Old 12-23-2012, 07:38 AM   #46
jackd
Oddometer: 3,051
Good luck on your new chosen path. I have backpacked through those areas in southern Mexico many years ago and I remember the remoteness of the area. By reading your latest posting, I see that you are a person who doesn't make decisions quickly or without reason. Your maintenance program as described is more than adequate to have trouble free service, in my view.
Personally I would consider your SA/FD service history to have been quite good. 65K out of an original DS is very good service considering they are projected to last for 45K. Mine lasted 46K before it showed signs of failure. I always project forward to consider where my next problems might come from but I don't fret over it - and I suspect that the transmission is where things might start appearing. My GS had a complete failure covered by warranty for the original owner which resulted in the replacement of most of the original internals at 9K and by all the stories that I read here about broken springs and migrating bearings, I watch for debris on my drain plug closely. I hope I haven't jinxed myself by talking about it..... Maybe I shouldn't be saying this but I consider some of the people who post here rather anal (don't start shooting yet folks) and I give the machine the benefit of the doubt. The manner of design/assembly of the BMW is very similar to the aircraft that I maintain and I see weak points in how they are put together and we just increase our maintenance of the suspect systems to get us through these rough spots. Good luck on your modifications.
Old 12-23-2012, 09:29 AM   #47
CptImagine
NCC-1701-B
CptImagine's Avatar
Oddometer: 244
Roger Wilco
Increase the maintainance is the only option . My first gig when I bought the gs was the transmission c-clip . Then 4 piston caliper on front, LED lights, Ohlins and PD tank . I figured all along the 20K servicing mode would be cool, so I began the Mexi winters . 20K maintainance worked on several RS and RT's down thru the years . However in 3 years and 65K, things went away on the gs at around 20K intervals . Then reading in this thread, I come away thinking @ 10,000 miles, grease, the DS . There's entirely too much work involved to hypothetically say make it10K in Cancun, where I have a friend and could work on it .Or where ever you might be, find a safe place to disable the machine . Have enough parts/tools to go back together . I did carry all the brgs and tools for the SA/FD, along with elec. stuff a bean can, parts to repair the crashbar oil cooler, etc . I had a spare Trans,SA,DS and FD in Pa, that DS is now in the mc . DHL is about the only safe way to get parts into Mexico, 3 weeks and big bucks . Unless your in Cancan and can find a sport fishing guy heading there . It was I thought pretty much figuered out . I agree the DS lasting 65K was ammazing . I am not at all anal about my rides, I do perform maintainance at pre determined intervals . Using this one the way I do, unless I start a 10K program . I believe it's only a matter of time til it happens some where I don't wanna be . We will see and thanks for your input .
CptImagine is offline   Reply With Quote
Old 12-23-2012, 12:51 PM   #48
jackd
Oddometer: 3,051
You sound very committed to going back to the older technology to improve serviceability. Just so you know, there was someone here who made a brief appearance claiming to be on the verge of releasing an improvement on the OEM final drive set-up. This would hopefully not be something along the lines of the 'Rubber Chicken' bushings but possibly some beefier bearings to go into that spot. That's the only improvement that I'm looking for on my GS. The final drive, the aftermarket shaft and swingarm bearings are not an issue. Remember, there's a final drive and swing arm bearings on the old bikes as well - the only plus I see is the oil bath for the shaft.
Old 12-23-2012, 04:39 PM   #49
CptImagine
NCC-1701-B
CptImagine's Avatar
Oddometer: 244
I've given that option a lot of though as well
While looking at the FD and SA . The FD bearing is minimal to say the least . The rollers are grossly under sized to handle the loads, without indexing/notching . I doubt the pivot pin diameter could be reduced by 50% . The only option is a larger in every way bearing . That IMO requires build up alumnimum weld in the FD bearing recess areas . Likely inside as well as outside . Then remachining the bearing cavity to accept a larger bearing . Can that happen without modifying the inside of the SA at that point ? Quien Sabe, Who knows ? I in fact think the Rubberchicken bushings are a great carry along n fix item, and about the same price as the mini bearing . I have a pair in the tool kit now, they've been there 3 years . The originals can be beaten out with a muffler chisel , then beat the rubberchicken back in with a socket . I believe a bit more sucessfully than the fragile factory mini bearing that you're trying to keep clean roadside . In 265k on airheads, I never had a swing arm bearing fail, til the gs . I always pumped a shot of grease in the pivot hole @ 20K spline lube . They're in a bottomed hole, put grease in, the pin forces it into the roller area . The gs they say don't even try to lube them . I never had a drivshaft fail, til the gs, never had a final drive bearing fail, til the gs . That along with the less problematic later model gs . Tells me the 93gs era has a design shortfall . That you either accept or retro fit to re atain airhead ridability . The icing on the cake is the mention herein about the 10,000 mile grease the DS routine . This is the first time I ever heard that timeline, alas, it is not going into my program . That sounds like hauling your boat every month to see if the hull is sound . I think I'm heading back in time to a machine I can maintain at 20K intervals . While carrying the known airhead potential problem parts and eliminating others . Starter, lame charging system, shock, and adding efficient lighting . The proof for me was in the $$$$ department . Beyond this, my retirement time is worth more and more cash, every year . The years are running out, loot can be found .
