Old 10-07-2011, 03:09 PM   #1
Rich-in-GA OP
Oddometer: 52
Dangerous front wheel wobble at high speeds.
I was driving home today from a 5 day trip and experienced a near disastrous and uncontrollable front wheel wobble at 92 mph. I had been cruising along between 70-80 mph with no problems, but I accelerated to over 90 to pass a truck when my front wheel began wobbling uncontrollably. I backed off the throttle and eased on the brake, and the wobble went away at slower speed. I pulled off the next exit to check the tire and wheel.....Everything looked fine.
I run TKC80's on my GS.....Is the high speed wobble due to the tires or wheel balance, or is it something else?
Rich-in-GA is offline   Reply With Quote
Old 10-07-2011, 03:15 PM   #2
whisperquiet
whisperquiet's Avatar
Location: 62298 in lovely corrupt/bankrupt Southern Illinois
Oddometer: 976
Are your saddle bags fully loaded and a lot of the weight up high? The trunk on many bikes, your body, and the windshield cause some weird riding dynamics at times and can cause a higher speed wobble. Most bike manufacturers have warning stickers on the luggage/top trunk warning against speeds over 80 MPH....
whisperquiet is offline   Reply With Quote
Old 10-07-2011, 03:18 PM   #3
mattjw916
never wears lip balm
mattjw916's Avatar
Oddometer: 310
How was your bike loaded, suspension set, and tire pressures? I generally wouldn't recommend doing over 90 with knobbies and a big load on the bike like bags and crap strapped to it...
My RS used to get all sloppy with the panniers on as well over 90mph regardless of how it was loaded...
mattjw916 is offline   Reply With Quote
Old 10-07-2011, 04:00 PM   #4
Rich-in-GA OP
Oddometer: 52
I had 34 psi on the front tire and 36 on the rear. Bike was fully loaded Vario side and top cases......Maybe the additional weight in the rear combined with riding on knobbies caused the wobbling.
Old 10-07-2011, 04:51 PM   #5
viz
I Ride Ms Piggy
viz's Avatar
Oddometer: 1,813
What you want is this
viz
Pig In The City - 2010 BMW R1200 GSA Adventure
Webmaster BMW Touring Club of NSW
viz is offline   Reply With Quote
Old 10-07-2011, 05:03 PM   #6
erkmania
Still Adventuring
erkmania's Avatar
Oddometer: 986
I agree with the others that mention heavy weight in the rear and some of that up high. You might try preloading the rear spring some to transfer more weight/force onto the front tire. If you have the adjustment then you might also want to increase your rear shock's compression setting.
The most likely cause, in my mind, is that the rear tire has worn more appreciably than the front during your trip (guessing 1750 miles or so) and the geometry has been upset a bit. I feel confident that new tires would eliminate the sensation also.
Now, slow down and smell the truck exhaust.
-Sticks and stones, love.
-Insurmountable problems exist in the imaginations of the less traveled.
2011 BMW R1200GS, 2004 KTM 950, 1996 ATK 605 ESDS
erkmania screwed with this post 10-07-2011 at 05:17 PM
erkmania is online now   Reply With Quote
Old 10-07-2011, 05:25 PM   #7
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,916
Check your rear wheel, FD and swingarm bearings.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 10-07-2011, 05:29 PM   #8
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,786
Did you adjust your suspension to compensate for the weight?
Old 10-07-2011, 06:48 PM   #9
Rich-in-GA OP
Oddometer: 52
The suspension is set as frim as possible.....But it's the original OEM factory shocks and the bike has 20,000 miles, with about 25% of those miles off road. The shocks are worn. I'm looking to replace them with new Ohlins but I just don't want to drop the bucks right now.
Old 10-07-2011, 07:10 PM   #10
marty hill
The Energizer Bunny
marty hill's Avatar
Oddometer: 4,286
I've never used the tires your using but your pressures seem way low for a loaded bike.
ride till you can't.
1200GS/black
Boxer Cup Replika/red-white-blue
Semper Paratus
marty hill is offline   Reply With Quote
Old 10-07-2011, 07:18 PM   #11
slartidbartfast
Oddometer: 4,916
If you mean the preload is maxed out, it's not the same as "as firm as possible" and maxing out on the damping is not right either. Furthermore, you may well find that max preload isn't max any more - or even close. See here for details but check rear end for movement and check bearings as suggested and I suspect you'll find your problem. Agree that your tire pressures seem a bit low for high-speed heavily laden running but that shouldn't cause a high speed wobble by itself.
Old 10-08-2011, 06:29 AM   #12
mattjw916
mattjw916's Avatar
Oddometer: 310
Too low of tire pressures and suboptimal weight distribution get my vote.
Old 10-08-2011, 10:20 AM   #13
Stegerman
MotoOCD sufferer
Stegerman's Avatar
Oddometer: 588
Ding ding ding ding....we have a winner.
2000 R1150GS- ZenPig
2003 F650GS (sold)
formally trained to screw with people's minds..
Stegerman is offline   Reply With Quote
Times are GMT -7.   It's 10:05 PM.
