10-04-2011, 08:26 PM
#76 | |
Tinaversal
IMHO. Fuck Cancer. Ride bikes. - dave + tina |
10-04-2011, 10:57 PM
#77 |
Oddometer: 740
Here's more pics of the heads, cylinders, and pistons. Measurements will happen this weekend.
https://skydrive.live.com/redir.aspx...FB71801A7E!766 |
10-04-2011, 11:35 PM
#78 |
Oddometer: 754
I would bet that, at some point the mating surface of the case (where the jugs bolt up) has been flycut to clean-up the surface. Thus making the assembled height too short without a thicker gasket, or double gasket, or gasket and shim.
10-05-2011, 12:15 AM
#79 |
enamoured
Oddometer: 2,481
What should the normal distance be from the piston crown to the head at TDC?
10-05-2011, 12:56 AM
#80 | |
Oddometer: 1,109
You need about the same piston to valve clearance too.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. Bertrand Russell |
10-06-2011, 06:12 PM
#81 |
Still on 3 wheels
Oddometer: 3,367
10-09-2011, 12:19 PM
#82 |
Oddometer: 740
Talked with the local Motorcycle shop (Bill at Quality Motorcycles). Going to have him inspect the heads and pistons, and see what needs replaced.
We were discussing the cause, and most logically, it seems like somewhere in the last 40 years, something was machined down, either heads, cylinders, or cylinder pads. I'm going to repair the damage, and then put the low test gasket (1.2 mm) on, button it up, and clay the motor. Should fix the problem. |
10-09-2011, 03:29 PM
#83 |
Confirmed Curmudgeon
Oddometer: 3,850
You might want to measure some volumes and calculate the compression ratio of this particular collection of engine components. It won't run happily on available fuel with a 15:1 CR...
'73 R60/5 Toaster |
10-09-2011, 03:43 PM
#84 |
Oddometer: 740
Probably would be the wise thing to do. These are all stock, so as long as there is clearance, it should be fine. Can't hurt to check though.
10-09-2011, 04:50 PM
#85 |
Don't buy from Brad
Oddometer: 7,403
this is one of the best threads I've seen in awhile.
Every time I get cocky about what (I think) I know, I run into threads like this and regain humility. ![]() Some of the questions you guys (and girls?) are asking demonstrate a tremendous depth of understanding of how these bits of ironmongery work. What an amazing braintrust. ![]() ... now don't get a swelled head. ![]()
On tap:Nada Aging: 3 experiments in mead - blackberry, apple, and straight honey |
10-09-2011, 05:41 PM
#86 | |
Oddometer: 740
Also a good example of the combined knowledge of the internet. You combine all the gurus', as well as the tinkerers' knowledge, and you could fill volumes. Each person adds their little (or large) contribution, and you get something amazing. I'd like to see an airheads wiki. |
10-09-2011, 07:58 PM
#87 |
BigBrowedNeandereer
Oddometer: 1,004
Now I know I have seen something like that somewheres. Maybe IBMWR or something like that.
Here is one down for service. http://wiki.airheads.org/index.php?title=Main_Page The there is wikipedia itself http://en.wikipedia.org/w/index.php?...ofile=advanced |
10-20-2011, 03:48 PM
#88 |
Oddometer: 740
Well, here's an update. Took the heads to the local motorcycle repair guy, who does a lot of work on airheads. He checked them out, and says they seem fine. We're going to have him look at the pistons too, but he thinks they should be run-able. We're assuming that at some point, something has been machined down. Rather than figure out what it is, we are just going to fix the problem. We'll start with the low test, 1.2 mm base gaskets, check for piston crown clearance with clay, then measure tdc volume with mineral spirits, and adjust each side to be equal with .5mm high test base gaskets.
10-20-2011, 06:28 PM
#89 |
Oddometer: 3,850
Sounds like a plan... :)
'73 R60/5 Toaster |
10-20-2011, 08:35 PM
#90 |
the thread-killer
Oddometer: 4,297
Early (70-75) jugs I'm measuring this: see picture
76 and later are running around 118mm even or thereabouts. I compared several original jugs. I have many several. wirewrkr screwed with this post 10-21-2011 at 07:03 AM |
