With Quote
Old 11-02-2013, 09:36 AM   #11856
Velociraptor
TrackBum
Oddometer: 1,096
I just ordered some decompression parts. Not that expensive and good to have spares around just in case.
Uller, your airbox mods are nice. I have not done those, but I just left the front bolts off. So the airbox is secured by the two back bolts and the rubber boot connecting to the throttle body. So far so good after two years.
I am also running the RR EVO2 tanks so a different setup to yours. The RR tank kit comes with a small plastic vent box that fits into the right side of the frame. So the airbox still vents to that box. Also I made a SAS blockoff plate for the valve cover but kept the vent open and also routed that hose to the vent box.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor screwed with this post 11-02-2013 at 09:54 AM
Velociraptor is offline   Reply With Quote
Old 11-02-2013, 09:45 AM   #11857
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,970
Uller-
I have the same safari tank setup. I was considering doing your airbox mod.
What are the major benefits to that? Is it just for quick access to the injector?
Can you now do a valve check with the tank on?
I figure after all the work of pulling the Safari tank, a few more bolts isn't much more.
Also- Did you ditch all the plastic covers and just move the stock regulator to the left side?
I was considering a little clean up of all that plastic as well.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike screwed with this post 11-02-2013 at 09:53 AM
dad2bike is offline   Reply With Quote
Old 11-02-2013, 12:09 PM   #11858
Katoom72
Katoom72's Avatar
Oddometer: 831
Think im gonna replace the clip every valve check. New copper clip every 10k ain't costly, it's a rather cheap but safe thing to do.
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 11-02-2013, 02:05 PM   #11859
Uller
Uller's Avatar
Oddometer: 1,672
It is good to know that the front of the airbox doesn't drop if left unsecured. I guess that makes my mod overkill. I like that.
I haven't seen the EVO2 collector box.
Originally Posted by dad2bike View Post
Uller-
Ultimately, this allows me to work on the bike much easier when I am away. When I check things, change the oil, look at valves back at my shop I tend to take the tank off. It just makes it easier to access everything. Isn't that why the trellis frame is so cool.
I can think of a few benefits. Most of them are for when you are away from the shop and removing the tank would be a major time consumer that you don't want to deal with. Without doing this mod, you have to remove the tank entirely to get to the two front airbox screws to get the airbox out and access anything. So, not only are you lying on the ground to get to the tank bolts but you are also fiddling with the fuel lines. In a best case scenario, that is probably 10 to 15 minutes of work to take off, then that time again to put back on.
Possible Benefits:
1. I have externalized my fuel filter. I can now access it very easily by removing only two screws and loosening the air box boot, as it now is directly below the airbox once that is out.
2. Should I have any issues with the fuel injector, I can now easily access that too. Or really any running issues for that matter. I can access air, fuel and spark without removing the tank.
3. Should I have issues with the spark plug, I can access it without removing the tank.
4. Should I have a problem with a water crossing, everything I need to get to in order to drain water and get the bike going again is now accessible with only removing the airbox. (knock-knock-knock)
5. If I have an electrical problem, I can just about get to all critical areas without removing the tank.
I believe, if you really wanted to, you could get to the head and check the valves without taking the tank off with the airbox removed and the Safari Tank still on. However, I would think that you would appreciate the additional access provided by not having the tank there for that operation. Especially, if you are one of those people who always uses a torque wrench for reinstalling motor components.
Edit: I went out and took a look, the back left head bolt would be a tuff one to get undone without a double-articulating socket adapter. Other than that, you have good access to the top of the motor, the only limitation is if you need to get into the side of it for installing a locking bolt or pulling the rockers. Thinking of that, it would block the ability to see the TDC markings and line things up properly. Maybe you could do that with a mirror???
Regarding the side covers and R/R, I had my stock R/R fail on me and fry my brand new lithium battery. I replaced it with an aftermarket unit that is much, much better. Even though the R/R itself is the same overall size and bolt pattern, it has sealed connectors on the bottom and the wire sides of those contact the coil in the stock location. I have the tank and don't need the side panels to hold on the plastics. I also removed the collector box on the R side so, I don't need them anymore. It was just extra stuff in the way. I came up with the super simple mounting method on the left side for the R/R. It fits perfectly under the tank with optimal airflow, almost like it was supposed to be like this. I then simplified the wiring and have the R/R directly connected to the battery instead of running through the Starter Relay.
I am not really sure if you could do this without changing the R/R due to the configuration of the stock wiring harness going from the L side of the bike to the R.
Uller is offline   Reply With Quote
Old 11-02-2013, 03:01 PM   #11860
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,970
Great info. Thanks Brad!
I can see me cutting those tabs at some future time. Maybe at the next valve check. I've never done the task myself. The PO did them just about 1K miles before I bought the bike. I'm thinking in the next few weeks I'll tear into the valves on my 950 & the 690. I have the Hot Cams kit that should cover both bikes.
I too have my fuel filter external. I mounted it up where I can replace all from the outside.
It was your post that has me thinking about the oil catch canister as a possible path for dust into my air box. I've sealed up all box seams with RTV. If I ditch the catch tank for a simple filter it removes that possible issue. A bunch of hoses too.
UNI has a nice little foam filter with clamp that will fit right over the hose end. I picked one up to use on my Dodge diesel drip hose.
Ditching the plastics & catch tank will help with cleaning up on top of the motor. We don't seem to get much wash hose water up there and it is always covered in crust.
Tom
My2Wheels
690 WIKI
Old 11-02-2013, 03:06 PM   #11861
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,970
How often are you guys changing spark plugs? I'm figuring to order one in and do that when I do my valve check. I think the PO did that about 3000 miles ago.
Tom
My2Wheels
690 WIKI
Old 11-02-2013, 04:36 PM   #11862
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,442
I think I put one in around mile 7500 and the old one still looked good.
Seth S
Seth S is offline   Reply With Quote
Old 11-02-2013, 09:26 PM   #11863
Singletrack_mind
Cave Man
Oddometer: 381
Save your self $20 and don't worry about it until closer to 10K miles
Singletrack_mind is offline   Reply With Quote
Old 11-02-2013, 09:54 PM   #11864
Singletrack_mind
Cave Man
Oddometer: 381
Some helpful replies back there, thanks.
If running a pod filter w/o an airbox decreases MPG by 10-15% I don't want to go that route. Fuel range is sometimes an issue for me as is.
Someone asked at what milage the auto decompression devices are failing: Mine did not destroy it's copper clip, the pivot bolt for the fly weight backed out. This happened at about 25K miles on a 2008 bike.
Since my head's still apart awaiting valve shimming, I will examine the copper clip.
Singletrack_mind screwed with this post 11-03-2013 at 07:13 AM
Old 11-03-2013, 03:44 AM   #11865
drunkenrich
drunkenrich's Avatar
Oddometer: 132
My 2010 ktm was acting weird today, took it out for probably the last ride of the year today, ran good all day then near the end of the day it acted like it was out of gas, hesitating. Stopped got gas, hesitation stopped. Then about 20 min later it shut off on me while riding, twice. The control screen was flashing and it wouldnt turn over, just chug. Turned key off then on and it was fine. Any ideas?
2009 Yamaha Nytro XTX
2010 KTM 690 enduro r
drunkenrich is offline   Reply With Quote
Times are GMT -7.   It's 11:48 PM.
