09-11-2011, 07:32 AM
#1 |
Red Sox Nation
Oddometer: 8,902
F800GS vs. KTM 990 Adventure
Hello all. I searched but couldn't find any comparo's. Maybe somebody here can help.
I have about 60k miles on my 2004 KTM 950 and want to replace it. I've had it since new and have ridden it all over the continent. I like it, but its pretty well worn and the 950's are pretty crude running compared to the new 990's. I know I would be happy with another KTM, because they are much more refined these days. I like the way they handle, I want a 21" front wheel, spokes and tubes, center stand, 200 mile range and the suspension is very nice for hitting washouts and such you find on forest service roads. It takes a lot to upset the bike. It appears to me the F800GS is pretty much the same motorcycle as the KTM Adventure. Maybe a little smaller and lighter, which for me would be a plus. My present KTM is well farkled, but I want to keep my new bike totally stock. I want it quiet and functional for long days cross country and visiting more remote areas in the west. Anybody here gone from a KTM to BMW800? How do they compare? Thanks
Straight ahead and faster -Bo Weaver 1970 "There I was..." -Griffin Niner Three Hotel |
09-11-2011, 07:59 AM
#2 |
Oddometer: 2,841
This or`d to be fun......
The look of the 990 and the oil change will still tip it for me...... But that`s just me. Best think for you to do is pour yourself a lot of espresso....and look through both forums.....and make up your own mind....... because simply put...we are all different.... and while some prefers the Austrian.....others will lean towards the Gerrrrrrrrman..... May the force be with you..... Erling |
09-11-2011, 08:37 AM
#3 |
Oddometer: 70
I can only speak for the F800, but a recent trip around Europe gave me regularly between 220 and 240 miles per 16l tank. One day involved 9 hours of non-motorway travel (regular changes of speed) and I only filled up once! Epic all day travel.
I average 60mpg, and I don't ride that frugally!I, too, read about issues with the bike, and was a little wary. I'm 9200 miles in, and only a headlight bulb has been an issue, so mine seems OK (it's an 2010 '30-Years' model). I did replace the seat, though, as mentioned above - a must in my opinion. I think I'm correct in saying that the UK BMW off-raod skills school uses stock bikes. |
09-11-2011, 11:44 AM
#4 |
Quaaack!!!
Oddometer: 1,120
If you want to keep the new bike totally stock Im not sure the F800GS is for you. Coming from the KTM you won't like the standard suspension much, you will at least need to respring both ends as they are too soft, and the forks still won't be that great. You might also need to do something with the seat. I think you will also want some protection ... better bashplate, engine bars, hanguards. Finally in the miniminilist world I would add a boosterplug or accelerator module or similar thing to smooth out the bottom end power a bit. On the bright side none of this has to cost a fortune or be very difficult.
Further to the bright side the F800GS is lighter and thinner than the 990, has a better turning circle, uses a lot less fuel, is easier to work on and has far better fueling than the 990 I rode. It has less power, but if you can use all the power an 800GS has off road you truly are a legend. The farkling does work ... I often get on my 800 after I haven't ridden it for a while and can't believe what a nice bike it is! There is also the Triumph 800XC. but that is generally accepted as being better than the BMW on road, but not as good off ... less ground clearance, more weight, less bottom end torque. If you believe the published maintenance schedules it is also harder to work on. If you get a 990 you will at least need some protection for it and to relocate the sidestand. Throttle tamers and what ever else you use to even out the throttle response might be necessary as well. As they always say test ride them all and see which one appeals to you the most. If I had to pick one of them now I would probably get another 800GS, knowing I wouldn't keep it stock. I might consider the KTM, but only if they have really improved the fueling over the one I rode ... after a brief love affair I couldn't wait to give it back!
"All that is necessary for the triumph of evil is that good men do nothing." - Edmund Bourke Irish orator, philosopher, & politician (1729 - 1797) |
09-11-2011, 12:22 PM
#5 | |
Man of Kent
Oddometer: 16,080
"Every county of England, every country of Europe and every (part of every other inhabited) continent of the Earth" ... 80% complete! Counties: 39 of 39 - done! Countries: 36 of 42; last up, Portugal, next up, Iceland Continents: 5 of 19; last up, North America (USA), next up, Central America (Cuba) |
09-11-2011, 12:37 PM
#6 |
Gear addict
Oddometer: 575
I think Ducksbane summed it up pretty well. I also thought long about the 990 and I still consider changing from my F800 from time to time. If indeed you intend to just keep it stock, you are in for an off road let down with the F800. Unless you ride very mellow stuff the stock F800 needs some upgrades to be really dirt worthy. I would say wheels, suspension, protection, and booster plug (or similar). Also maybe a change in the stock gearing. That said, with these changes, the F800 is indeed quite nice. Weight is still an issue for me any time I get into harder stuff and I wish the bike was another 50-100 lbs lighter. This alone has scared me away from the 990 as I certainly dont want more weight. But I do think the 990 has a better stock suspension so it may indeed feel better if not lighter in the dirt. The maintenence thing also scared me off the 990, although the F800 is not exactly perfect there either. I haven't seriously considered the Tiger as its lower and heavier appears to be less dirt worthy than the F800.
