Old 10-20-2011, 10:29 PM   #91
wmax351 OP
Oddometer: 743
Originally Posted by wirewrkr View Post
Early (70-75) jugs I'm measuring this: see picture
76 and later are running around 18mm even or thereabouts.
I compared several original jugs. I have many several.
I will definitely measure that. Thanks!
wmax351 is offline   Reply With Quote
Old 10-21-2011, 01:15 AM   #92
supershaft
Oddometer: 9,110
I am suspecting that ww just figured it out? At least part of it?
Old 10-21-2011, 05:10 AM   #93
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,441
And nitpicking a tad, 'Wire meant 18cm, 180mm (not 18mm). 117.6mm to be precisely as-read.
FWIW. :)
'73 R60/5 Toaster
Old 10-21-2011, 07:51 AM   #94
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,462
FWIW. :)
Actually, I'm pretty sure he meant 118mm
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 10-21-2011, 08:05 AM   #95
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Thanks for catching the typo guys, it's 118mm and has been corrected.
Interesting how the length jumps an entire half a millimeter when they went to the large spigot jugs in 1976
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 10-21-2011, 08:22 AM   #96
robtg
Oddometer: 647
Would that be to make up for the aluminum gasket used before '76?
robtg is offline   Reply With Quote
Old 10-21-2011, 08:29 AM   #97
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
BINGO! if you smoked Bob, I'd send you a cigar!
www.wirewerkes.com
Old 10-21-2011, 08:31 AM   #98
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
To be honest, I've been waiting the entire thread to bring this up.
It's the first thing that popped into my head when all this started.
I was just having a blast reading all the "theories".
www.wirewerkes.com
Old 10-21-2011, 11:20 AM   #99
Bill Harris
Oddometer: 7,441
Dang, we're all mostly blind...
'73 R60/5 Toaster
Old 10-21-2011, 11:30 AM   #100
supershaft
Oddometer: 9,110
However it was written I read as a half mm.
For some reason the the /7 750 escapes my reasoning sometimes but that subject is longer, not shorter than a /5 cylinder?
Old 10-21-2011, 12:26 PM   #101
mykill
odd
mykill's Avatar
Oddometer: 1,160
Interesting! Good call Bob! I might have the opposite issue. Not to derail, but I think this might be the answer to my thinking my CR was down from expected 10.5:1 on my race bike. I have too much head/ valve/ piston clearance, but need to go back and measure everything again.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 10-22-2011, 01:11 AM   #102
wmax351 OP
Oddometer: 743
76 and later are running around 118mm even or thereabouts.
Just measured mine. A quick check put it at ~4.624 inches, (117.4496 MM). Will check again in the morning.
Old 10-22-2011, 10:25 AM   #103
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
You PUI there Robert?
datchew is offline   Reply With Quote
Old 10-27-2011, 06:09 PM   #104
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
In English please?
www.wirewerkes.com
Old 10-27-2011, 08:32 PM   #105
supershaft
Oddometer: 9,110
My point exactly. Longer /7 jugs are going to increase piston/valve clearance, not decrease it?
Times are GMT -7.   It's 10:06 AM.
