Old 12-26-2011, 06:15 PM   #1186
andykeck
Oddometer: 109
Originally Posted by andykeck View Post
2. I checked the fuel pressure, it's great. The prime immediately spikes the gauge up to, dunno, 53psi I think. The moment the prime cycle stops, the pressure bleeds down over a couple of seconds to something closer to 20psi. I don't know how the regulator works, so I don't know if that's normal or not. When I installed the current fuel pump, I'll admit that I thought the quick disconnect fitting in the tank just ahead of the regulator didn't seem as snug as I'd like, but I could be imagining things. If the line pressure isn't supposed to bleed down that quickly, my guess is that fitting is not 100%. But I really don't know. It could explain some of the hard starting though, if I turn on the key, let it prime then wait a couple of seconds while I screw with my gloves or whatever, then the line pressure would drop, meaning my one and only one injector blast is at less than half the intended fuel pressure and thus maybe not enough fuel to catch.
Ideas anyone?
I'm just gonna give this one bump to see if anyone knows if this is how the regulator is supposed to work.
andykeck is offline   Reply With Quote
Old 12-27-2011, 02:34 PM   #1187
CordR
Oddometer: 514
Originally Posted by ktm950se View Post
Anyone doing rewinds on this for more juice?
ktm950se
All I know about rewinding is that it's out of my scope and could only lead to bad things if I tried it.
I haven't seen any mention of an aftermarket upgrade. Perhaps my concerns are unnecessary?
CordR is offline   Reply With Quote
Old 12-27-2011, 02:35 PM   #1188
CordR
Oddometer: 514
Originally Posted by Barman View Post
The output is 224w.
I remember this discussion from the big thread and believe the consensus was that we've safely got about 100w of additional accessory load before there may be charging issues.
Thanks, Barman. I thought I had read something around that number.
Old 12-27-2011, 02:55 PM   #1189
johnlt
Oddometer: 591
Can someone tell me the amount of watts the KTM heated grips use in the HI position? tks
Johnlt
2009 BMW R1200 GS Adventure
2000 Suzuki DR200
1975 BMW R75/6
Yamaha WR250R
johnlt is offline   Reply With Quote
Old 12-27-2011, 04:44 PM   #1190
CHRIS_D
CHRIS_D's Avatar
Oddometer: 969
Not sure of the additional total watt load (maybe 130 watts total), but I run heated gloves, and a liner from Warm n safe without a problem. I also have a Zumo GPS with the XM radio option that is placed in this mix. Now I will say when I turn my heat trolley up all the way I get a bit of a flicker on the headlight (when on high beam) in sync with the heat trolley's cycling. To be honest I'm not all that concern and been running like this for a while.
I'm sorry not much to do with the heated grips but them alone should not be a problem (their usually 30 watts total).
Hope that helps!!
2014 KTM 1190 Adventure R
2011 Victory Cross Country
CHRIS_D is offline   Reply With Quote
Old 12-27-2011, 04:48 PM   #1191
CHRIS_D
CHRIS_D's Avatar
Oddometer: 969
So I been eyeing the new 2012 KTM 350 EXC-F. It's only 236 lbs dry.
Old 12-28-2011, 12:30 AM   #1192
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 1,001
I'll be embarrassed to have a bike lighter than myself.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 12-28-2011, 02:16 AM   #1193
DirtJack
DirtJack's Avatar
Oddometer: 1,606
Not 100% sure, but is probably a spring loaded 1-way valve. Maybe there is debris lodged in the valve, keeping it from sealing.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 12-28-2011, 04:13 AM   #1194
CHRIS_D
CHRIS_D's Avatar
Oddometer: 969
I know I just lost 20lbs (now I'm down to 203 lb) and just need to lose 8lb more to 195lb. So far this last 8lbs has been a real challenge with the holidays being here! I'm hoping with losing all this weight and working out more 'that my endurance will increase dramatically riding off road.
CHRIS_D screwed with this post 12-28-2011 at 04:19 AM
Old 12-28-2011, 07:58 AM   #1195
cpg7562
just me..
cpg7562's Avatar
Oddometer: 102
clutch slave
Originally Posted by bobzilla View Post
no but my buddy missed the buy and wants one
Im in if we get enough folks for a group buy!
Chris
'10 KTM 690 R
My Spot
cpg7562 is offline   Reply With Quote
Old 12-28-2011, 09:02 AM   #1196
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
Or you could just order the "enhanced" cylinder direct.
http://translate.google.com/translat...26prmd%3Dimvns
I am at one with my duality.
Barman is offline   Reply With Quote
Old 12-28-2011, 10:08 AM   #1197
CHRIS_D
CHRIS_D's Avatar
Oddometer: 969
Does anyone know if Rekluse has any plans to build a kit for our 690?
Old 12-28-2011, 10:39 AM   #1198
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
I've been wondering as well. Just shot their tech dept an E-mail......
Old 12-28-2011, 10:40 AM   #1199
Uller
Uller's Avatar
Oddometer: 1,698
I can't remember where, however, I remember reading that they looked into it and determined that it wasn't possible due to the slipper clutch and the amount of power. I also remember another company looking into it and having the same issues.
Uller is offline   Reply With Quote
Old 12-28-2011, 10:45 AM   #1200
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,802
yep they looked at it several years ago and decided that due to the complexity of the slipper clutch they could not do it. I don't know if the 690 Rally clutch is a slipper...if not it might be possible to convert to a 690 setup and then get a rekluse made...again not likely to be a huge customer base for that one.
Seth S
Seth S is offline   Reply With Quote
Times are GMT -7.   It's 04:47 AM.
