Old 11-17-2011, 01:12 PM   #106
Casejeep OP
Casejeep's Avatar
Oddometer: 739
Anyone know of anyone have a good sale on race lights?
Casejeep is offline   Reply With Quote
Old 11-17-2011, 01:22 PM   #107
LukasM
Oddometer: 5,427
Darryl at Cyclops has great prices on Trailtech stuff, even more so if you tell him you come from ADVrider.
Old 11-17-2011, 01:42 PM   #108
Casejeep OP
Casejeep's Avatar
Oddometer: 739
yeah i do like the trailtech lights, but i want 2 6" lights not one huge 8".
Old 11-17-2011, 04:21 PM   #109
Casejeep OP
Casejeep's Avatar
Oddometer: 739
i really like the look of the KTM fender, but im not ok with spending $50 for the 690 fender. will this one be long enough to protect me?
http://www.ktmcyclehutt.com/ktm-part...tment=bigbikes
Old 11-17-2011, 08:54 PM   #110
dendrophobe
Motorbike Junky
dendrophobe's Avatar
Oddometer: 859
Hard to tell, but I'd say probably. It looks of similar design to the Acerbis one that Finn used.
Doug
Semper Fi
2009 BMW F800GS, Olive Drab
2006 Ducati Sport 1000, Black
Custom built Ducati GT1000 Scrambler, Red
dendrophobe is offline   Reply With Quote
Old 11-18-2011, 03:28 AM   #111
LukasM
Oddometer: 5,427
That one is fine, it's what the KTM dirt bikes use.
Old 11-18-2011, 08:06 AM   #112
Casejeep OP
Casejeep's Avatar
Oddometer: 739
I think im going to get that one then.
Old 11-18-2011, 11:34 AM   #113
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
Nice job CaseJeep. I am seriously thinking about the brake line / high fender mod and its fantastic to have the info and pics in this thread. Thanks also to MCMXCIVRS for all the info in the high fender mod thread. I think I will probably go with the three line setup like MCMX. It looks like it fits pretty cleanly. If you do switch to a two line set up CaseJeep, it would be great if you could post some pics of it.
A nOOb question if you guys don't mind as I have never worked on brake lines before. I follow the process of bleeding and installing the lines. When you refill the fluid do you just pour it in from the reservoir? Will this push all the air down out the bottom bleed valve? The Haynes manuel also says something about having to have a BMW dealer check for any error codes if you do any work on an ABS equipped bike. Thanks for any info.
Dan
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 11-18-2011, 11:55 AM   #114
Casejeep OP
Casejeep's Avatar
Oddometer: 739
Dan
Yeah Dan, once you have the new lines attached, you unscrew the bleeder valve a few turns. you fill up the reservoir, and pump the front break will the fluid gets low, fill it back up and keep going till the bleeder is continually spiting out fluid. MAKE SURE you dont let any air into the lines from the top, or else you will have to start again.
tighten up that one bleeder valve and go to the other side. repeat.
I havent gotten any error codes on my bike, but of course i have not been riding since.
Old 11-18-2011, 05:01 PM   #115
chadams
Oddometer: 209
Originally Posted by Gangplank View Post
So those are the Fuego 4" right?
What bracket did ya use?
What's that little light in the middle?
That's my little beasty, They are unbranded 4" HID, from what I can find out about the they are the same housing / reflector as the 4" hid hella optilux. 35watt each, one spread one pencil, if I did it again I'd just get the two spread as the pencil is very focused. The little light is a 55watt halogen junk lamp, I'm surprised it still working. If seen candles throw more light then it does but I will do for now.
Current ride:- 2002 KLX400R
Previous rides:-09 f800gs, 05 z750, 81 z1000j, 84 gpz1100, 98 dr250, 99 dr250, 96 dr350, 93 rf900, 93 nx650, 98 xtz660, 97 dt200r
chadams is online now   Reply With Quote
Old 11-18-2011, 05:06 PM   #116
Casejeep OP
Casejeep's Avatar
Oddometer: 739
i got this KTM fender. i think it is big enough, what do you guys think?
Fender
Old 11-18-2011, 05:45 PM   #117
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,804
I say too big. May look into a KTM SX fender. They used to be a bit shorter in the nose.
johngil is offline   Reply With Quote
Old 11-18-2011, 05:55 PM   #118
Casejeep OP
Casejeep's Avatar
Oddometer: 739
Old 11-18-2011, 07:13 PM   #119
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,804
I don't have the bike anymore so I can't offer a part #, but you can see the shorter front portion.
Old 11-19-2011, 01:08 AM   #120
dendrophobe
Motorbike Junky
Oddometer: 859
Looks like it's angled down too far. Try rocking it back a bit (just use spacers) and see how that looks.
Doug
Semper Fi
Times are GMT -7.   It's 12:59 AM.