The 990 and the F800 are both cool bikes. IMO : dirt capability (stock) 990 > F800 road capabilty : probably a toss up maintenence (ease of and reliability) F800 > 990 looks : F800 > 990 ![]() The above are of coarse just my totally biased and unscientific impressions so take them for what they are worth. I am sure I would be very happy with a 990, but I have spent enough time and money on my F800 now getting it dialed in the way I like it I am going to stick with it for now.
Dan 2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install Red dirt, rocks and sand; Riding the southern UTBDR Ronin ADV screwed with this post 09-11-2011 at 12:50 PM |
09-11-2011, 04:00 PM
#7 |
Geared up and ready.
Oddometer: 512
Great input all
![]() I was having the same debate awhile ago... I'm going to join the F800GS ranks. The local dealers for the KTM NEVER have anything to test ride unless I buy it first The BMW dealer has always given me a 1.5+ hr test ride (mid week). That alone carries more weight than comparing the two on paper.
Damn I wish all roads were dirt. Current ride : 2011 White F800GS, 9500 km's Past ride : 2006 KLR with 41,000 kms -gone to a good home- Toronto to Maine and back Toronto to Boston -The Long way |
09-11-2011, 05:15 PM
#8 |
Bike-aholic
Oddometer: 2,067
I owned an '04 KTM 950 before going to the F800GS. So, I can tell you exactly how they compare in minute detail. But, let's keep it simple with just the highlights.
If you want to keep it bone stock and plan to do some hardcore offroad riding, then no butts about it.....the KTM is your choice. Its heavy, doesn't turn well, and quite bothersome to work on (removing all the plastic, tanks, etc....to do anything), but its got a good suspension stock, and easy to convert the front end to a high fender. The KTM motor was more exponential in the powerband.....harder to tame and control in the loose stuff. The F800GS is smoother, more linear motor, better fuel mileage, heavy but more nimble with great turning ability, whisper quiet, and a real dream to work on (easy peasy maintenance). But, the stock suspension SUCKS˛ You'll have to drop some serious coin to fix it properly. But after you do.....ooo-la-la....she's pretty sweet. I didn't get along well with my KTM offroad and in the garage. It wasn't the most reliable bike I've owned. I'm loving my F800 in comparison....AFTER bringing it up to my personal specs. Seems like I've bought this bike twice, by now. Probably have. But I'm very pleased with the result. Do wish it had a bit more ground clearance. Sound like you got along well with your KTM, so...... HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 BMW F800GS, '71 Honda CL70 Bergs Over the Rainbow Texas or Bust! BigDog/Highfive--Fall Colors in Missouri 2011 Athena Big Bore Project The Other Side of Nowhere Highfive Goes Dragon Hunting WRRDualsport.com |
09-11-2011, 06:49 PM
#9 |
Oddometer: 2,039
I've ridden both a lot (back to back to back) and I own an F800GS which I bought before the comparisons - never really considered a 990 because I just don't like the looks.
The 990 has quite a bit more power than the F8, and the suspension is certainly stiffer (probably better once you get it dialed in). 990's are bimodal. On some the fuel injection is in the "workable" category and on others it is a nightmare - jerky transition from idle to midrange, stalling, dying as you stop,... The bad ones seem to resist all attempts to fix either at home or at the dealer. I know of two people who have converted from FI to carbs at considerable time and expense. As others have pointed out, the 990 is harder to work on. In fact, when you pull the fairings the wire and other routing looks ad hoc and chaotic. It is like the bike was never really finished by the factory. Even a simple oil change is a lot of work. The FI filters clog very easily, and cost $120 to replace. And on it goes. The F800 is not perfect to be sure, and has had it's share of issues, but at least there was always a light at the end of the tunnel. The 990 is just not ready for prime time IMO.
my favorite bike - R1200GS |
09-12-2011, 04:43 AM
#10 |
Oddometer: 62
When I went to the dealer to test a KTM 990, I got back and said it just felt too much of a dedicated offroad machine (albeit a heavy one!). He then offered me a test ride on a brand new F800GS. I bought the BMW on the spot.
