Old 05-02-2013, 01:22 PM   #16
jetcity
jetcity
Oddometer: 10
2008 KTM 690E - complete shutdown
Accelerating through a left turn in town, bike completely shuts down.... no power at all.; did not accidentally hit kill switch; battery wiring did not look disconnected. would not respond at all to turning of the key
I waited for about 10 minutes --> fired up with a "FI - bat" error (I believe it said) with tachometer showing redline and clock reset. Made it home (1/2 mile) and parked it.
Any thoughts? Thanks in advance for the input.
jetcity is offline   Reply With Quote
Old 05-02-2013, 01:34 PM   #17
Biped
NooB Again
Biped's Avatar
Oddometer: 339
Interesting, looks like a confused ECU, possibly regulator/rectifier related due to over voltage on the system. Or your battery completely disconected and reconnected without you knowing.
If it moves and it should not, duct tape it, if it does not move and it should WD40 it!
Biped is offline   Reply With Quote
Old 05-02-2013, 02:45 PM   #18
Velociraptor
TrackBum
Oddometer: 1,122
Battery failure? Rectifier problem? Short somewhere in the wiring?
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 11-07-2013, 09:50 AM   #19
RB450
RB450's Avatar
Oddometer: 296
I bought an 09 a few months ago. When I'm riding snottier and tighter trails, I tend to clutch a lot. Several times, I have lost my clutch completely, look in reservoir, no fluid. Where does it go? Is this the bad clutch slave issue, and will replacing the clutch slave solve my problem.
RB450 is offline   Reply With Quote
Old 11-07-2013, 07:40 PM   #20
live2ridetahoe
RN
live2ridetahoe's Avatar
Oddometer: 1,472
You could always try this...
live2ridetahoe is offline   Reply With Quote
Old 11-08-2013, 02:22 AM   #21
RB450
RB450's Avatar
Oddometer: 296
Thanks. Everything points to the slave cylinder. I guess it's Time for a sigutech and another oil change.
Old 08-25-2014, 12:34 PM   #22
Strega
Black is a color
Strega's Avatar
Oddometer: 487
Thanks for this ;)
-Roger
Bikes: ['09 KTM 690 RR]['98 KTM 620 Adv]['07 WR 450F]['99 YAM R6]
Support: [Where Am I Riding][Dual Sport Moto][C.O.R.E.][Nomadic Racks][Dual Sport Maps]
Strega is offline   Reply With Quote
Old 08-28-2014, 05:16 PM   #23
RB450
RB450's Avatar
Oddometer: 296
Thanks. That's the one I put in. No problems since.
Old 08-28-2014, 06:58 PM   #24
Vector Leto OP
Vector Leto's Avatar
Oddometer: 169
update and delete posts
I added the Oberon clutch slave link from Magile and 12bong13's index. Unfortunately, I think I accidentally deleted some of the older links. . Sorry.
If y'all don't mind, delete your post after the link is added. Thanks.
Looking for the next cool thing.
Vector Leto is offline   Reply With Quote
Old 03-05-2015, 11:26 AM   #25
brysjacobs
Oddometer: 8
KTM 690 electrical help!!!
Hi everyone,
I'm in need of some major help with my 690 enduro r 2012. I've put my bike back to standard after having an evo 2 tune kit fitted and I've had a problem with the right side throttle sensor for 3 weeks now. I keep getting code P0227 throttle grip sensor low voltage and a value of 0.4 (what does this stand for??) in the top right of the throttle menu on tuneECU. Things I have checked so far:
- cleaned every connector including earths with electrical contact cleaner- all good
- buzzed the cables back from the plug of the sensor to the ecu- same results on both sides, seems good.
- voltage of 4.9/5.0v at the plug for the sensor
- checked all the fuses both in the ignition relay and fuse board
- regulator puts out 14.4v with the engine running, seems good in my book
- changed the throttle sensor (at great expense). no cure :-(
- throttle 'on+off' reset and 15 min idle done. no cure
- tried uploading the old map from when it used to run ok, still no cure
- swapped the relays around, no cure
One clue may be that when I installed the battery I accidentally arced the + terminal to the frame, but didn't blow any fuses..
Has anyone got a wiring diagram that shows what the right side throttle sensor connects to so I can trace it back? Had my fair share of motorcycle fixes over time but this one is losing my faith in KTM..
Any help on this would be gold for me.
Thanks,
Ryan.
brysjacobs is offline   Reply With Quote
Times are GMT -7.   It's 01:55 AM.
