Old 10-05-2011, 11:16 AM   #1
Milehi OP
Milehi's Avatar
Oddometer: 168
Header wrap, good or bad ??
I am looking into keeping some heat off of my voltage regulator on my SE by wrapping the short section of exhaust that runs under that area. I have done this for decades on sportscars and hotrods, but get raised eyebrows when mentioned around bike people. How can an exhaust tube on a bike overheat by being wrapped when a mild steel V8 header primary tube, under a car hood, tolerates it just fine and lowers the underhood temp as well? Thanks.
Milehi is offline   Reply With Quote
Old 10-05-2011, 11:19 AM   #2
Flanny
Flanny-it-up!
Flanny's Avatar
Location: Ottawa, Ontario, Canada, the World, the Universe
Oddometer: 2,738
There's no problem, it will just cause the pipe to corrode that's all.
Instead of wrap, can you consider some flashing instead?
Flanny is offline   Reply With Quote
Old 10-05-2011, 11:21 AM   #3
MrPulldown
MrPulldown's Avatar
Oddometer: 3,391
What I hear is that it gets wet and traps moisture, then your headers rust. Even Stainless can get corroded is subjected to a rough enough enviroment.
MrPulldown is offline   Reply With Quote
Old 10-05-2011, 11:25 AM   #4
950TRANSALP
950TRANSALP's Avatar
Oddometer: 794
428 Ford
Years ago I burned up a set of headers on a street car by wraping them , I'm sure the Ohio road salt helped a bit . But they only lasted maybe 6 months .
950 steel pipes can be cerramic coated to keep the heat down , can you just move the regulator a bit ?
"The more you drive the less intelligent you are !"
Repo Man - 1984
950TRANSALP is offline   Reply With Quote
Old 10-05-2011, 12:40 PM   #5
River6822
Fat kid on a 950 SE
River6822's Avatar
Oddometer: 361
Voltage Reg
I've added a little self adhesive heat shield tape to the bottom of the bracket. I'm hoping that it dissapates the heat a little. It certainly can't hurt and it's cheap.
I know others have moved it completely.
Don't do the wrap, you'll corrode the pipes. Ceramic coating is a better option. Cools things a bit. Not so cheap.
If you really want to reduce overall exhaust temp, run an aftermarket exhaust and an H2W jet kit. Expensive.
2013 KTM 1190 Adventure
2007 KTM 950 SE
2004 KTM 450 EXC
1979 Suzuki GS850
1993 Harley Café Project
River6822 is offline   Reply With Quote
Old 10-05-2011, 02:20 PM   #6
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 525
My 2 cents of experience,
I put header wrap on my "hot rod" years ago and my headers never rotted. Of course I never had to take the wrap off so don't know for sure but 10 years and the wrap never came off and the pipes never succumbed to rust.
Why? I painted them with header wrap paint. I really soaked them well. The wrap takes on a new character and appears to be water proof and becomes much more durable. Thus in my experience if you paint the wrap the headers are not hurt by moisture.
kj
* But this was in California so no road salt, except in the mountains. So if your roads are salted in winter all bets are off that your headers will survive.
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008 now has 520 Thumper Racing kit
KTM 990 Adventure 2008
knobbyjoe is offline   Reply With Quote
Old 10-05-2011, 02:29 PM   #7
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,758
http://www.advrider.com/forums/showt...ader+pipe+wrap
Originally Posted by WaterWheel View Post
The things I would do with that old broad would make a seasoned porn producer puke.
KTMSER is online now   Reply With Quote
Old 10-05-2011, 06:05 PM   #8
countersteer
countersteer's Avatar
Oddometer: 93
Ceramic coating wins on every level. Did it on my supermoto's and my 950 is next. Best when the pipes are new but good anytime.
______________
2003 Honda 900RR
2004 Suzuki DRZ400 S/SM
2004 KTM 950 Adventure
2008 Husky SM610
countersteer is offline   Reply With Quote
Old 10-05-2011, 07:40 PM   #9
bikepsych
Oddometer: 279
I'm not sure but keeping heat in rather than getting the heat out doesn't seem to be a good idea to me. Anytime you are increasing internal heat no matter where in the bike I wouldn't think this is going to help. Is there some thermo dynamic aspects of wrapping the headers I'm not aware of? I think it WOULD make sense inside of an engine compartment to keep the heat out of there, however in our bikes we already have a problem keeping them cool.
Thoughts?
B
Bruce
Camarillo, CA
2015 Triumph Tiger 800 XCx
2009 Harley Road Glide
2006 Buell Ulysses
bikepsych is offline   Reply With Quote
Old 10-05-2011, 09:47 PM   #10
mousitsas
mousitsas's Avatar
Oddometer: 2,948
Thoughts?
B
Thermo-dynamically speaking, by insulating the headers, you gain more power (and efficiency) due to higher gas velocities through the pipes.
mousitsas is online now   Reply With Quote
Old 10-06-2011, 01:08 AM   #11
68deluxe
68deluxe's Avatar
Oddometer: 14,495
Just make sure it is real ceramic. Some companies basically just paint the exhaust. Cannot remember the name of the recommended company.
2004 KTM 250SX
68deluxe is offline   Reply With Quote
Old 10-06-2011, 03:13 AM   #12
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,850
i've used thermo-tec many years ago & found moisture stays between the wrap & pipe & will rust/corrode it away.
jethot coat is the way to go.
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Old 10-06-2011, 08:23 AM   #13
Milehi OP
Milehi's Avatar
Oddometer: 168
Skip the wrap
You guys got me away from the wrap, thanks. I made a cool little heat shield under the r / r area. It is held in place by the two bolts in the bottom of the battery box. I contoured it to clear the spring nut and res. put some thermo tec mat on the bottom, gave it a swirl finish with the 3M pad- good to go. I thought this looked better than fitting one to the pipe. Still waiting for my v.reg. though, I may order another to keep on hand,
Old 10-06-2011, 02:01 PM   #14
countersteer
Oddometer: 93
Completely agree about real. I use Jet Hot for mine. Great service and product at least in my experience.
______________
2003 Honda 900RR
2008 Husky SM610
Times are GMT -7.   It's 12:36 AM.
