Old 01-01-2012, 05:51 PM   #31
Rocking-M OP
DuckCowboy
Rocking-M's Avatar
Oddometer: 234
Getting some more of the Velo sorted out. The Ducati seems to be running much better since I rebuilt the carbs (after ultrasonic cleaning for the 5 or 6th time).
figured out the belt drive and clutch,
alignment on the chain sprockets looking pretty close. Still have to set up a laser alignment redneck rig to align the wheels then recheck and shim if necessary the chain alignment.
checked fitment on the tank with the head steady, I like the hand beat front fender? Goes with the hand hammered oil tank which is off to be tigged.
99 ST4 (for sale)
2003 ST4s (the new one)
Velocette Thuxton (The old one.)
Blue Ridge Mountains, Virginia
Rocking-M is offline   Reply With Quote
Old 01-02-2012, 08:53 AM   #32
Tripletreat
Oddometer: 587
Velo
That's coming together real nice. I look forward to seeing pix of the finished product.
Years ago I had an opportunity to ride a Thruxton Replica. I was in way over my head on that one! It had a huge Amal GP that apparently didn't have provision for a throttle stop and consequently would not idle. Every stop was a challenge. If I blipped the throttle wrong it died and kicking it back to life was practically beyond my ability, what with the manual ignition advance, choke and 500cc high compression piston. Out on the road however, it was a delight. Locomotive thrust and I still marvel at how well the brakes worked on that bike.
For all we know, this may all be just a dream; we come, we go like the ripples in a stream.
Tripletreat is offline   Reply With Quote
Old 01-12-2012, 03:58 PM   #33
Rocking-M OP
DuckCowboy
Rocking-M's Avatar
Oddometer: 234
Originally Posted by Tripletreat View Post
Years ago I had an opportunity to ride a Thruxton Replica. Out on the road however, it was a delight. Locomotive thrust and I still marvel at how well the brakes worked on that bike.
Oh your getting me all fired up to get her running. I got the oil tank back from the tig welder today. When I was out to Mart's to box parts I looked at some of his art work through the years, silver vase and other bits he'd hand hammered on an anvil from one sheet to form. I thought wow, I'd like to have one of his pieces. I do, it's oil tank art!
99 ST4 (for sale)
Old 01-26-2012, 05:40 PM   #34
Rocking-M OP
DuckCowboy
Rocking-M's Avatar
Oddometer: 234
just a note to let y'all know I ain't forgot the Velo.
I've routed the oil lines and ordered a racing magneto cover which allows the use of double ended plug wires which are much easier to build than the standard plug wires for the Fairbanks Morse mag. I think I've decided on plugs for the beast and I'm resetting the timing back to 25 degrees advanced rather than the 37 degrees as was per factory with one plug. The two plug head ought to give a good burn with less advance and make it easier to kick start, if there is such a thing as an easy kick starting velo. :)
I've also got the brake stay made for the front brake.
I'll have to figure out my rear sets/foot pegs mounting. Also need to return the Velo intake manifold and shorten to allow a rubber mount since that helps cut down on heat transfer to the carb.
More to come, might even be cranking her up soon.
99 ST4 (for sale)
Old 01-31-2012, 04:54 PM   #35
MayerMR
MayerMR's Avatar
Oddometer: 268
Keep plugging along...I'm loving this build.
1972 Honda CB450 (Rebuilding), 1971 Ducati 450 R/T (in the queue), 1971 Honda SL100, 1965 Ducati 160, 1967 Honda CM91/CT90 hybrid, 1986 BMW K75
MayerMR is online now   Reply With Quote
Old 01-31-2012, 09:35 PM   #36
Tripletreat
Oddometer: 587
Do it!
Yes! That's gonna be a unique and beautiful bike.
Old 03-24-2012, 06:52 PM   #37
Rocking-M OP
DuckCowboy
Rocking-M's Avatar
Oddometer: 234
got her to run today....................finally..........forgot to shut the enrichment circuit off a bit to long and she started to flood, so the plug will need to be changed. BUT, she ran. I've been round and round and kicked it a thousand times, let it lay a couple of weeks, cleaned the carb which didn't seem bad, swapped to a single HT coil in the Fairbanks Morse mag and low and behold she ran. Skeered the neighbors horse too.
http://www.youtube.com/watch?v=iZQyHQi6dyA
99 ST4 (for sale)
Old 05-20-2012, 03:59 AM   #38
Rocking-M OP
DuckCowboy
Rocking-M's Avatar
Oddometer: 234
the tank strap.
99 ST4 (for sale)
Old 05-20-2012, 08:47 AM   #39
jbcaddy
Oddometer: 1,217
My AJS in a box is getting mighty upset with me it wants me to put aside some of my other projects and get her on the road. I can hear it speaking to me every time I look at your Velo. Good job
jbcaddy is offline   Reply With Quote
Old 05-20-2012, 09:44 AM   #40
killfile
49/50
killfile's Avatar
Oddometer: 353
Looks great, you are truly doing this project justice!
Gallery MotoSF & Neoedo
killfile is offline   Reply With Quote
Old 05-20-2012, 10:52 AM   #41
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,780
Looks like your tank was intended for a slimline frame. Great work. I'm looking forward to seeing it complete.
Rob Farmer is offline   Reply With Quote
Old 05-20-2012, 12:40 PM   #42
Rocking-M OP
DuckCowboy
Rocking-M's Avatar
Oddometer: 234
The ones I've seen mounted on the wideline all have the mounts in the back with the space between the frame. Doesn't mean I've seen what is correct.
Back when Mart order the tank from the fellows, he did so at the IOM in '85' this was the one for the bike. It fits up nice but the back rubber blocks are visible as you noticed. I've been told, that's the way it is.
99 ST4 (for sale)
Old 05-22-2012, 08:19 AM   #43
SlideSideways
SlideSideways's Avatar
Oddometer: 11
Was that an E30 project in the background of the video?
SlideSideways is offline   Reply With Quote
Old 05-22-2012, 01:50 PM   #44
Rocking-M OP
DuckCowboy
Rocking-M's Avatar
Oddometer: 234
yep, a E30 repaint for my son. His is an IS.
We also have an E30 325i four door. Terrific cars.
99 ST4 (for sale)
Old 05-27-2012, 06:23 PM   #45
Rocking-M OP
DuckCowboy
Rocking-M's Avatar
Oddometer: 234
had the old duck out today. Nice ride this morning.
99 ST4 (for sale)
Times are GMT -7.   It's 12:08 PM.
