Old 10-03-2011, 01:31 PM   #1
Soberman001 OP
Soberman001's Avatar
Oddometer: 735
Sticky house doors??
Guys
I have a 20 year old house that, like most homes, has the occasional sticky door depending on the time of year and temp/hum% in the house. The doors barely stick so it isn't worth the time to get out a sander or door plain and deal with the mess and then matching the right paint color to the right door.
I saw an add on TV a couple weeks ago for a lubricant that can be used on finished wood, latex paint, and other non-metal items. Not sure what this stuff was but it was advertised to go on dry which is vastly different from silicone or petrol based lube.
Anyone got a easy solution that won't make a mess or ruin my doors?
Thanks!!
Soberman001 is offline   Reply With Quote
Old 10-03-2011, 01:42 PM   #2
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 7,547
Send a message via MSN to rapidoxidationman
length of 2X4 wood
2-4 # hammer, mallet, sledge, whatever
rest 2x4 on its edge against door jamb where things stick
hit 2x4 with hammer until the door closes cleanly in the opening.
done, and if you did it right there's no evidence.
Unless your house was extraordinarily well built you should easily be able to adjust the doorjamb to fit the door.
I know I'm feeling badly when I have no interest in speeding
Patrick
rapidoxidationman is offline   Reply With Quote
Old 10-03-2011, 01:44 PM   #3
Soberman001 OP
Oddometer: 735
Originally Posted by rapidoxidationman View Post
length of 2X4 wood
I shoud have done a better job of explaining that 70% of the doors in quesion are french (dual) doors with no frame between the doors.
I like your solution for the other doors but I would be very concerned about messing it up.
Old 10-03-2011, 02:21 PM   #4
speedracertdi
speedracertdi's Avatar
Oddometer: 979
For double doors, try tightening the hinge screws that go into the jamb. It will pull the doors apart a little when closed. For a lubricant.....maybe wax?? Something that won't stain, run, or soak into the paint and wood.
Roads? Where we're going we don't need roads.
-Doc Brown
speedracertdi is offline   Reply With Quote
Old 10-03-2011, 03:45 PM   #5
the_gr8t_waldo
Oddometer: 1,867
if the most effort you want to put into this project is lubing--use bee's wax
the_gr8t_waldo is offline   Reply With Quote
Old 10-03-2011, 06:35 PM   #6
anonny
What could go wrong?
anonny's Avatar
Oddometer: 4,985
Take the doors by the handles and lift and push down when the door is in the almost closed position, if there is play the screws holding the hinge to the door or jamb need attention.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 10-03-2011, 08:11 PM   #7
rapidoxidationman
Easily trainable
Oddometer: 7,547
Ok, next solution:
If the doors need to be straightened up in relation to each other (making them parallel) that can be done with a bit of gasket paper (or a cereal box if you're a KLR rider...). Putting a layer of paper (or 3) behind each hinge can make quite a difference when it comes to adjusting the way doors fit together. Make sure the hinge screws aren't stripped though, like somebody already pointed out. If they are, toothpicks are your best friend for filling the stripped out holes: Pack a few picks in the hole - with a bit of wood glue if you're so inclined - and put the screw back in. LONGER screws will get you into the door's rough-in framing and may give you the pull you need to square things back up. Just make sure the screw head is big enough to not pull through the hinge.
Patrick
Old 10-04-2011, 05:03 AM   #8
Soberman001 OP
Oddometer: 735
Thanks boys!! I now think I have a solution for each of the problems. Bit of bees wax, and some help on the hindges.
Thanks for all the help!
Old 10-04-2011, 07:01 AM   #9
Fire Escape
Fire Escape's Avatar
Oddometer: 1,146
Thumb Door-Eze
I have used a product called Door-Eze for about 40-50 years. It is basicly a stick of bee's wax with a paper wrap, kinda like a big crayon. I haven't looked for it in some time so availability is up to question these days. Back in the 70's and 80's when I was diving a lot it came included with some diver's dry suits as a zipper lube/sealant so it might be sourced at a dive shop if you can't find it in the local hardware.
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco, TKCs summer/17" SM wheels winter 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is offline   Reply With Quote
Old 10-04-2011, 07:03 AM   #10
Soberman001 OP
Oddometer: 735
Bruce
This stuff?
http://www.acehardware.com/product/i...ductId=1415925
Old 10-04-2011, 07:54 AM   #11
HamboneSlim
ಠ_ಠ
HamboneSlim's Avatar
Oddometer: 3,286
Sighhhh...
Avoiding an opportunity to use man toys...
...or aquire new man toys...
is just plane wrong!
Remember, the fact that we can fix stuff is one of the few things women like about us.
No need to thank me; we're all in this together. Just doing my bit to help a fella out.
Lost on a wave that you're dreaming
Dream on, on to the heart of the sunrise.
Sharp, distance -
How can the wind with it's arms all around me?
HamboneSlim is offline   Reply With Quote
Old 10-05-2011, 09:15 AM   #12
FatChance
Road Captain
FatChance's Avatar
Oddometer: 9,368
"If the women don't find you handsome, they should at least find you handy."
- Red Green
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance is offline   Reply With Quote
Old 10-05-2011, 07:39 PM   #13
JED
Oddometer: 476
For slight stik trouble, just rub the tight area with a candle. The wax works for me.
JED is offline   Reply With Quote
Times are GMT -7.   It's 02:44 AM.
