Old 09-11-2011, 06:35 PM   #1
henrymartin OP
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,715
Help! Broken bolt
Buddy of mine just paid too much money to a shop to do carb cleaning. Hmm...the thing did not run right. I told him I would look into it, as he was about to leave for a two week trip and was leaving the bike home.
1986 Intruder 700.
He parked it in my garage, I asked him when was the last time the valves were done, and it was at least 15k miles ago.
So, I told him I would do his valves, oil change, air filter changes, synch his carbs...whatever should be done. Both his exhaust/cylinder and coupler gaskets were gone, plus the mid connector pipe had no clamp. I told him I'll look at it.
Took the exhausts off (struggle - seized bolts). Replaced gaskets, fixed the mid pipe, put on a clamp...so far so good. The I started taking the chrome covers off to get to the valve covers. First bolt came out after some struggle. Second came out with some aluminum threads on it (was overtorqued). I started being more careful. Third bolt (front cylinder, right) I took my open-end wrench, pulled a little, and the bolt snapped. The last one came out okay.
So, I had a broken bolt that broke without any effort. It was broken flat with the cylinder fin. I sprayed in some PB blaster, let sit overnight. No room for a good drill to get there, so I took a flexible shaft, drilled a 7/64 hole just deep enough, tapped in screw extractor (spiral), gave a little spin and the sucker broke inside.
I tried taking it out with a diamond coated dremmel bit. and just got a little dimple (no room for the dremmel to be straight)
Took it to a car shop today. We tried welding a nut on it. The easy out came out with the first weld. We welded up the broke bolt, welded a nut on top of that. Five times in a row the sucker broke off. The nuts were red hot from the welding, and it still did not move. But all this heating started to make the aluminum melt around the welds, (just a teeny bit), so I told the shop to stop. The easy out is out, but now the broken bolt has hardened by all the welding. Drill bit just slips on it.
I'm ready to sacrifice the threads and just helicoil it afterwards, but I can't get the bolt out. Heat, PB Blaster, welding, tapping - nothing moves it.
This is the bolt 6mm for the decorative covers, so nothing structural.
What can be done?
Oh, after this experience, I decided not to do the valves. The 6mm valve cocer bolts did not move even with 20ft/lb force, and I'm not comfortable applying any more as i'm afraid they, too, will snap. then the engine would have to come out.
Whoever worked on this bike before really overtorqued stuff, and probably used some sealant.
I tried doing his forks as well, and the bolts in the clamps don't move at all. Also, the shop where he took it for the carbs charged him for new plugs, but they were not replaced. The carb to carb cable is all messed up, and adjusting screws have stripped threads.
Sorry, I guess I'm asking a question and venting at the same time.
henrymartin is offline   Reply With Quote
Old 09-11-2011, 07:00 PM   #2
Benesesso
Benesesso's Avatar
Oddometer: 9,898
First, it's unlikely the broken, non-structural bolt has been hardened by the welding. Do you have a small air compressor? You can buy/rent a small right-angle air tool that will fit in very small places. They spin ~12k RPM. Put a carbide "point" in it and grind that bolt to chips and powder.
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 09-11-2011, 07:02 PM   #3
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,358
Well you have learned the first rule that goes "no good deed goes unpunished". Next time you are doing a freebie, stop when the first effed up screw comes out. Also, in this particular situation there is a chance that a 3/8" impact might work (not a 1/2"!!!) so if you have access to one that next time.
At this point, I'd suggest drilling and tapping a new hole. You can use the cover as a drill guide but be careful while you do it and you should be OK.
GreaseMonkey is offline   Reply With Quote
Old 09-11-2011, 07:11 PM   #4
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 984
Quote: "This is the bolt 6mm for the decorative covers, so nothing structural."
I've had similar problems, and I've simply glued the bolt head in place; provided
that the remaining bolts hold the cover in place. If not a spot of velcro at a good
spot may do the trick...... Too often, as you are finding, attempts at repair can
wind up a lot worse than the original problem.
One of my peeves with working on metric cruisers is all the fake stuff; someplace
under all that is a bike.....
CycleDoc59 is offline   Reply With Quote
Old 09-11-2011, 07:58 PM   #5
henrymartin OP
Mr. Tourguide
Oddometer: 3,715
I'll look for one tomorrow. My local mechanic who has a large body shop did not have one. Sears only had a cordless $90 piece that was too big. The problem I have is that all the local tool shops have been closed for years, leaving behind only Sears, Home Depot, and the like.
That would be nice if I could get there without taking the engine out. I literary have about 2 1/2 inches before I hit the frame. above the hole in question
Well, this particular cover has only two bolts. With one missing, the thing will rattle itself sideways.
First time working on an Intruder, and the last time as well. There is no room to do anything on that bike. Even changing air filters requires moving half of the stuff aside.
Old 09-11-2011, 08:22 PM   #6
Benesesso
Benesesso's Avatar
Oddometer: 9,898
Here you go. Maybe your buddy will pay for it or split the cost.
http://www.searsoutlet.com/1-4-in-Ri...de=buyUsedOnly
Old 09-11-2011, 08:33 PM   #7
henrymartin OP
Mr. Tourguide
Oddometer: 3,715
Thanks. I could probably use this anyway, so I'll look for something like this in the local car parts stores.
Buddy is going to get hit with parts bill only since I did not do what I said I would. Still, those air filters and gaskets for the sucker are expensive.
