Old 09-06-2011, 09:10 PM   #1
herman maire OP
Oddometer: 155
R75/7- driveshaft bolt stripped!! why?
Thanks for looking. I am trying to figure out why the bolt stripped on my driveshaft coupling when I tried to torque it to spec (170-180ft/lbs.)
Is this the correct torque figure?
This was supposed to be a 2 minute job.... all I had to do was torque the coupling bolt on the driveshaft and install my shinny freshly painted swing arm .
It was not to be, it went from worse to worse.....
After the bolt stripped, it was impossible to remove the nut since all it would do is spin and would not catch the last 2 treads on the driveshaft.
I bring it to a machine shop, I tell them the problem, they say no problem. I say cool.
While I am busy working on something else I get back to the shop and they hand me the shaft in 2 pieces.... I say WTF did you do.
Oh, we had to torch the nut off also cutting the treaded section of the driveshaft off. Its amazing how stupid people are.
So, if anybody has a driveshaft that would work with a R75/7.... please PM info and price.
R100GS
R75/7
KTM 950 ( slowly looking)
herman maire is offline   Reply With Quote
Old 09-06-2011, 10:49 PM   #2
jbcaddy
Oddometer: 952
that is a sad tale so sorry
jbcaddy is offline   Reply With Quote
Old 09-07-2011, 01:11 AM   #3
pommie john
pommie john's Avatar
Oddometer: 1,133
I haven't got my manual in front of me, but 170 ft pounds seems a hell of a lot.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 09-07-2011, 01:20 AM   #4
pommie john
Oddometer: 1,133
As you were! My manual says that's the right torque.
Bertrand Russell
Old 09-07-2011, 05:31 AM   #5
airheadDavey
airheadDavey's Avatar
Oddometer: 63
There is now way they are 170ftlbs. I think you may have misread the manual. The center nut on the back of the output shaft I believe is that tq spec. I dont have the manual in front of me to give you the proper specs on the bolts. Sorry that happened to you and I feel your pain.
airheadDavey is offline   Reply With Quote
Old 09-07-2011, 05:32 AM   #6
airheadDavey
Oddometer: 63
Are you sure its not 170 inch pounds?
Old 09-07-2011, 05:58 AM   #7
noman
just another bike nut
noman's Avatar
Oddometer: 591
torque
from my r75/6 bmw repair manual:
hex nut on coupling bell housng 173.5 -188 ft-lbs
twelve-sided bolt 17.3 - 18.8ft-lbs
may not be the same as r75/7
Each man's death diminishes me,
For I am involved in mankind.
JD.
noman is offline   Reply With Quote
Old 09-07-2011, 06:24 AM   #8
herman maire OP
Oddometer: 155
Thanks for the replys.
the bolt I had trouble with is not the transmission output shaft bolt.
In the link you have to select driveshaft and it is #7 in the diagram http://www.maxbmwmotorcycles.com/fic...7&rnd=03252011 .
Still looking for a driveshaft in good condition if anybody has one.
R100GS
R75/7
Old 09-07-2011, 06:25 AM   #9
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 4,013
Folks, I think he's talking about Nut #7 that holds on Flange #6.
I don't have the /7 spec with me, but 170 ft-lbs sounds correct-ish.
'73 R60/5 Toaster
Old 09-07-2011, 08:21 AM   #10
herman maire OP
Oddometer: 155
Bill,
Thanks for that.... yes it is indeed #7.
R100GS
R75/7
Old 09-07-2011, 08:33 AM   #11
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,297
Just bad luck, that's all.
Move forward, get another shaft and fix it.
Most used shafts have notchiness in the joint.
It's just the way it is, don't freak out when you find a used one that way.
Some is okay, Too much is not.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 09-07-2011, 08:39 AM   #12
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 11,352
Did you torque it with dry or oiled threads?
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx
You can be Han Solo, and I can be another Han Solo...
Old 09-07-2011, 09:21 AM   #13
PaulRS
Dutch fool
Oddometer: 682
For the /7 the manual states a slightly lower spec, around 150 Lb-Ft (converted from Nm).
But that wouldn't strip the threads, imho.
Manual says nothing about oiling, so it should go on dry.
Just bad luck, I think.
Paul.
Geht net, gibbet net.
PaulRS is offline   Reply With Quote
Old 09-07-2011, 09:31 AM   #14
bmwrench
Oddometer: 1,483
The spec is/was 170 lbs/ft, but I haven't put that much torque on one in years. Go to 150 with a drop of red Loctite on the threads.
bmwrench is offline   Reply With Quote
Old 09-07-2011, 10:34 AM   #15
Bill Harris
Oddometer: 4,013
And the coupling is a taper-fit so make for absolutely certain that BOTH parts of the taper (inner & outer) are oil-free-- clean with acetone or brake cleaner if need-be.
'73 R60/5 Toaster
Bill Harris screwed with this post 09-08-2011 at 06:23 AM
Times are GMT -7.   It's 12:21 AM.
