Old 09-14-2012, 02:24 PM   #286
bdjuju
Should be wrenching
bdjuju's Avatar
Oddometer: 51
Bike looks great!
Did you make a mold for that airbox cover, or is it a one-off?
Thanks for wearing pants this time.
bdjuju is offline   Reply With Quote
Old 09-14-2012, 07:27 PM   #287
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,817
Originally Posted by bdjuju View Post
Bike looks great!
One off.
And youre welcome
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
sailah is online now   Reply With Quote
Old 09-16-2012, 02:24 PM   #288
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,817
Just weighed the bike. Front is 175, rear is 189 so 364 total
Bike has the fuel tank absolutely pressed, full of coolant oil etc.
I have a few ideas to drop a few more lbs but in reality will add it back with a damper and hand guards. Pretty happy with those numbers and pretty close to what I thought backing out the weight of the fuel id be right at 350
There are some steel brackets for the original linkage that I haven't removed yet should get another couple lbs
Nessmuk
sailah screwed with this post 09-16-2012 at 02:29 PM
Old 09-16-2012, 05:52 PM   #289
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,182
Very good numbers on the weight.
Hoping for 390 pounds on the Bandit, but the motor is a pretty big lump compared to your CBR.
Old 09-17-2012, 10:26 AM   #290
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,817
Threw on the sumo wheels, after an unreal time getting the slicks off and the new battalax s20 mounted. I have almost zero swingarm clearance might need to shave the tire slightly.
Nessmuk
Old 09-17-2012, 10:36 AM   #291
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,182
What size is the rear?
I have a 150 street tire I want to run on the Bandit.
Old 09-17-2012, 11:33 AM   #292
TerraRoot
Oddometer: 61
congrats on getting it moving, hope the nervous front end feeling is just down to the knobblie tyre on the the street.
i was just showing my dad your vid earlier on today, and i had to go back through the thread to find the shot of it with the sumo setup, (gonna do the same to my cbr after another project) and there you go posting a new shot just after i get home!
btw i think the oil cooled bandit engines are about 80kilos, cbr 65kg.
TerraRoot screwed with this post 09-17-2012 at 11:40 AM
TerraRoot is offline   Reply With Quote
Old 09-17-2012, 11:40 AM   #293
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,817
160 60 17
I think if I shave the sharp corner I'll be fine but next tire I'll go to 150. The rim is 5" wide though, and it's a factory ktm wheel. Maybe 150 is the way to go.
Nessmuk
Old 09-17-2012, 11:42 AM   #294
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,817
The front end was due to lack of bearing preload. All better now
It's about as light as I would want, the compactness is awesome
Nessmuk
Old 09-18-2012, 02:07 AM   #295
LukasM
Oddometer: 5,427
Beware that some tires are wider than others, but in general a 150 is too narrow for a 5" rim to handle well. The SM guys are modding the same swingarm that you have to fit with a 5.4" (Marchesini) or 5.5" rim and 165-175 slicks. There is a guy on SMJ who does it for a fee, rpugh (?).
Since you like to cut and weld you could try it yourself.....
Old 09-18-2012, 08:01 AM   #296
mousitsas
mousitsas's Avatar
Oddometer: 2,992
I have an 150 Anakee tyre fitted on a 5.0/17 rim. Apart from the fact that you need tie downs to seal the tyre and inflate it (my rim is tubeless) the bike handles very very well. But I suspect the overall width is dictated by rim width as well as tyre, so a 150 might be equally wide on your rim.
Old 09-18-2012, 08:17 AM   #297
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,817
Lukas,
Cool idea but I'm not sure I want to modify the swingarm, maybe I might try another tire as they do vary between manufacturers. Most of the time I expect the bike will be dressed for dirt and those tires fit. If I shave the sharp corner I cab probably get another 1/4"
Mousitas, maybe thats the tire to run next time they do have a lot of grip. Are you using the same swingarm? How did you seal your rims? I like the idea on these tires to do that
Nessmuk
Old 09-18-2012, 09:27 AM   #298
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,574
Depending on how much you feel like investing, you could probably lace up a narrower hoop that would fit the 150.
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Old 09-18-2012, 02:03 PM   #299
TerraRoot
Oddometer: 61
try a differnt tyre? i got a dunlop (not sure what, too late to go out an check right now) 160 on my 4.5" f2 rim
it is really small compared to the pilot road ct2 i normally use.
Old 09-18-2012, 03:10 PM   #300
Bambi
Bambi's Avatar
Oddometer: 722
Hi Sailah,
doesn't the tyre shave itself on the run?
Sorry, not quite serious!
Kind regards, Bambi ... waiting to relive the old camp-fires in Germany, you remember?
'Find me kindness, find me beauty, find me truth ...'
(Dreamtheater, Learning to live)
Bambi is offline   Reply With Quote
Times are GMT -7.   It's 05:33 AM.
