Old 10-31-2011, 01:38 AM   #31
DRjoe
DRjoe's Avatar
Oddometer: 5,117
if he puts the triple clamps on backwards he'll get more trail than he can shake a stick at, That should sort any stability problems just wont go round corners very well
Old 10-31-2011, 05:08 AM   #32
God of Speed OP
brrraaaaAAAAAAAP
God of Speed's Avatar
Oddometer: 1,103
not sure either, but if need be during testing we can just slide the yokes up, or smaller rear wheel or lower rear ride height.
point is theres alot more to worry about before then. high speed tyres, full exhaust and radiator hoses to be made. mild tune of the carb at least so it runs.
in other news, the dash is looking good!
thats the starter on the left, and ignition on the right. simple.
the map 1-2 switch, lanyard and kill switch are on the bars.
- Charlie
125cc Salt Racer - God of Speed Thread
'Overall happiness is directly proportional to the increasing distance between the front wheel and the ground.'
'85 XL600R-L-M-PDGSAZ
God of Speed screwed with this post 02-12-2015 at 06:51 PM
God of Speed is offline   Reply With Quote
Old 10-31-2011, 05:14 AM   #33
God of Speed OP
brrraaaaAAAAAAAP
Oddometer: 1,103
http://ic1.maxabout.us/autos/tw_indi...a-9-yzf-r1.jpg
thats a pretty steep steering angle..........
- Charlie
Old 10-31-2011, 05:30 AM   #34
DRjoe
DRjoe's Avatar
Oddometer: 5,117
Yea but whats its trail compared to yours?
Old 11-01-2011, 12:54 AM   #35
God of Speed OP
brrraaaaAAAAAAAP
Oddometer: 1,103
looking better every day
im starting to think if i spent more time actually working on it instead of lining it up for pictures, it would be done by now.............
- Charlie
God of Speed screwed with this post 02-12-2015 at 06:52 PM
Old 11-14-2011, 11:28 PM   #36
FatBoyCrash
Buckle up SpankY!!
FatBoyCrash's Avatar
Oddometer: 1,129
Update???
Built In Shed
Because chrome don't get ya home.
FatBoyCrash is offline   Reply With Quote
Old 11-14-2011, 11:32 PM   #37
God of Speed OP
brrraaaaAAAAAAAP
Oddometer: 1,103
sorry guys,
electrics are done
first exhaust is done
seat is done
engine mounts are done
cooling system done
we turned the engine over for the first time today, and will be starting it tomorrow when i get some fluids.
i will need to make a tank that fits inside the frame, is 2-3 litres and lets me tuck my knees up aswell. until then we just have a small atv tank i got from work.
- Charlie
God of Speed screwed with this post 02-12-2015 at 06:53 PM
Old 11-18-2011, 06:06 AM   #38
Speedzter
Speedzter's Avatar
Oddometer: 681
Originally Posted by God of Speed View Post
what do you guys think of the length of the manifold we made?
Not sure about the inlet manifold length, but I would make a shorter one as well for Dyno testing. I'm not happy with the angle of the float bowl though.
Also a 40mm Carb may be too big for that motor ? On what basis did you choose it ?
A 40mm Flatslide will suport around 100hp. A 34mm would give you better air speed.
Getting closer though. Good luck with it.
'03 KTM950 ADV'
Speedzter screwed with this post 11-18-2011 at 06:14 AM
Speedzter is offline   Reply With Quote
Old 11-18-2011, 07:45 AM   #39
God of Speed OP
brrraaaaAAAAAAAP
Oddometer: 1,103
float bowl is at a better angle when the engine is in the frame, it is also from a cr250r so designed to operate on angles.
38mm is a standard upgrade from the 28mm carb, and some of the girls on the aprilia forum suggested to go even bigger than 40mm.
the manifold was tricky, as we needed to forge it to go from the round carb to the square reedblock, so im hoping it will be ok as making a new one will be a downright pain.
- Charlie
Old 11-18-2011, 03:26 PM   #40
Speedzter
Speedzter's Avatar
Oddometer: 681
Yes, the round to square transition would be hard to make by hand.
The other thing to try that would be easy enough is a variable length intake bell mouth. Are you running the original expansion chamber ?
What sort of HP to weight ratio are you hoping for ?
'03 KTM950 ADV'
Old 11-19-2011, 12:27 AM   #41
God of Speed OP
brrraaaaAAAAAAAP
Oddometer: 1,103
the original expansion chamber is a dog, already got a JM aftermarket pipe but for our specific high-revving and non-stock carb we will need a full custom one made up aswell.
looking for 40ish hp but just happy with 38 or so. for this year i am not going overboard on engine development, more chassis and aero.
but 40hp, on a bike that weighs 65kgs + 70kg rider = 300hp/tonne.
- Charlie
Old 11-19-2011, 12:29 AM   #42
God of Speed OP
brrraaaaAAAAAAAP
Oddometer: 1,103
PS
i had originally planned to make a variable intake manifold but we already have so many parameters for tuning with the exhaust, fully programmable ignition and options for piston, head and cylinder, i didnt think it was necessary and just added alot of complexity for not much gain.
- Charlie
Old 11-19-2011, 12:48 AM   #43
spotcom
Watch This Space
spotcom's Avatar
Oddometer: 43
Love this project. Subscribed, and keen to see how this baby goes!
spotcom is offline   Reply With Quote
Old 12-02-2011, 10:29 PM   #44
God of Speed OP
brrraaaaAAAAAAAP
Oddometer: 1,103
here is a video of the first engine start
http://www.youtube.com/watch?v=Frb5YW5hT6Q
- Charlie
Old 12-02-2011, 10:39 PM   #45
God of Speed OP
brrraaaaAAAAAAAP
Oddometer: 1,103
so ive been pretty busy, the build is done, aswell as a rough carb tune, the engine is running well now with responsiveness and good idling, which is surprising as i havent even changed the stock jetting from the mikuni tmx40 carb which was meant for a cr250r.
i will put a chain on it this weekend and see how it handles going around the block in the next few days.
- Charlie
God of Speed screwed with this post 02-12-2015 at 06:48 PM
Times are GMT -7.   It's 06:01 PM.
