10-04-2011, 12:51 PM
#61 | |
Oddometer: 740
10-04-2011, 12:55 PM
#62 |
the thread-killer
Oddometer: 4,297
I'm still waiting for someone to compare CROWN HEIGHTs and Valve pocket heights.
C,mon youse guys..............
10-04-2011, 01:21 PM
#63 |
Oddometer: 740
10-04-2011, 01:26 PM
#64 |
Oddometer: 359
Valve sticking in the guide and the piston hammering it closed?
10-04-2011, 01:36 PM
#65 | |
Oddometer: 4,315
When injustice becomes law,resistance becomes duty. Thomas Jefferson |
10-04-2011, 01:43 PM
#66 |
More tacos than you
Oddometer: 5,106
Measure the top of the wristpin hole to the top of the piston with a caliper. Also measure the installed valve spring length also.
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
10-04-2011, 01:56 PM
#67 |
Mad Scientist
Oddometer: 2,964
Visually it looks like the piston is stick up to high in the cylinder. My guess would be the cylinder has been machined down at the base.
BOXER Metal BMW Biker Scum BMW Mad Scientist! VBMWMO #7770, BMW MOA #48694 & Airhead BMW Club #600 |
10-04-2011, 02:19 PM
#68 |
the thread-killer
Oddometer: 4,297
Oooooh, Bobby, I think that makes alot of sense if both guides were not sized correctly.
10-04-2011, 02:20 PM
#69 |
Oddometer: 4,315
When a stuck valve is struck by the piston it bends and gets much worse from there.
10-04-2011, 04:46 PM
#70 |
because I can
Oddometer: 6,070
10-04-2011, 05:06 PM
#71 |
turd polisher
Oddometer: 771
I had this happen on a SABB marine diesel. The valve train was not engineered to rotate the valves, and the stems would get carboned up and would make the valves stick very slightly open. Being that this engine was rebuilt 100 miles ago, I'm sure it's not a carbon buildup issue, but theres a lot of other ways a valve could stick. Unfortunately, now that things have beaten on each other, if on inspection you find that a valve is sticking, you won't know which came first, the chicken or the egg.
I wouldn't bring her home to Mama, but Mama ain't home tonight. |
10-04-2011, 05:21 PM
#72 |
Oddometer: 4,315
You're a hack and a charlatan. If he'd have checked at assembly we wouldn't be having this conversation.
10-04-2011, 07:11 PM
#73 |
Beemerguru...G/S guy
Oddometer: 635
I know it's always the right thing to do,,,measure for head interference when assembling a new engine...but in reality,,,all stock BMW parts,,rotates with no interference on assembly, has the proper valve clearance, etc, I would think everyone on this list would think the engine was good to fire up,
Of course when that first loud WHACK, WHACK comes out...I don't think I'd see if it would go away in a 100 miles. That head would be off in 15 minutes. Measure the piston and measure the cylinder...this crowd has been in suspense for too long. Post the findings..everyone will grab their favorite manual and tell you if the problem lies in either part.
Greg Hutchinson BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club http://gregsgssite.shutterfly.com/ ![]() |
10-04-2011, 07:47 PM
#74 | |
Oddometer: 740
10-04-2011, 08:10 PM
#75 |
because I can
Oddometer: 6,070
I do go so far as turning the engine over enough times to get through all the valve cycles for each cylinder and make sure nothing is hitting. I have never had anything hit so far. It is a lot easier than measuring your valve clearance with clay. ESPECIALLY when you have the cams off a DOHC engine to adjust some shims. The idea that you should disassemble your engine, reassemble it with clay in it, take it back apart again to measure the valve clearance the clay witnessed, and then reassemble it again. How do you check the last assembly??
(You could do it with solder like I suggest!) Doing that every time you can get into any trouble isn't really realistic. Not even close.
