Old 09-07-2011, 10:34 AM   #1
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,349
1977 R100RS shift shaft oil leak...
My RS just started leaking a tad from the shift shaft. It is a small puddle of about 2in in daimeter and it seems to stop after it cools from a ride. Stupid wuestion, but what goes in the trans for lube and where does it go in and where do I check it? I can't find a fill hole??!!??!?!?
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 09-07-2011, 10:55 AM   #2
airheadDavey
airheadDavey's Avatar
Oddometer: 65
Make sure the bike is on the center stand. The fill plug is located on the transmission and requires (90w syncromesh gear lube) right near the connecting rod for the shif lever and uses a 6mm hex key if I remember correctly. Remove the fill plug and use a piece of fuel line to attatch to the tip of the gear lube bottle to get the angle. Fill until fluid starts drizzling out the fill plug hole.
airheadDavey is online now   Reply With Quote
Old 09-07-2011, 11:04 AM   #3
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,349
Damn, I knew that had to be it right after I posted this! THANKS! I'll go tot he parts sto and get some 90wt gear lube for lunch and fillerup before I ride home. Already ordered the new seal about twenty minutes ago for the shaft...2 in fact in case I bung one up the first time!
Old 09-07-2011, 11:28 AM   #4
airheadDavey
Oddometer: 65
Double check to make sure its sycromesh that is needed. It might be hypoid as I cannot be sure. I get a gear oil that is approved for both syncro and hypoid.
Old 09-07-2011, 11:32 AM   #5
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
???? Synchromesh????
That ain't no synchromesh box.
You just need GL-5 Spec gear oil 80-90 wt is the most common.
As long as it's rated "GL5" you're fine.
8mm hex key, not 6
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 09-07-2011, 12:22 PM   #6
kbasa
Colnago!
kbasa's Avatar
Oddometer: 69,813
Replace the seal, then top off.
To get the seal out, take the shifter off the trans, then take a ballpoint pen and lever the old one out. You should be able to press the new one in with your fingers. I can't remember, but I think the seal is set down in the recess a bit, so use the old seal to set it in there nice and square.
IMHO.
Fuck Cancer. Ride bikes. - dave + tina
kbasa is offline   Reply With Quote
Old 09-07-2011, 02:08 PM   #7
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,220
I replaced mine a month ago. Because I'm supposed to know, I didn't ask for any advice. Well it doesn't leak at least. I had no problem getting the old one out. I used a most efficient method to install the new seal. I found a socket from a socket set. One that was large enough to drive the seal but small enough to not stick in the bore. Drive away. It went in so smoothly almost no effort. I drove it ALL the way in. Uh-Oh. The bore is much deeper than it needs to be. The seal is now almost not visible. Replaced the shift lever and topped off oil. Well it doesn't leak but if I have to do it again I think it'll be much harder to get the seal out. It's pretty deep. So let my mistake be a lesson for you and when you put your new seal in don't drive it all the way in. You can stop after it clears the edge 1 or 2 mm.
Old 09-07-2011, 08:30 PM   #8
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,349
cool! They sould be here Tuesday. I did drain and change the hypoid with 80-90 when Alejo and I got back from the install at 17:30 in front of the shop. Busy busy so am glad I don't HAVE to swap the seal till Tuesday! The stuff that came out was like a melted cafe latte'. But there appeared to be no water in it. Is there a way for water to get in there, like a breather? It was pouring on me on the way home three times last week and once this week so I would not be sur[irsed it there is a breather that some water got in there.
Old 09-07-2011, 08:39 PM   #9
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,708
The rubber boot on the speedo drive is the most common water entry point for the gearbox.
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 09-08-2011, 02:58 AM   #10
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,673
Usually no need to drain the oil to change the seal.
Lean the bike on the right rocker cover/pannier, maybe on a step or an embankment or something. Remove the lever and fish out the seal. Replace in reverse.
However, the oil you have recently drained is water contaminated, so inspect the speedo cable boot, and maybe shove some grease under it.
I find a semi-synth oil can remove some clunk from the gear change too. I would just buy something cheap first though...run the bike to get the gear oil good and hot and change it again. When happy that the milky look is gone, use the semi-synth.
boxerboy81 is offline   Reply With Quote
Old 09-08-2011, 07:38 AM   #11
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,349
I have decided to change it again when I get the seal installed and I will address the boot as noted, thanks again all! I am again so happy these things are so easy and cheap to work on.
Old 09-08-2011, 07:48 AM   #12
Grider Pirate
Grider Pirate's Avatar
Oddometer: 1,686
Just because I happen to have a picture.... here's the filler plug. Yeah, I know you already have it figured out.
Please don't tell Mom I'm a pilot. She thinks I play piano in a whorehouse.
http://griderpirate.smugmug.com/
http://www.youtube.com/my_videos?feature=mhum
Grider Pirate is offline   Reply With Quote
Old 09-08-2011, 08:55 AM   #13
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,349
Thanks, great picture. I find looking at a parts fische from MAX helps me locate stuff as well!
Times are GMT -7.   It's 10:11 AM.