Old 09-12-2011, 06:55 AM   #8
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,874
The seized up nature of 25 year old fasteners is why our local bike mechanic will not work on bikes over 10-15 years old.
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 09-12-2011, 08:39 AM   #9
henrymartin OP
Mr. Tourguide
Oddometer: 3,715
I've worked on 30 years old bikes that sat in the rain for 20 years, and never, ever, had these issues. Now I have an exhaust flange bolt that feels like is about to give, and I'm afraid...very afraid.
This is beyond seized bolts -- they usually give with heat and/or PB blaster. This thing was red hot and still did not move, soaked in PB, and heated, and still did not give.
There is no amount of money someone could pay me to take the risk of braking every single bolt.
Let's put it this way. A simple 3-4 hrs turned into 20 unpaid hours. I'm taking stripped brass adjuster bolts on carb synch cables, stripped screws on air filters, broken tabs on side covers, clear fuel line without any clamps resting on top of cylinder, flat from melting away, fork bolts that don't move with an impact wrench....
As my body shop friend said yesterday: "I think this bike hates you." I'm beginning to feel the same way.
Old 09-12-2011, 12:41 PM   #10
henrymartin OP
Mr. Tourguide
Oddometer: 3,715
Damn. After looking for a right angle air drill and not finding a small one, I came home with a $129 Milwaukee cordless electric right angle drill, as it was the smallest i could find. I still can't fit into the opening.
I'm ready to blast the damn thing.
I decided against the die grinder as it spins way too fast. I need slow, steady motion not to cause unwanted damage.
Old 09-13-2011, 09:32 AM   #11
henrymartin OP
Mr. Tourguide
Oddometer: 3,715
Finally got it out after boring through the hardened (due to welding) part with a carbide cutter, then driving it through with a larger bit inserted at an angle (as there was no room to stand the flex shaft straight). Got lucky this time.
ten minutes later, an exhaust flange bolt snapped. I drilled it through (there is a small room behind the bolt before you hit the head), sprayed with PB from behind (through the hole I made in the bolt), and have been trying to move it. No success yet. I'm going to try with a short left handed drill bit.
Old 09-13-2011, 10:32 AM   #12
Laromonster
Vesperado !
Laromonster's Avatar
Oddometer: 1,335
try the 50/50 ATF and acetone solution, wicks into threads much better than any spray on stuff
'99 Road king
'09 XR1200
Laromonster is offline   Reply With Quote
Old 09-13-2011, 07:54 PM   #13
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,726
The trick to removing broken bolts is to drill a large enough hole to get your largest extractor in there. Don't get the straight fluted ones, get the tapered ones. Drill hole dead center, use NEW Cobalt drill bits. Drill large enough hole, but not too much as when you use the extractor, it has a tendency to spread out the hole and wedge the broken bolt in tighter. Once the hole is the size you need, use largest extractor and hammer it into the hole, but don't wail on it. Use a cheapo adjustable wrench on the square of the extractor and start to back it out. If it doesn't move, it'll probably need to go to a machine shop or you may break the extractor and feel like hanging yourself by then.
Why the cheapo adjustable wrench? Because it's so cheap any excessive force on the adjustable wrench will cause it to break away. I have one just for this process because it isn't any damn good for anything else. Believe me, i've broken extractors in customer's cylinder head drilling out broken heat treated exhaust studs. Not fun. Why the tapered ones? Because those you can back out and save if the bolt isn't going to come out.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 09-13-2011, 08:31 PM   #14
henrymartin OP
Mr. Tourguide
Oddometer: 3,715
I did use the tapered, spiral extractor in the first bolt, and that's where the extractor broke. High speed carbide cutter took care of that sucker
Anyway, I got the exhaust bolt out. Was not easy, but I managed to save the threads As stated earlier, I drilled a hole through the bolt (there was less than 1/4" room behind the bolt in the cylinder), making sure I had a stop on my drill. Sprayed PB in there, tapped, sprayed again, let sit overnight. Well, the sucker did not move. Not ready to break another extractor in another bolt, I tried using 3/16 left-handed bit. Nope, bit went through and did not bite. Hole was ever so slightly off-center - scream. I took a little punch and started peeling the bolt where it was thinnest, away from the threads (towards the inside), Then, I put mu carbide cutter in the drill, and cut a small groove in the thick part of the bolt (off-center hole, unfortunately), blowing away any shavings with air so i would see where it all went. Just before I reached the aluminum, i stopped, cracked it with a punch, and continued peeling it away as deep as i could. By then, I had about 1/4" deep, clean hole. I put my left handed 1/4 bit in the chuck, and started, ever so slowly, to pull out little chunks of the bolt. Took a while, but it went okay. I did not even have to recut the threads. At first I thought I would have to, but all it took was running an oily bolt in and out twice.
The first thing i did after, was to clean all threads, degrease them, and blow them out with compressed air, run to the hardware store to get some replacement, stainless bolts, cut them into length at home, applied some blue Loctite, and put the exhaust back on.
Old 09-14-2011, 11:45 AM   #15
GreaseGorilla
GreaseGorilla's Avatar
Oddometer: 415
Henrymartin, show your buddy this thread, if he has anything about him at all he will stump up some $$$ for ya........ a garage would have charged him the earth......
GreaseGorilla screwed with this post 09-14-2011 at 11:46 AM Reason: spellingz
GreaseGorilla is offline   Reply With Quote
Times are GMT -7.   It's 05:22 AM.
