Old 09-18-2011, 08:36 PM   #16
Jon-Lars
Jon-Lars
Jon-Lars's Avatar
Oddometer: 418
The dimensions are listed on Max BMW's catalog page.
According to them, 3mm.
Cheers, Jon-Lars Sorenson
Beverly, WA
http://www.facebook.com/BMWR90S
Jon-Lars is offline   Reply With Quote
Old 09-18-2011, 08:58 PM   #17
bmweuro
Mad Scientist
bmweuro's Avatar
Oddometer: 2,966
Interesting. Well bigger is better! I do like the seal set up on the later ones as well.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
bmweuro is offline   Reply With Quote
Old 09-19-2011, 01:53 AM   #18
xavier296 OP
European Adventurer
xavier296's Avatar
Oddometer: 274
So, BMWeuro, you used the original sized (larger) bearings of the "big tube" swingarm with the longer (earlier) pivot pins (my question seems redundant, but I am just making sure)?
Also, how do you test a swingarm bearing?
My swingarm bearing and seal setup doesn't really look like any of the ones from the microfiche.
2011 R1200GSA 30th Anniversary
Hard at work on: 79 R100RS
Build Thread: http://advrider.com/forums/showthread.php?t=732078
I welcome any and all couch surfers if you are traveling through Naples. I even have a well stocked garage for emergent repairs.
xavier296 is offline   Reply With Quote
Old 09-19-2011, 03:14 AM   #19
bmweuro
Mad Scientist
bmweuro's Avatar
Oddometer: 2,966
I did use the wider bearing and the early shorter pivots. I got everything adjusted and torqued down tonight ans ran the swing arm through it's travel and it worked great
I removed the bearing and the race, Cleaned everything very well and did a visual inspection.
The info from the fishe sucks. I ordered a bunch up parts and most turned out to be wrong. The seal let up has seals that you can clean and reuse.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 10-23-2012, 11:37 PM   #20
brocktoon
brocktoon's Avatar
Oddometer: 165
THREAD, RESURRECT!
So, a year on:
For those that have done the big tube conversion, have any issues arisen using the earlier style bearing, spacer, seal and pivot pin setup? I have a big tube swing arm for my /5 coming back from the powder coater on Thursday. Like others, I'm loath to kick down an extra $130+ for the exotic bearing setup. Is performance the only thing lost from using the earlier bearing setup?
brocktoon is offline   Reply With Quote
Old 10-24-2012, 12:31 AM   #21
ME 109
ME 109's Avatar
Oddometer: 611
I just put NTN 32203 bearings in my big swing arm.
They are 40 x 17 x 17.25 basically the same size as oe.
I was able to use the original outer dirt seal from the previous bearings. It isn't a perfect seal, but at least the bearings can now be greased via the pivot bolts.
How much of an issue is greasing the bearings?......perhaps not too much as my bearings were 31 years old. They were stuffed, but still quite serviceable.
Lord of the Bings
ME 109 is online now   Reply With Quote
Old 10-24-2012, 06:18 AM   #22
Airhead Wrangler
More tacos than you
Airhead Wrangler's Avatar
Oddometer: 5,114
I'd consider it a yearly maintenance item unless you ride in the rain or off road a LOT. It's probably not necessary yearly, but with a grease gun and the right tip it's a 5 minute affair, so why not? Just pump grease through the pivot pins until you see clean new grease coming out past the seals. Wipe up what came out and you're done.
R80ST Gets The HPN Treatment
Ducati Pantah 500SL Rebuild
Seattle to TDF on an airhead
WTB R100R Mystic sidestand and mount.
Old 10-24-2012, 09:13 AM   #23
brocktoon
brocktoon's Avatar
Oddometer: 165
So with 32203 bearing did you use the earlier pivot bolts and/or spacer?
I was also curious about people who've tried the 30203 bearings, which seem to be the most readily available (read: cheap)
Old 10-24-2012, 11:29 AM   #24
supershaft
because I can
Oddometer: 6,076
It's been a while but I believe it is the inner race that is longer. I have had trusted reports that they do make a difference. I did the front axle trick on my LS and I am sure it made a difference. All the little stuff adds up. (You machine the big part of the axle back so that both sides of the other slider pinch on the axle versus just one side of it.)
Personally, I wouldn't worry about that drive shaft spring. Sure they rarely fail but so does everything. Of course, the solid ones are lighter! I have seen the spring in the transmission fail at least five to one more times. I think that's what the spring on the drive shaft is suppose to be saving. They beefed the trannies up a lot there around '86? Good luck!
supershaft screwed with this post 10-24-2012 at 12:00 PM
Old 10-24-2012, 01:38 PM   #25
ME 109
ME 109's Avatar
Oddometer: 611
I could never work out how to get the seals/bearing out. Mind you I don't recall asking either. The seals are basically levered off. Anyway, that prevented me from properly greasing the bearings on the few occasions that the swing arm has been out of the bike.
Now, it is a five minute job to grease them.
The swing arm bearing from bmw is wider than a standard30203
30203 outer race is approx 10.5mm. Inner race I'm not sure as I threw it out.
bmw swing arm bearing with fitted seals outer race is approx 13.5 from memory. It is wider because it has a groove which holds the inner race cage in place.
The inner race on the bmw bearing is wider @ 17.25mm. The roller bearings are the same, but the inner part which holds the rollers is longer, so as to also hold the seals....
Good opportunity for a photo...
I used the original pins from my bike as the NTN bearings are the same physical size as oe. No need to change pins, and no spacers needed.
If a standard 30203 is used to replace the oe bmw bearing, a 3mm approx spacer is needed to make it the same width as oe.
The spacer will need to have a 17mm id. The pin will pre-load? on this spacer so a sloppy fit (17.5mm or so) will be unsatisfactory.
Lord of the Bings
ME 109 screwed with this post 10-24-2012 at 01:50 PM
Old 10-24-2012, 02:06 PM   #26
bmweuro
Mad Scientist
bmweuro's Avatar
Oddometer: 2,966
Originally Posted by brocktoon View Post
THREAD, RESURRECT!
So, a year on:
What are you doing for the rear brake switch?
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 10-24-2012, 02:25 PM   #27
brocktoon
brocktoon's Avatar
Oddometer: 165
I have a large maglite with a red theater gel lens that I can shine over my shoulder when braking.
No, I found the rear brake conversion tutorial on your website and plan on putting in an order with you for the spacer you mention (though I don't see it on your website).
Old 10-24-2012, 03:14 PM   #28
bmweuro
Mad Scientist
bmweuro's Avatar
Oddometer: 2,966
Sorry about that Rear Brake Switch Cap
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 10-24-2012, 03:37 PM   #29
Airhead Wrangler
More tacos than you
Oddometer: 5,114
Oh wait. I forgot which swingarms have closed off ends where the bearing seats are and some don't. Some swingarms you can just pump grease through the pins until it oozes out past the seals. Others are open on the inboard side of the bearing, so you can't grease them that way. Check yours before you pump your swingarm full of grease.
Old 10-24-2012, 06:44 PM   #30
ME 109
ME 109's Avatar
Oddometer: 611
All good for greasing on my swing arm. Driveshaft side is closed off, and the other side has an oe tin plate that sits under the bearing, effectively closing off that side as well.
Lord of the Bings
Times are GMT -7.   It's 11:11 PM.
