Old 02-01-2013, 03:57 PM   #316
Casejeep OP
Casejeep's Avatar
Oddometer: 736
Just got my used xChallange forks in the mail today. Im going to use them to make my forks adjustable, and paired with new springs = Sweet!!
MY F800 GS Build
Casejeep is offline   Reply With Quote
Old 02-01-2013, 05:01 PM   #317
Angryrican
know nothing all
Angryrican's Avatar
Oddometer: 286
my favorite mod so far!
Angryrican is offline   Reply With Quote
Old 02-01-2013, 05:28 PM   #318
Buster714
VP of crash testing
Buster714's Avatar
Oddometer: 662
awesome man, can't wait to see how this turns out
Aram :: SoloMotoParts.com :: Motorcycle Parts, Gear, and Accessories
Premier Brands / No Tax / Free Shipping / Hassle-Free Returns / Friendly Customer Service
Buster714 is offline   Reply With Quote
Old 02-01-2013, 09:32 PM   #319
biodieselandon
biodieselandon's Avatar
Oddometer: 358
Single rotor?
2013 BMW F800GS, Cordoba Blue, ASC, ESA, ABS
2012 BMW G650GS - 13,000 miles ***SOLD***
"If you're not mixing gas, you're not hauling ass!"
"A clean GS is a dirty shame."
biodieselandon is offline   Reply With Quote
Old 02-02-2013, 07:07 AM   #320
Casejeep OP
Casejeep's Avatar
Oddometer: 736
Originally Posted by biodieselandon View Post
Single rotor?
Im only taking a few of the parts from the xChallange forks, the cap and some internal parts.
MY F800 GS Build
Old 02-04-2013, 09:59 AM   #321
Casejeep OP
Casejeep's Avatar
Oddometer: 736
Took the morning to take my forks off.
The first one came off fine, but the other side.... i stripped one of the star bolts that hold the caliper, so fuck my life, ill have to figure out how to do that side.
(i had to install it back into the bike in order to get the top cap off)
Once i got it off you just slide it down and pour out the oil.
After you take out the cartridge. you can see that not only are they the same. but the xChallenge one is adjustable and a little longer!
I dont have my new Race Tech springs yet, but i just wanted to see how it all went together. Looks great!
MY F800 GS Build
Old 02-04-2013, 03:06 PM   #322
Angryrican
know nothing all
Angryrican's Avatar
Oddometer: 286
if anyone wants to know where the xChallenge gets the extra 40mm of travel take a look at the uppers(gold tube) from both forks and you have your answer, it is ~40mm shorter then the F800GS allowing the fork stroke to be longer giving it the extra travel.
Old 02-08-2013, 11:04 AM   #323
jeepy
jeepy's Avatar
Oddometer: 58
bike look good ... how many time to do the tank swap ??
jeepy is offline   Reply With Quote
Old 02-08-2013, 11:21 AM   #324
Casejeep OP
Casejeep's Avatar
Oddometer: 736
I did it over a few days working maybe 2 hours a day.
MY F800 GS Build
Old 02-09-2013, 12:17 PM   #325
LukasM
Oddometer: 5,426
If you are putting the X-Challenge cartridges into the F8 outer tubes, make sure that the travel is limited internally, and not by the longer upper tube bottoming out.
Old 02-09-2013, 12:51 PM   #326
Angryrican
know nothing all
Angryrican's Avatar
Oddometer: 286
It shouldn't, the cartridge body is 4-5mm longer, besides that both dampers compress and extend the same length, the upper tubes are ~40mm shorter, the lower tubes ~40mm longer, they both share the same stock spring (same exact part number)so all things equal it should not be an issue since the cartridge sits further in the lower tubes which is what allows it to move the extra 40mm or so on the xChallenge.
I have ridden mine on some pretty rough terrain and have hit a few drops and have yet to bottom it out. I should only travel as far as the spring allows it to.
Static sag was a ~3-4mm higher but that should be caused by the stiffer Ohlin's springs.
Also remember static sag should be shorter on the xChallenge since it is close to 100lbs. lighter
Angryrican screwed with this post 02-09-2013 at 01:32 PM
Old 02-26-2013, 12:01 PM   #327
Casejeep OP
Casejeep's Avatar
Oddometer: 736
The day has come! The Xchallenge cartridge swap is complete! A fully bolt up mod that cost me a total of $275. Way better than $1,300 for something very similar.
Took it around the block ( thats all i can do since there is 20" of snow on the ground) and WOW!!!!! Just wow. What a difference. It blows my mind just a little bit!
Literally all you do is switch out the cartridge and put in new springs. anyone can do it!
Look how pretty they are!
MY F800 GS Build
Old 02-27-2013, 11:46 AM   #328
Buster714
VP of crash testing
Buster714's Avatar
Oddometer: 662
You bastard. You'll get to stretch its legs next month.
If I'm able to ride you can be my fueling station in DV.
Old 02-27-2013, 01:01 PM   #329
ebrabaek
Oddometer: 4,763
Looks awesome..... I just don't seems to be able to find a pair of XC forks.....
Erling
Old 02-27-2013, 06:21 PM   #330
DoWorkSon
Oddometer: 270
Yeah, that is gonna be the hard part....
DoWorkSon is offline   Reply With Quote
Times are GMT -7.   It's 10:40 PM.
