Old 03-31-2013, 08:43 AM   #16
keener
Speed changes you.
keener's Avatar
Oddometer: 957
Thx for the photos. I have converted the break lines of my 04 950 which is taller than any other none-S version, to 2010 R 990 specs. That gives the lines a "S" shape as supposed to straight down.
The length of the lines worked beautifully for my 04.
The only unresolved issue for me are the fork guards. I have a set of 85 SX gaurdes which I don't really like and won't use. I have sent the break lines to the OUTSIDE of forks. I'm not quit happy with the setup. They are rubbing against the forks:
looking at this:
If this person has cut the stock fender, it doesn't look like the top part of the fender is kept. I don't now how that fender is staying in place! with just 3 bolts at the bottom?!
04 ADV 950
keener is offline   Reply With Quote
Old 03-31-2013, 09:07 AM   #17
keener
Speed changes you.
keener's Avatar
Oddometer: 957
just saw this on post: http://www.advrider.com/forums/showp...75&postcount=9
here is the photo from that post:
This person has cut the fork protectors/guards, and does not look like the one on my previous post.
04 ADV 950
Old 03-31-2013, 07:23 PM   #18
hayshaker
hayshaker's Avatar
Oddometer: 390
Originally Posted by keener View Post
Old thread...I though I post my question here as suppose to starting a new one for better record keeping.
Does anyone recognize these fork protectors?
are they made by KTM? I like them a lot over 85 SX version.
photo from BlackDog website.
Thats how I did mine, cut using a 4" angle grinder utilizing the low fender (it was cracked from mud etc). One issue I had was high fender clearing the engine guard just in front of the radiator. By clipping a couple of inches off the fender and using thicker spacers in the 2 holes to the rear bolts on the fender and perfect fit. It tips the fender up in the front a bit away from the radiator. I added a mud flap thingy to keep stuff falling into the skid plate area.
The one concern is rubbing of the brake lines on the fender. Watching for a wear pattern but it seems fine and I ride it pretty hard off-road.
TONY
2014 450XC-W, 2006 KTM 450 EXC, 2010 KTM 990 Adventure, 1995 Goldwing Trike
George, WA
hayshaker is offline   Reply With Quote
Old 04-01-2013, 06:17 AM   #19
keener
Speed changes you.
keener's Avatar
Oddometer: 957
Thx Tony,
so those two photos are showing the same fork protectors! for some reason the shadow lines on the top one made it look different.
I'd like to keep my stock fender. I'm just searching for fork protectors that look better than 85SX ?
This is the fender I installed:
http://www.polisport.com/motorbikes/...?ID=55&marca=1
It clears the radiator by about 3/4" to 1/2". Looks well made.
04 ADV 950
Old 01-16-2014, 06:14 AM   #20
HarryEye
Oddometer: 36
Polisport
I'd like to see a photo of that Polisport fender on a bike.
Also, how much do they cost?
HarryEye is offline   Reply With Quote
Old 01-16-2014, 07:08 AM   #21
keener
Speed changes you.
keener's Avatar
Oddometer: 957
PolisPort - universal - SM line fender
RE: PolisPort - universal - SM line fender
since there is interest in this fender I'd like to share that I have since moved the break lines to the INSIDE going down between the tire and the forks. It may sound crazy, thinking the lines will get grab the tire but they won't. The fender keeps them away. I have ridden the bike with this setup for two seasons and over 20,000km with no issues.
04 ADV 950
keener screwed with this post 01-16-2014 at 03:56 PM
Old 01-16-2014, 07:30 AM   #22
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 934
That Polisport SM fender is too short and you'll be eating mud!
Have onde almost brand new in my shed, waiting for a bike with a smaller wheel
690R
Old 01-16-2014, 12:18 PM   #23
armourbl
Adventure Life
armourbl's Avatar
Oddometer: 626
When I finally get around to doing my high fender I want to use the standard KTM wrap around fork guards for added protection and more durability. First time you lay the bike over and a rock scratches the lower fork tube you'll wish you had them. Had this recently happen to my CRF450R and I'm thinking about retro fitting them on that bike now.
Anyone know where you can get a white front fender for a 690 Enduro?
ben
______________________________
2013 KTM 990 Adventure Baja Edition
armourbl is offline   Reply With Quote
Old 01-16-2014, 04:20 PM   #24
keener
Speed changes you.
keener's Avatar
Oddometer: 957
I can not disagree more!
I have ridden in rain, mud, snow, dirt, sand,... any condition I guess with this setup and never ate mud! I love riding in mud though.
04 ADV 950
Old 01-16-2014, 04:24 PM   #25
keener
Speed changes you.
keener's Avatar
Oddometer: 957
ben
Look up the parts fiche at your dealer's website. Be warned that holes at the bottom might not line up with your forks, but there are ways around it. Look up other high fender threads here, there are lots of photos. You have two choices as far I remember.
04 ADV 950
Old 01-16-2014, 04:41 PM   #26
renogeorge
Oddometer: 1,393
I run an Acerbis short fender which looks just like the Polisport to me. I use the KTM 85 fork guards, with a strap adaptor to align the bottom holes between the fork and guard. I run brake lines inside the fork legs, using original top guide on left side guard and Zip tie on right side. Worked well for 8000 miles including Alaska with some mud and muck.
Have a set of brand new orange fork guards to sell.....
FWIW
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 01-16-2014, 05:51 PM   #27
JoeMongo
¿Por dónde?
JoeMongo's Avatar
Oddometer: 532
Thumb I really like Taurkon's design
It worked out great for me. I used all the parts in Taurkon's list. They all worked great. I just put in a few seconds with a heat gun to help the screws line up, and drill a couple of holes for the third screw on each side, and it is a done deal.
'08 990 ADV, '03 DR-Z400S
Anything worth doing, is worth overdoing.
JoeMongo screwed with this post 01-16-2014 at 06:02 PM
JoeMongo is offline   Reply With Quote
Old 02-21-2015, 09:25 AM   #28
zbob
Oddometer: 6
Gathering parts for the high fender set up. Have you guys had any issues with rocks kicking up into the radiator with the short tail end of the new fenders ?
zbob is offline   Reply With Quote
Old 02-22-2015, 01:06 PM   #29
squadraquota
mostly harmless
squadraquota's Avatar
Oddometer: 103
ben
The 2015 and 2014 690R fenders are white. I just fitted one to my bike.
680 SMC fenders also come in white. They look better imo but offer less guard to mud splatter.
As for fork guards, I had the 85sx (2005 or so) black guards, but have now put on the 2015 SX white guards. These are a bit different, they wrap around the forks more compared to the old model. Bolt holes are the same as the old SX.
I just use two bolts ie three, the side bolt and the outer one on the front.
As for the ABS sensor, I just dremmeled a bit into the guard to make the sensor fit. No big deal.
Two bolts is really enough to hold the guard into place, feel free to make brackets but personally I think that is too much trouble.
If you like, I could post some photos later. None handy at the moment
squadraquota is offline   Reply With Quote
Old 02-22-2015, 03:15 PM   #30
Young-Gun
KTM Tragic
Young-Gun's Avatar
Oddometer: 1,061
I know the hole placement at the front is slightly different on the 990 to the 950 but pics can help with ideas anyway. I also used the heat gun method to stretch the side hole a bit:
Ryan
KTM 950/990 Oil Drain Hoses For Sale
KTM 950 'S' - Loving it!
KTM 625SXC - Adventure bike (project)
Young-Gun is offline   Reply With Quote
Times are GMT -7.   It's 01:16 PM.
