09-25-2011, 09:04 PM
#1 |
Oddometer: 1,244
Stripped thread in aluminum engine block...
I was in the process of installing front tip-over bars today on my old Concours. I've had these bars laying around since January.
As I was tightening the bottom left mounting bracket (the bolt goes into the radiator mounting bracket), with the torque wrench set at 35 ft-lbs (instructions for tip over bars say 30-40), of course, the aluminum engine block threads got stripped. I am now unable to screw anything into that hole now, even the original, shorter bolt. The thread in the engine block is fucked. Is there anything that can be done now? How does one go about rethreading a stripped hole in an aluminum engine block, if this is even possible? Is it possible to do something without having to rethread? God I hate wrenching. |
09-25-2011, 09:09 PM
#2 |
Do you ADV
Oddometer: 668
I would go for a helicoil. Ive had good success with them in the past.
09-25-2011, 09:16 PM
#3 |
Mr. Tourguide
Oddometer: 2,552
Helicoil OR finding a SAE bolt that is just enough larger in dia, then threading the hole for SAE bolt.
I did this with a drainplug on a motor once. 12mm bolt was stripped (PO), and I did not feel like doing the helicoil route. A 1/2" thread is just enough larger to allow for new threads, and small enough not to have to drill or cause any structural issues. Now, I don't know what size metric is the thread now, but I imagine there is something pretty close to it.
My motorcycle projects blog My Goodreads Profile This is what I do when I'm not here! |
09-25-2011, 09:20 PM
#4 | |
Oddometer: 1,244
09-25-2011, 09:25 PM
#5 |
Oddometer: 6,915
I did the same thing. Fortunately, the threads are not in the engine, they are in the radiator support. The TO bar instructions shouldn't say 40 ft-lbs for those fasteners, 'cause the threads in the radiator support can't hold that much. It would help if the factory service manual specified a torque for those bolts, but it doesn't. To fix it, get a bolt that's a little longer and a matching nut and sandwich the radiator support to hold it and the TO bar to the engine.
09-25-2011, 09:35 PM
#6 | |
Oddometer: 1,244
Good idea, I'll be dropping by Home Depot and Auto Parts store tomorrow to explore both options. THanks. |
09-25-2011, 09:39 PM
#7 | |
Rhymes w/piecejunkie
Location: The only county in Illinois with no train tracks
Oddometer: 4,765
They do have a specific purpose, but I cannot figure out the fascination with helicoils. Basically, you have to drill and tap a hole bigger, then add an extra part that can fail, then reinstall the screw. Why not re-tap the hole and just use a bigger bolt in most cases.
Grow a WW1 Victory Garden this year! |
09-25-2011, 09:48 PM
#8 | |
Do you ADV
Oddometer: 668
09-25-2011, 09:49 PM
#9 | |
Mr. Tourguide
Oddometer: 2,552
NOOOOOO! Never. You got the concept right, but I would tap for the SAE bolt. Never force a bolt into aluminum case to cut its own thread. Please. GreaseMonkey hit it head on.
09-25-2011, 09:50 PM
#10 |
Oddometer: 670
"The object of life is not to be on the side of the majority but to escape finding oneself in the ranks of the insane." Marcus Aurelius, Emperor |
09-26-2011, 03:15 AM
#11 |
WFO for 41 years
Oddometer: 3,995
+1 Helicoil is the answer.....
Too much is just barely enough..... 2007 Tiger 1050 2005 Royal Star Tour DeLuxe 1973 Yamaha TX750 1974 Norton 850 Commando Roadster |
09-26-2011, 08:18 PM
#12 |
MOmymamamamaMOmymama
Oddometer: 1,489
The helicoil is the only proper fix. Done correctly you will have a stronger, more reliable thread than the factory threaded aluminum.
Caution: NO DISCLAIMER! |
09-26-2011, 08:40 PM
#13 | |
Oddometer: 173
Have to take issue with the statement that a Helicoil is the only proper fix. There are competing products such as Timeserts that are just as good or better. Bob |
09-26-2011, 09:17 PM
#14 |
Oddometer: 365
ts is best
Timesert beats hc every time.
09-26-2011, 10:32 PM
#15 |
Oddometer: 6,915
I'm sure both products are fine, but the OP misunderstood which threads were pulled out of what and there isn't enough meat to do thread repair. The threaded part of the assembly he's talking about is a steel stamping (~14ga) with maybe three threads in it. It's supposed to steady the bottom end of the radiator, not carry any kind of a load. The longer bolt with a nut is the way to repair this, unless you want to disassemble the bike and weld a nut on the back side of the tab.
