Go Back   ADVrider > Riding > Regional forums > Canada
Old 10-26-2011, 10:31 AM   #91
windquest OP
windquest's Avatar
Oddometer: 574
Originally Posted by El Birdo View Post
Nice work on the tanks, my concern safety wise would be the exhaust heating up the aluminum tank and gasoline inside it. Would the fuel have to be siphoned out?
I'm excited about the WR, there's two in BC for $4800. Low km. Maybe we should get three from the states.
Don't worry about the heat. There will be a gap of min. 1/2" between the tank and the muffler. The heat transfer from conduction & convection will be negligible. Heat transfer due to radiation will be low, however I would put heat reflective tape on the tank to reflect the majority of heat coming off the muffler. Even without the tape the tank would only become warm to the touch, like if it sat outside in the sun... As for getting the fuel out I heard that CJ Designs has a aluminum filler neck that mates to a vented KTM fuel cap. That's how they will be filled. I noticed that the 4.75gallon IMS tank has a bung on each wing bottom where the vacuum hoses attach to get the fuel out of the wings to the main pump. I plan on tapping into these, therefor eliminating the need to siphon also the tanks will drain evenly then allowing for a more balanced ride while the tanks start to drain...
I'm pumped about the wr too, only shitty thing is I have to sell the xr650r first to fund the wr purchase. I like your idea about a us purchase, probably would only be worth it if we do 3 at once... I was planning on getting a wr250x, they tend to sell for less , plus they come standard with a bigger front brake which I really like, then I can either build a 21/18 combo off those hubs or keep or sell the wheelset and build a dirt set.
windquest screwed with this post 10-27-2011 at 02:10 PM
windquest is offline   Reply With Quote
Old 10-27-2011, 06:35 PM   #92
AtlasExp
beer me
AtlasExp's Avatar
Oddometer: 448
Test
http://www.advrider.com/forums/showt...239330&page=64 Testing on the lake!
AtlasExp is offline   Reply With Quote
Old 10-28-2011, 08:50 AM   #93
HighwayChile
greetings from Wa state
HighwayChile's Avatar
Oddometer: 4,404
check this extra tank, cheap, fast.
http://advrider.com/forums/showthread.php?t=735589
or look at one of acerbis side tanks , you may be able to modify one. they also make a number plate tank that may be mounted on side racks with mods.
I would rather wake up in the middle of nowhere than in any city on earth. .....Steve McQueen
HighwayChile is offline   Reply With Quote
Old 10-30-2011, 10:21 PM   #94
windquest OP
windquest's Avatar
Oddometer: 574
more inspiration for the Trans-Canol 2014
Photos from Ryan Murdock hike across part of the canol.
Trans-Canol 2014ish
Old 10-31-2011, 01:27 PM   #95
El Birdo
El Birdo's Avatar
Oddometer: 908
Thank you.
Riding something on two wheels
El Birdo is offline   Reply With Quote
Old 11-02-2011, 07:30 AM   #96
El Birdo
El Birdo's Avatar
Oddometer: 908
Fuel Tanks
Although the tanks you are suggesting/designing would be super cool I'm wondering if the attached fuel tanks might pose a problem if say were stuck in a boogy section and needed to unload stuff to get it out. If the tanks are easily removable we could potentially walk our gear 1km or so then get the lighter bikes unstuck with less effort. I'm also wondering how much of a mud collector it will be in a boggy situation.
I've been stuck in that situation before and glad I could unload.
Old 11-02-2011, 08:04 AM   #97
windquest OP
windquest's Avatar
Oddometer: 574
Great points!
Excellent question, the tanks would be attached in 3 points and would certainly be quick and easy to detach them. They will also each have they're own fuel shut off valve so removing them from the whole system is as easy as a flip of a petcock. As for making the bikes easier to handle I will also implement built in handles onto the top sides of the tanks like some rally bikes. While the tanks are attached this will greatly help with lifting or dragging. I don't see them collecting mud anymore then what would already attached to a bike...
Trans-Canol 2014ish
windquest screwed with this post 11-02-2011 at 08:56 AM
Old 11-02-2011, 01:46 PM   #98
OurBC
Live to Travel
OurBC's Avatar
Oddometer: 437
Wikipedia
Really enjoy this thread, here is a another good link http://en.wikipedia.org/wiki/Canol_Road
OurBC is offline   Reply With Quote
Old 11-03-2011, 08:44 AM   #99
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,078
LINK
Look forward to adding pics and info from your future expedition
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 11-03-2011, 06:58 PM   #100
El Birdo
El Birdo's Avatar
Oddometer: 908
Originally Posted by Deadly99 View Post
LINK
I was hoping you were going to say that
Old 11-04-2011, 02:29 AM   #101
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,078
If all goes to plan I may have a poke at the trail next Sept
Roaming Rally 2015
Old 11-05-2011, 09:30 AM   #102
drbike
drbike's Avatar
Oddometer: 271
After reading some of those logs and reports, I am getting the urge. Looks totally amazing. The land seems OK but the river crossings seem like it could be a major issue. I am hooked on this thread.....
drbike is offline   Reply With Quote
Old 11-05-2011, 10:55 PM   #103
OurBC
Live to Travel
OurBC's Avatar
Oddometer: 437
Canol Road Song
Canol Road song by Stan Rogers http://www.youtube.com/watch?v=w0htgidWbtc
Old 11-06-2011, 09:46 AM   #104
El Birdo
El Birdo's Avatar
Oddometer: 908
I love it! Sounds Gordon Lightfootish but more electric
Old 11-07-2011, 05:09 PM   #105
aquadog
Dude Buddha
Oddometer: 654
Ah, but you're not seeing photos of the bogs or boulder fields. The photo with the overhead bent pipe in it hints at some of the lumpy areas to bounce over. And some sidehills where the trail has been eroded by a river. Even without the river crossings, this is a major endeavour. My hat's off to those who attempt the entire trail. Me, I'm happy getting as far as Caribou Pass and turning around! I break more readily now.
aquadog is offline   Reply With Quote
Times are GMT -7.   It's 07:03 PM.
