Old 10-03-2011, 06:18 PM   #46
Max Headroom
lost in the '70s
Max Headroom's Avatar
Oddometer: 517
If the damage is confined to one side only, it would suggest that either the base of the barrel has been machined or the head has been shaved.
I had a similar situation with an R75/5 earlier this year, and it was resolved simply by installing a 0.020" spacer under the barrel.
'76 R90S silver smoke
'75 R90/6 hybrid
'Skills are learned, talent is ornate.' Billie
Max Headroom is offline   Reply With Quote
Old 10-03-2011, 06:22 PM   #47
D-Mac
D-Mac's Avatar
Oddometer: 613
I agree that it looks like both valves are hitting the piston. If true, this provides a clue. Also, they clearly can't be open very much when it's happening or things would almost certainly be much, much worse.
What kind of valve overlap exists on an airhead? I don't see how the piston could hit closed valves, so wouldn't the evidence indicate the valves might be hitting the piston at the end of the exhaust stroke (when the exhaust is nearly closed and the intake is just starting to open?)
So check the timing first.A couple of teeth off would seem to be the most likely culprit.
Alternatively, would very weak valve springs allow the piston to hit the valves and cause this kind of mark?
2010 BMW R1200RT
IBR #443 (2011 Finisher)
D-Mac is offline   Reply With Quote
Old 10-03-2011, 07:36 PM   #48
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,498
At high revs only, yes. The intake valve being larger and thereby heavier would be the first to float though. It'd be worth measuring the free and installed lengths of the valve springs because it's easy, but I doubt that's it.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 10-04-2011 at 07:19 AM
Old 10-03-2011, 09:47 PM   #49
kbasa
Colnago!
kbasa's Avatar
Oddometer: 68,523
Originally Posted by outfit View Post
Dont be silly, why do you turn the crank 360 to do the valve lash on the opposeing side
Cam timing is off 180?
Is it even possible to do that?
IMHO.
Fuck Cancer. Ride bikes. - dave + tina
kbasa screwed with this post 10-03-2011 at 09:52 PM
kbasa is offline   Reply With Quote
Old 10-03-2011, 10:41 PM   #50
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,373
No. If you set the cam shaft 180* off the engine will run normal. 180* off is really normal cam timing.
Look. The cam rotates once for every two times the crank rotates. Got that. They don't care which side is at TDC. So if you set the cam mark 180* off the engine will still run normal.
In fact when you changed the chain or whatever and had to set the timing marks? Put them in alignment and then turn crank one rotation, now the cam is 180* off.
Old 10-03-2011, 11:01 PM   #51
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,807
My R100RS was built by S.J. BMW as a hotrod. It had a set of their factory rocker arms modified for a greater ratio and thus greater lift. It was my first BMW so I wondered why the adjuster end looked modified but didn't recognize it as not stock. I didn't have any interference issues but I was working for Ozzie in Chico at the time and when he saw them he insisted that I remove them.
You have a photo of the rocker arms? It's unlikely but who knows.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 10-03-2011, 11:27 PM   #52
supershaft
because I can
Oddometer: 9,116
They were pretty savage.
Old 10-04-2011, 08:58 AM   #53
Beemerguru
Beemerguru...G/S guy
Beemerguru's Avatar
Oddometer: 977
Talked with Max last night.
Look at the pictures...both valves on both sides are hitting the heads.
When the engine was set up,..there was the proper end play for all the valves.
It has a set of SJ push rods installed and they measured out to the same length as the stock ones.
He installed the smaller base gasket,,,the .5mm and not the 1.5mm option.
If the heads were skimmed, I KNOW the machinist always includes a set of washers to put under the rocker arms to keep the correct height..but i don't think these were skimmed.
That doesn't leave much other than weak springs...but I know those are always replaced too.
The thicker base gasket will probably solve the problem but is that really the cause..don't think so since there was proper end play to begin with...the rocker arms would have locked up just trying to set the valve clearances.
Timing gears have been checked at least 3 times for alignment against TDC.
The mystery continues..heads are going to be examined as well as each part of the engine..bound to be something obvious,,I hope.
Greg Hutchinson
BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club
http://gregsgssite.shutterfly.com/
Beemerguru is offline   Reply With Quote
Old 10-04-2011, 10:40 AM   #54
melville
melville's Avatar
Oddometer: 1,459
Originally Posted by wmax351 View Post
One consideration from Ted Porter,
Originally Posted by Ted Porter
I would have a lot of questions about this assembly. Those look like the special high compression 750 pistons, is that true? Is the cam stock? I would also want to look at the depth of the valves in the head. Obviously you need some clearance somewhere. ;)
Do those look like stock pistons? I'm not sure. They're .5 over, 82.465 mm. That puts them .5 over on a R75/7, but still not 100%.
They are first oversize, "A" bore group. The domes do look big, bigger than what I pulled out of my R75 last year IIRC. I might be able to post a better pic for comparison tonight. This is a first OS, "B" bore, 82.475mm:
Hard to see a difference sitting in the ring squeezer, but there might be one.
Call me Mel. Some years ago- never mind how long precisely- having little or no money in my purse, and nothing particular to interest me at home, I thought I would ride about a little and see the other parts of the world. It is a way I have of driving off the spleen and regulating the circulation.
melville is offline   Reply With Quote
Old 10-04-2011, 11:50 AM   #55
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,649
If the cam, etc was set up right, could the crankshaft be a later on with a longer stroke? What size flywheel bolts and type flywheel does it have? Don't know for sure, just grabbing at straws.
I'm thinking it will be ultimately related to it being a Beemer In A Box and Frankenbeemering parts together.
'73 R60/5 Toaster
Old 10-04-2011, 12:20 PM   #56
anotherguy
anotherguy's Avatar
Oddometer: 6,216
Clay the valves for clearance on assembly and these things won't surprise you. Too many unknowns unless you know all the parts history. Guessing leads to disaster.
you don't see luggage racks on a hearse..........act accordingly
Old 10-04-2011, 12:40 PM   #57
supershaft
because I can
Oddometer: 9,116
Clay? I rather use solder. On a beemer you can measure valve clearance with solder through the spark plug hole. You can put it together for keeps and only have to take it back apart if there is a clearance issue. Plus solder is much easier to get a caliper around and accurately measure down to the thousandths.
Most of us beemer guys would call this issue highly unusual. All original stock BMW parts? No need to measure.
Old 10-04-2011, 01:01 PM   #58
Max Headroom
lost in the '70s
Oddometer: 517
Try fitting a pair of standard BMW pushrods. I know of another recently rebuilt engine which had issues with rough idling and loss of power when hot, yet it ran fine when cold. It was also fitted with a set of SJ pushrods, and eventually it was discovered that they were growing when hot and the valve clearance would close up.It wasn't an obvious problem, and kept folk guessing for quite a while.
Between that and a thicker base gasket, most of the issues would be sorted.
'75 R90/6 hybrid
Old 10-04-2011, 01:02 PM   #59
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,131
The only crank with a different throw is the R65 - and it's shorter. The flywheel bolt size only affected which flywheel it would accept.
Mixing parts doesn't necessarily cause problems, but in this case, some un-noted change was made previously that must be tracked down by careful observation, comparison to standard parts, and measurements.
At this time I don't see any other possibilities other than already mentioned. All the likely suspects have been rounded up and are currently getting their mug shots and finger prints.
Old 10-04-2011, 01:09 PM   #60
supershaft
because I can
Oddometer: 9,116
My NOT SJ 4130 pushrods were doing just the opposite. They "shrunk".
Times are GMT -7.   It's 09:56 AM.
