Old 10-01-2011, 07:31 AM   #1
MOSGS OP
Oddometer: 104
HELP, How to install Fuel Sensor Strip ???
Ok my fuel sensor strip went on my 07 GS. That is not big news. I started to look it over to see if it may be something else. It reads a full tank all the time. I took the fuel tank neck out and looked in the tank. I saw the strip laying down on the right side of the tank. Is this right? Seems like it should be hung someplace in the tank not laying down.
Anyone know just how this strip is to be installed????
Mike
MOSGS is offline   Reply With Quote
Old 10-01-2011, 05:43 PM   #2
hillbillypolack
Grumpy Old Goat
hillbillypolack's Avatar
Oddometer: 6,255
take it to your dealer. It should be covered under warranty. Mine was.
I found Jesus. He was behind the sofa the whole time.
1996 M900 2012 GS 2008 Megamoto 2008 S2R
2006 HP2e
hillbillypolack is offline   Reply With Quote
Old 10-02-2011, 05:54 AM   #3
MOSGS OP
Oddometer: 104
BMW would not cover it. They said it was out of warranty! 2007 with 25,000 miles.
Old 10-02-2011, 10:03 AM   #4
skibum_1260
Oddometer: 243
I just replaced the strip on my bike, really its pretty simple. It hangs from a steel post under the gas cap. So pull your gas cap, pull the cap sealing ring and under that you will see a metal ring with a piece of steel sticking out about 1-2" Thats what i needs to hang from, then the bottom of the strip will sit in a small pocket on the left side/ bottom of the tank. You may need to pull your fuel pump to verify its sitting correctly.
So far i havent even had it calibrated and it seems somewhat close. Time will tell but alot better then having a dealer do it. And you dont even need to pull the tank to swap it.
skibum_1260 is offline   Reply With Quote
Old 10-02-2011, 01:13 PM   #5
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,228
Thumb GSpot FAQ
This is a nugget of information.
Can it be verified (that is, someone else telling me that it is in fact true)?
If so I'll put it into the GSpot FAQ without delay.
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Old 10-02-2011, 05:16 PM   #6
skibum_1260
Oddometer: 243
Yeah I tried finding someone else who had tried this but had no luck. I figured the resistance value cant be that different when there made. So it should at least be close if you just swap them out without having it calibrated. But I did fill the bike up finally today and the guage does go all the way to the top, range is a bit different then before but its wasn't exactly accurate to begin with. now just to see how accurate it is once empty!
But really you could probably replace the strip in about half an hour.
Just need to be able to pull the fuel pump on left side of tank, disconnect fuel strip, remove fuel filler cap and pull out the old strip from hanger, hang new one and plug it back in, install fuel pump and then your body panels.
Only issue is removing the large ring on the left side of the tank for the fuel pump. I just used a adjustable pin spanner wrench but isnt on to tight anyway.
skibum_1260 screwed with this post 10-02-2011 at 05:27 PM
Old 10-03-2011, 07:02 AM   #7
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,228
Thumb
Part number for a new strip?
[TaSK]
IBA: 33616
Old 10-03-2011, 07:28 AM   #8
little foot
Scratch and Sniff
little foot's Avatar
Oddometer: 6,666
Lets see some pics of the strip swap.
little foot is offline   Reply With Quote
Old 10-03-2011, 07:52 AM   #9
skibum_1260
Oddometer: 243
16 14 7 675 547 List is 131.95 from maxbmw and this is for a 09 r1200gs adventure, not sure if the adventure and regular gs uses the same strip or not. Sorry didn't take any picks though when I did it.
Times are GMT -7.   It's 12:43 PM.
