Old 03-28-2005, 11:44 AM   #46
txrider
txrider's Avatar
Oddometer: 370
Originally Posted by Loadedagain
mine took off on me once upon a time... i knew it happened right away, as it jammed between my tire and inner fender
it aint never going back on.
That's what my carbon canister did, it's resting in pieces in some weeds now.
I'm bolting a toolbox there now so it'll get the chance.
2004 KTM 625 SXC
2004 Yamaha FZ-1
1996 KTM 620 RXC
txrider is offline   Reply With Quote
Old 03-28-2005, 11:48 AM   #47
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,730
don't do it man..... it aint worth the fright you'll get when it fucks off.
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 03-28-2005, 12:11 PM   #48
Esteban
Esteban's Avatar
Oddometer: 5,799
Stuffed with heavy tools, I'd bet a hard day of single track would snap that off in a hurry. Maybe if the mounting points were more centralized. Even so, the small subframe mounting tabs can only take so much before they go south.
SG
Esteban is offline   Reply With Quote
Old 03-28-2005, 12:39 PM   #49
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,206
SG
looks that way - best to let the owner say what he did and how it has held up to what kind of riding he has done. it does look like it could use another mounting point near the cap to stabilize it.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 03-28-2005, 01:47 PM   #50
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Or at least put an old surfboard leash on it so you could find it after it parts company...
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 03-28-2005, 02:04 PM   #51
meat popsicle
Ignostic
Oddometer: 14,206
a short one so you dont get that full speed rear wheel lockup that Loaded was crying about
Old 04-01-2005, 11:57 AM   #52
KTM640Dakar
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,063
Wicked
Okie Dokie, got yer pics mister! I contacted a local welding supply and they are indeed about 10 bucks. I am stopping by there this week to pick one up and give this a shot; more later. Here are the pics:
First may I introduce you to KTM640Dakar's bike
And here is a pic of his mounting setup
And one more of the cap:
These are 15" long I hear tell.
Thanks for posting those pictures Meat Pop. If you notice the bracket that I used is a piece of aluminum. It is about 6 in. by 2 in.. Originally it was just a flat piece but I soon realized that it was going to hit the rear tire. I then cut a slit in it and bent it out to clear the tire. I also used 1/4 in. bolts to secure the tube to the bracket and siliconed the bolts to keep them water tight. It was nearly impossible to hold the nut on the inside of the tube so my wife (with tiny hands) held it for me. If I had to do it again I would use a shorter piece of aluminum. IMO the weak link are the brackets that are welded to the subframe.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar screwed with this post 04-01-2005 at 04:53 PM
KTM640Dakar is offline   Reply With Quote
Old 04-01-2005, 12:33 PM   #53
KTM640Dakar
Motorsick
Oddometer: 2,063
SG
I ride single track with a lot of woop-de-doos and since I weigh 240 pounds my back tire will bottom out. In Michigan we have 1300 miles of marked trails just in lower portion. (Lots of single track)
As long as you make sure that you clear the back tire you should be fine. You will be surprised how far you can bend out the bracket. The plastic panel on the bike will flex outward to accomidate the tube to clear the back tire. I carry tire irons and other long objects in my case. They probably don't weigh five pounds total. I would carry all my tools in this tube if I could but the factory tee handle allen wrench will not fit into this tube. It is about 1/4 inch too wide. Bummer. I have the pelican case for that tool roll and my electric hand held compressor.
Also notice that I have a flat sided welding tube (or octagon shaped). They also sell round welding tubes but I liked the octagon sided one the best.
This has been on my bike for a year now. Maybe 150 miles of it has been trail riding (single track).
Good luck!!!!!
Update 11-21-07 10,000 miles and still holding up great.
KTM640Dakar screwed with this post 11-21-2007 at 01:23 PM
Old 04-01-2005, 03:00 PM   #54
Ian640
Oddometer: 243
Cool2
Erm...may seem obvious, but some other options for tool storage:
1. A tail rack bag - I have a Touratech one that straps very securely (so securely it takes me 5 minsutes to remove it...) to the small luggage rack (if you have one).
2. A tail bag that fits to your rear fender (KTM sell one) - if you don't have the small luggage rack.
3. An engine guard mounted tool box like the one from SW-Motech (available from Sommer).
4. A Cycoactive fender bag - used one of these with success on my LC4-E on long (trans-Sahara) tracks - but it partially obscured the headlight beam.
5. A Cycoactive glovebox - probably won't fit an Adventure - anyone used one on their LC4-E/SXC/RXC?
Cheers.
Ian640 screwed with this post 04-01-2005 at 03:47 PM
Ian640 is offline   Reply With Quote
Old 04-01-2005, 04:37 PM   #55
matey peeps
Bead Buddy
matey peeps's Avatar
Oddometer: 3,326
HEY! We sell those where I work!
And guess what I just paid $4.09 for.
matey peeps is offline   Reply With Quote
Old 04-01-2005, 05:30 PM   #56
meat popsicle
Ignostic
Oddometer: 14,206
now about those brackets...
and maybe an additional one further back to stabilize the weight better and backup the weak weld on tabs that support it now.
Old 04-01-2005, 07:37 PM   #57
rapiti
IOR Veteran
rapiti's Avatar
Oddometer: 1,899
You've got a stress riser where you slit the aluminum. Drill a hole there, so it won't break "on the dotted line."
If it were mine, I would get some kind of webbing for a secondary support and wrap it around your welding rod tube and the subframe, binding it with another pop rivet. DON'T use a surf leash!!
Looks like a good concept.
...its the best paint scheme that has ever been or ever will be on an Adv...-AussieRob
rapiti is offline   Reply With Quote
Old 04-01-2005, 08:49 PM   #58
KTM640Dakar
Motorsick
Oddometer: 2,063
Hey Rapiti, congrats on your 1000th post.
Yes you are right it is a stress riser. If it was filled with cement I would probably drill it. The plate is 1/8 inch thick. It is way over engineered for my application but the plate is just some extra stock that was laying around and it was easy to work with.
Old 04-01-2005, 11:34 PM   #59
Esteban
Esteban's Avatar
Oddometer: 5,799
KTM640 Adventure,
Thanks for taking the time to post the pics of your welder tool box for all of us to see.
Steve
Old 03-18-2006, 10:56 PM   #60
KTM640Dakar
Motorsick
Oddometer: 2,063
Just to update everyone. The toolbox has 3000 miles on it now. I have had no problems. I did paint it orange with that Krylon fusion spray paint. They make an orange that is a perfect match. See it in action here:
http://www.advrider.com/forums/showt...=85503&page=17
Times are GMT -7.   It's 04:25 PM.