Final drive gs, big $$$$ one ratio . $100 in bearings that will fail . I have 2 to get off .
Final drive mono, a song available in various ratios . 4 bolt replacement no bearings .
Driveshaft gs rebuild or replace $475-$600. Rubber in the middle ??? Treasure it's existance . Deal with too often . Have 2 to get off .
Driveshaft Mono, a song, maybe $200 quoted max, to lengthen, mine has 50K on it . I'm runnin it, no rebuild now . If it craps out then yes . Refer back to the "never had one fail" statement . No rubber in the middle, instead a heavy spring buffer on the end .
Swing arm gs $100 in bearings that will go away . Have 2 to get off .
Swing arm Mono . $50.00 to extend, a retired pipe fitter buddys' on it now . I'm running it with the nice smooth greased bearings that are in it .
The wheel is going to cost some big $$$ I need a rear gs hub, have a couple rims, no hub . Only one stock gs wheel .
Time will tell, the motorcycle is a blast to ride and has done everything I ever tried with it . Good mileage, great on tyres, and so on . However , my patience is taxed every time I deal with it's driveline . Maybe I aged a lot more in the last 3 years than the 55 before that . Or maybe I'm just stuborn, old and hard headed .
Old 12-23-2012, 04:51 PM   #50
brittrunyon
R 100 GS F 650 GS
brittrunyon's Avatar
Oddometer: 527
Originally Posted by jackd View Post
You just gave me an idea. As previously stated, I don't like disturbing my FD bearings (the BMW Dealer parts computer says they are a one use item in the notes section), so hopefully I can leave these alone for another year. What I'm going to do is undo my boots at the front and rear of the swing arm, undo the swing arm bearing pins and slide the swing arm forwards and backwards to access the front and rear u-joints for greasing/inspection. I just might get enough room to get in there. The vibration damper doesn't need looking at yet.
How often do you think the U-joiunts need grease?
Just wondering?
1992 R 100 GS (ZED)
2007 F 650 GS
My Motorcycle Videos & More @ http://vimeo.com/user2721333
Big Bend Ride Report @ http://brittrunyon.com/
brittrunyon is online now   Reply With Quote
Old 12-23-2012, 05:00 PM   #51
jackd
Oddometer: 3,051
Just wondering?
Don't know yet. I'm going in real soon to give it a looksie but I suspect that there is still lots of grease in there from manufacture. I suspect these aftermarket shafts contain bearing cups just like the originals and therefore will retain grease for long periods. It's nice to see that I finally have some info on how to get a re-build kit for it - provided by another member of this forum. I'll ask for some literature when I buy the kit and maybe it will specify service intervals. I'll report back.
Old 12-23-2012, 05:11 PM   #52
jackd
Oddometer: 3,051
Originally Posted by CptImagine View Post
. I never had a drivshaft fail, til the gs, never had a final drive bearing fail, til the gs . That along with the less problematic later model gs . Tells me the 93gs era has a design shortfall . That you either accept or retro fit to re atain airhead ridability . The icing on the cake is the mention herein about the 10,000 mile grease the DS routine . This is the first time I ever heard that timeline, alas, it is not going into my program . That sounds like hauling your boat every month to see if the hull is sound . I think I'm heading back in time to a machine I can maintain at 20K intervals.
Oh I hear you... Maybe it's because of what I do for a living that I have no problem going in and doing the little extra bit that the later models need. I'm right behind you in age by the way.... I'm keeping my baby the way she is until I finish riding (ref: Looking Ahead (Getting older) thread) and then I'll give it to my Son.
Old 12-23-2012, 05:51 PM   #53
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,964
Just wondering?
