Old 09-22-2011, 02:54 PM   #1
Dieselboy OP
Journey not Destination
Dieselboy's Avatar
Oddometer: 1,161
D.I.Y. Cam Chain Replacement
EDIT: See Page 4, POST 56 to get to the beginning of actual tear down.
EDIT: See Page 10, POST 141: chadams has a master link solution in progress.
EDIT: See Page 11, POST 161: Joelwisman offers tech insight to cam chain stretch.
So tech says chain is stretched slightly.
No measurement but I trust the eval. She’s running rough and does have a chatter at idle when hot.
What to do? Well, Joel says its an 8 hour job. I’ll give a 24:1 transposition and give it a whirl.
I have the maintenance DVD. (Haven’t looked at it yet.) I ordered the Haynes Manual yesterday.
Parts went on order today:
Item Part Quantity Part Number Cost
3 GASKET RIGHT 1 11147670688 $15.00
ENGINE RIGHT
1
7 Gasket set, cylinder 1 11128520621 $68.97
head cover
VALVE COVER
2
6 GEAR WHEEL 2 11317708198 $42.01 EDIT: DID NOT NEED THE GEARS.
8 GUIDE RAIL 1 11317690494 $7.74
11 TIMING CHAIN 1 11317690475 $84.39
12 CHAIN TENSIONER 1 11317690493 $10.80
7 Bearing screw 1 11317676592 $4.98 EDIT: REUSED OLD SCREW.
TIMING GEAR
3
1 GASKET LEFT 1 11117707906 $24.10
ENGINE LEFT
4
07 Gasket, oil pan 1 11117707905 $28.93
OIL PAN
5
Plus a tube of sealant.
I have torque wrenches. I have a garage. I have stayed at Holiday Inn Express this month....What am I missing?
EDIT: I reused all the old seals and o-rings but I should have also orded:
exhaust header flange gaskets
cam sensor o-ring
coolant lines o-rings
valve cover o-rings
out put shaft seal for counter sprocket
shaft seal for gear shift
Dieselboy
The Adventure Continues
Dieselboy screwed with this post 08-28-2013 at 07:03 PM
Dieselboy is offline   Reply With Quote
Old 09-22-2011, 04:12 PM   #2
Camel ADV
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,483
Will be watching closely as mine's making more and more noise all the time.
Camel Tank auxiliary fuel tank for F series BMW twins. www.Camel-ADV.com
AT-BZ-CA-CN-CO-CR-CZ-CH-FR-DE-GB-GT-HN-IE-JP-KZ-KR-LI-LU-MX-NL-NI-PL-RU-SV-UA-US
'09 BMW F800GS, '14 KTM 1190 ADV-R
Camel ADV is offline   Reply With Quote
Old 09-22-2011, 04:27 PM   #3
trizzo
Oddometer: 207
any possibility you can take pics of the project and caption the process?
trizzo is offline   Reply With Quote
Old 09-22-2011, 04:37 PM   #4
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,161
I plan to. Unless of course I screw it up then I'll disavow all knowledge of the event....
Dieselboy
Old 09-22-2011, 04:44 PM   #5
Rafiki
Some Dude
Rafiki's Avatar
Oddometer: 1,878
Step by Glorious step.
with photos.
good and bad.
and don't forget the beer.
'94 XR650L ΜΟΛΩΝ ΛΑΒΕ
"Monkey killing Monkey over pieces of ground.
Silly monkeys give them thumbs.
They make a club, And beat their brother down."
Rafiki is offline   Reply With Quote
Old 09-22-2011, 04:57 PM   #6
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,588
This could be really interesting...
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is online now   Reply With Quote
Old 09-22-2011, 05:01 PM   #7
tkent02
Oddometer: 2,604
What to do?
Just curious, what is the mileage on this engine? Is the chain worm beyond the limits that the tensioner can compensate for?
Is there a problem with your tensioner, too?
Cam chains in Cheap Japanese Motorcycles used to run fine for 100,000 miles and more.
But then again so did wheel bearings.
tkent02 is offline   Reply With Quote
Old 09-22-2011, 05:27 PM   #8
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,161
92,000miles
Yes
Yes. Tensioner was bad. It has been replaced. (34,000 & 88,000) Suspect this was the root cause of the cam chain stretch.
Ich verstehe nicht
Dieselboy
Old 09-22-2011, 05:36 PM   #9
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,161
I had toyed with the idea of contacting BMW NA and offering a high-mileage GS for QA historical data . But.....I'd rather be riding and I want this chain fixed so I can get back to it.
Dieselboy
Old 09-22-2011, 06:45 PM   #10
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,588
Have you heard anything about a new design a CAM chain tensioners? How hard are they to replace? Symptoms of the tensioner going bad? How many fibers in a shredded wheat biscuit?
Sorry for the questions, just curious.
Semper Fi
Old 09-22-2011, 07:05 PM   #11
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,161
No
The current one just screws into place. No fuss. [EDIT: I did reload it with oil prior to install.]
African or European?
Dieselboy
Dieselboy screwed with this post 10-14-2011 at 02:12 AM
Old 09-22-2011, 09:05 PM   #12
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,588
No
Huh, I wonder if replacing the tensioner every 20k or so miles would be good preventative maintenance....
Semper Fi
Old 09-23-2011, 03:09 AM   #13
LukasM
Oddometer: 5,426
Damn Nick, I didn't know you had THAT many miles on it!
Is there any reason why it wouldn't be possible to replace the chain without taking the whole engine apart, e.g. split it and put in a master link? I would think that there is nothing unique about the BMW chain, so it would be a matter of finding an industrial supplier that can match the pitch, roller diameter etc. Or maybe from another bike?
Cheers,
Lukas
PS: Stator has been rebuilt and is now on the way to me. Cost $165 + shipping so not too bad. I will post some pics so we can see the quality and compare it to the Electrosport offering.
Old 09-23-2011, 04:42 AM   #14
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,161
Yeah, I get that a lot. What can I say, I like the bike.
Because the OEM chain is continuous, the engine must be cracked to install a new one. While I did consider trying to find a master link solution, the additional problem is internal wear on the guides. If you look at the pics (Timing Gear #12 & 17), the guide rail and tensioner are likely worn and must be inspected. Since I'm in there anyway, I'll just replace them. Plus, I don't like being the crash test dummy in the master link conversation even if I could find one.
Glad that appears to have worked out. Keep us informed. I have a feeling more will be needed.
Dieselboy
Old 09-23-2011, 04:46 AM   #15
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,161
Lost Rider actually commented that this might be a good idea every 30,000. Until this widget gets re-engineered, I think that will be my new policy.
Dieselboy
Times are GMT -7.   It's 02:16 PM.
