Old 03-17-2005, 07:55 AM   #1
Walker Sky Ranch OP
Riderdown.org
Walker Sky Ranch's Avatar
Oddometer: 1,346
Front Fender vs MXtire = room?
Hello Team Thumper, I have the 05-640 and want to put the most agressive mx tire on the front, but I am concerned with the clearance with that shiny new orange rally fender. Has anyone had any expierence with what works? And is there a way to raise that fender if needed?
Les Walker
www.RiderDown.org
http://www.advrider.com/forums/showthread.php?t=304490
The RiderDown Foundation is a non-profit organization dedicated to helping responsible off road motorcyclists and ATV racers who have been injured while riding. Proceeds are used to provide assistance to the riders and their families when faced with medical expenses and related issues.
Walker Sky Ranch is offline   Reply With Quote
Old 03-17-2005, 08:05 AM   #2
Linzi
Crazy Plott Lady
Linzi's Avatar
Oddometer: 15,438
Duct tape.
Glad I could help.
Linzi is offline   Reply With Quote
Old 03-17-2005, 08:22 AM   #3
Walker Sky Ranch OP
Riderdown.org
Oddometer: 1,346
UMMM Duct Tape
Anybody know where I can find the high fender kit for the 640?
Les Walker
www.RiderDown.org
Old 03-17-2005, 09:16 AM   #4
G.Kennedy
G.Kennedy's Avatar
Oddometer: 1,850
Not totally sure, but look into fitting a high front fender from an '03 and earlier. Probably just a matter of calling your local KTM dealer. Creeper will know if its a direct bolt on, maybe some kind of brake line issue.
'00 R1100RT
'05 525EXC
'08 Hypermotard
IBA#11791
G.Kennedy is offline   Reply With Quote
Old 03-17-2005, 09:53 AM   #5
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
I do believe that as it is for all intents and purposes a ninefiddy front end, your best search will be in the ninefiddy forum... lots of LC8 owners that have been tossed on their arses have opted to install a high fender, and some loose the right brake as well.
If all you want to do is raise it up an inch, no one makes a production kit that I am aware of. Shouldn't be to hard to make... just an adaptor. You could do it from split aluminum tubing... cut cut cut, drill drill drill, countersink here and there... and you'll need to get a longer cross-over hose too.
Look in Orange Crush... I'm sure those guys have tried a variety of methods.
Good raising,
Creep
I would be leary of Linzi's method... she didn't specify what color of duct tape, so you know she's full of it.
So... how's tricks?
creeper is offline   Reply With Quote
Old 03-17-2005, 10:05 AM   #6
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Say it ain't so....
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 03-17-2005, 10:06 AM   #7
Linzi
Crazy Plott Lady
Linzi's Avatar
Oddometer: 15,438
Silver, of course... You can't go wrong with Alabama Chrome.
I use black on Mutley 'cause I'm a classy kinda gal.
Old 03-17-2005, 10:41 AM   #8
matey peeps
Bead Buddy
matey peeps's Avatar
Oddometer: 3,326
matey peeps is offline   Reply With Quote
Old 03-17-2005, 03:46 PM   #9
Walker Sky Ranch OP
Riderdown.org
Oddometer: 1,346
KTM-SOMMER makes a high fender for her at 300 dollars.. ouch!
reruns the break lines and all
Les Walker
www.RiderDown.org
Old 03-17-2005, 05:00 PM   #10
Mack
Gone, but never forgotten. RIP, Mack...
Mack's Avatar
Oddometer: 3,797
Just source the parts from KTM directly and save a bunch. I can't really see a downside, on the 950 the rear of the fender has to be modified to allow enough air to pass for cooling, not an issue on a 640.
Some good pics: (950, but it's the same forks you have.)
http://www.advrider.com/forums/showt...ht=high+fender
Mixed search results, but there are a few high fender conversions hidden in here:
http://www.advrider.com/forums/searc...earchid=777172
http://www.advrider.com/forums/searc...earchid=777178
Österreichische Motorräder und deutsche Autos. Wie wundervoll kann das Leben sein
Mack is offline   Reply With Quote
Old 03-17-2005, 06:09 PM   #11
DevDel
DevDel's Avatar
Oddometer: 559
There was an orange LC4E, I think it was a 2000 model. That's how I got a matching orange seat when I converted my SXC to an 18l tank. A friend of mine just converted his LC4 to orange, so I know it's still available.
Being as there were no changes to the LC4 front fender, it should bolt right on. Just check to make sure you have the threaded holes in your lower triple clamp.
It's a good idea to get rid of that low fender. You couldn't shim it enough to save your ass if you find yourself in the mud.
Dev
DevDel is offline   Reply With Quote
Old 03-17-2005, 06:39 PM   #12
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,206
get a local fabricator to make some aluminum spacers - just LOOK at your fender's mounting points and then think "how do i raise this mutha?" and then put the spacers in. the 950 folks been doin it in europe with no problems.
figure out how much clearance you can get with your brake crossover line and then use it - or get a longer line from Motion Pro (custom).
report back when you have done it for the other 49 05-640 folks.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Times are GMT -7.   It's 05:41 AM.