I know they say 10K, but I feel thats just too short an interval.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 01-08-2013, 03:42 PM   #54
jackd
Oddometer: 3,051
Originally Posted by H96669 View Post
I just had a driveshaft rebuilt by Bruno in Canada.
His recommendations for lube is Synthetic grease, so I just went to the marine shop and bought Amsoil synthetic water resistant.
I had a wander into my local automotive repair shop to drop off my used oil (There's only two small independent shops here and we just lost our last gas station....) I asked him what grease he recommended for u-joints and he came out of the back with this stuff:
https://pennzoil.com/wp-content/uplo...aring-707L.pdf
It's a lithium based grease and the spec sheets says that its good for u-joint installations. I like using Penzoil GL5 gear oil and so I'm going to give this a try. What I'll do is first purge out the old grease so there isn't a compatibility problem with what's in there already. The mechanic described it as a wheel bearing type grease that does good service for them.
Old 01-08-2013, 08:29 PM   #55
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,719
I'll think that any grease is better than no grease. But I'll listen to Bruno on that one, for once I got to buy a synthetic lubricant I think that's a first for me.
Got real busy before Christmas and had to come to work Christmas day, but do have pics of the Amsoil, it is marine rated but also compatible with any lithium based lube. Good enough for a boat....good enough for me.Cheap anyway all things considered, $14.00 for three cartridges at Trotac Marine in Victoria, will last me well into my retirement.
Also waiting on some Guard Dog Moly for other purposes, someone dug the info out and apparently recommended for U-joints. Don't know would have to check the specs for myself before, I know it is a Lithium base.
Still debating the maintenance schedule, will have to remove one of them U-joints just to see what's left in there. Probably all that was put in 12,000 Kms or so ago. Too busy with failing equipment at work to think bikes much. I am calling on the senior engineer too often and feel guilty, after the next steak dinner I guess I could snoop around with him and see what he thinks on greases.
Have tools, will travel!
Old 01-09-2013, 05:54 AM   #56
jackd
Oddometer: 3,051
Maybe if he sees your questions aren't work related, he might be more willing to share his knowledge. That's the way I am these days.
Old 01-09-2013, 09:51 AM   #57
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,719
Then I'll have to show you some of my U-joint pics. Another couple weeks and I should be free.
Can't ask too many questions, we are pretty busy, to the point that I have to fix some of my own stuff. Will be calibrating thermostats all day amongst other things. I owe him already on the nice machining job he did for me, new cone for my wheel balancer but he balked at using brass.
Schnitzel dinner coming up.....nothing is really free.....!
Old 02-14-2013, 05:38 PM   #58
jackd
Oddometer: 3,051
An update. Got down to doing the re-grease on the Emerald shaft today - I thought I'd tell you what I've found.
They must grease the hell out of these things when they build them because there was grease slung all over the swing arm of my GS. I pulled the final drive off for access and installed the fitting in the rear joint - and then I started pumping. I'm going with Penzoil 707L grease so I just kept pumping until all the original grease was expelled. A thicker grease than this would be a problem because the grease follows the path of least resistance and possibly not all of the bearing cups would accept grease and only the ones with the least resistance would get the new lubricant. I had one that seemed not to take any but eventually it too showed signs of co-operating. To do the front u-joint, I undid the front swingarm pivot bolts and slid the swingarm toward the rear to achieve better access. There is a grease fitting already installed in this location pointing straight forward toward the transmission output flange. I didn't feel like undoing my driveshaft forward flange bolts to gain access, so I bought a Lincoln 90 degree grease gun fitting and this allowed me to get onto the fitting with no further disassembly. These bearing cups all took grease easily and no worries for a few more years.
I had a look with a flashlight up the swingarm at the retaining circlip for the flex coupling - all seems well. There is minor fretting where the circlip sits but nothing of real concern. All u-joints are as the day the shaft was built - no wear or signs of distress. All in all, I give the Emerald shaft a thumbs up.
Old 02-14-2013, 08:56 PM   #59
wiggins
Oddometer: 33
Question
Jackd, how many miles do you have on this new driveshaft??? I have purchased the same driveshaft but have not installed it yet???
wiggins is offline   Reply With Quote
Old 02-15-2013, 04:20 AM   #60
jackd
Oddometer: 3,051
6314 miles exactly. I only thought I had around 3500 on it until I checked my records. Probably a very good time to go in and do an initial check. I'll probably buy the re-build kit and have it around for the next time I go in in 3 years.
Times are GMT -7.   It's 05:45 PM.