Theres not a day goes by where I don't regret buying the BMW ....BUT I imagine I'd be even more dissatisfied with the KTM. The Beemer is uncomfortable with the stock seat, has a ridiculously tall first gear so hard core offroading is out of the question in stock form which is fine because the suspension is shite for that anyways, the motor rattles more than my dead grannys teeth and it's stupidly overpriced IMHO. No, where the Beemer pics up points is it's ability in town over the KTM and it's astounding fuel mileage. I have 7 bikes - I dislike the Beemer because it cost the most and delivered the least. I'm sure there's people here who swear by 'em but honestly there's no comparison to what you get with a Japanese machine - in quality, performance and value for money. When I bought it, I made my bed and now I'll lie on it....... c'est la vie!
09-12-2011, 05:50 AM
#11 | |
Oddometer: 550
"being alive is a crock of shit" - Kilgore Trout |
09-12-2011, 08:11 AM
#12 |
Oddometer: 1,093
Huh
Walk this on over to the orange crush section and listen.
I will share a few thoughts. I will address a few of the comments and your question. First off- find a dealer that will let you ride a 990. I rode a f800 and 990 multiple times , back to back at the same dealer (grand junction -Harley,BMW,KTM). If I had not rode the 990 I too would have made the mistake (my opinion for myself) of buying the f8. someone who clearly never changed the oil on a 990 said hours for an oil change ? Only 1 hour and that is the first one-then once a year, yes the book says pull the screens every oil change but most people do not-they never have anything in them, for a couple bucks you put a valve and line on your oil tank and thus your oil changes for the most part are nearly as fast (within minutes) as a F8. I own a 650 twin so dont tell me im wrong. Other wise once a year or during the valve adjustment having to pull one side tank is a little more work but 1X a year your bike deserves a good once over. Looks- well if you are buying a bike on looks, then maybe a 61 pan head is the way to go ? Some like to F8 - some like a 990. I personally like both, like the 990 more but, if I bought on looks I would never have gotten into BMWs many years and hundreds of thousands of miles ago. RIDE them both. As far as what you need to do to make it off road ready, KTM side stand - I say yes $100 up grade that needs to be done. F8 needs protection added too. Apples to apples in the want department. Fact: KTM - rally platform bike. Off road it will walk on the F8. Suspension,power, so on & so on. On road still a great bike. BMW F8- dual sport bike, a great bike on the road-milage,soft suspension,gearing-so on. Off road a very capable machine with a great warrantee (if you can get BMW NA to stand behind it-thats another story of a R1200GS) These bikes are in the same category but not really designed on the same platform. Both great bikes. Id say you cant go wrong with either- but I almost did and am very glad I chose the 990. I urge you to ask this on the orange crush side of the world-and do a search first over there-its come up alot. And there are many GS (F8-R1200) guys there. Clearly you owe it to yourself to ride both- think about where you ride or want to ride. And choose what you feel suites you the best-then you made the right decision no matter what I or any one else says. |
09-12-2011, 09:02 AM
#13 | |
Oddometer: 2,039
09-12-2011, 10:43 AM
#14 |
该出手时就出手
Oddometer: 107
I asked myself the same question and the KTM lost on paper.
I have to admit I never rode it. My only option was to buy a used bike and I got a 08 GS for around the same kind of money as a 06 KTM 990. Maintenance intervals and costs are less for the GS, and as I ride more then 12k per year that makes a difference. Plus the GS uses very little fuel, even riding it hard (aside from Motorway). And it does 200 km/h with luggage with ease and without being tiring. The KTM on the other hand as a reputation for weaving above 160 km/h. Wouldn't matter for most, but I have some long high speed commutes to do some times.
Do what you love, and do it often. If you don’t like something, change it. If you don’t like your job, quit. Travel often; getting lost will help you find yourself. Some opportunities only come once; seize them. Life is about the people you meet and the things you create with them, so go out and start creating. Live your dream, and wear your passion. Life is short." |
09-12-2011, 10:53 AM
#15 |
Red Sox Nation
Oddometer: 8,902
Thanks for your thoughtful responses. Once again, I am quite familiar with what a KTM twin delivers since I have had one for almost 7 years.
I rode a KTM 990 SM-T for a hundred miles, and I found it highly refined compared to mine. The motor was silk smooth and didn't notice any fueling issues. I am hoping the Adventure has a similarly tuned motor. Oil changes aren't hard and the plastics come off quickly. My 950 has never left me stranded, so I consider it reasonably reliable. I like the BMW, though, because it has the right wheelset for me and its a little smaller. Also, it's different. If the suspension is softer than my KTM, it may be too soft, but I will be using the bike for travelling, not single track. I have a Yam 250 for more technical riding. I'll try and get a couple test rides lined up. Thanks again. PS: I know what the OC folks will post, because I participate there from time to time. I came here because you ride 800's and I want your first hand opinion.
