Old 10-07-2011, 06:32 PM   #1
Tslepebull OP
Snakecharmer
Tslepebull's Avatar
Oddometer: 265
fluid leak after brake pad change
I replaced the rear brake pads on my 05 GS today. They really needed it so the pistons were extended all the way out. After I pushed them back and replaced the pads I noticed what looked like brake fluid dripping out from under the tank and transmission. I had wrapped a rag around the brake fluid reservoir in case it leaked but this is not where it came from. The brakes with the new pads seem to work fine, I get no brake fault signal and there is no wet place on or underneath the ABS unit. Where was the fluid coming from and do I have a problem?
This is one of the servo brake models so things are a bit more complicated.
Tslepebull is offline   Reply With Quote
Old 10-07-2011, 06:42 PM   #2
Mudcat
Unregistered
Mudcat's Avatar
Oddometer: 4,472
The brake fluid was coming from your ABS servo unit. It had been over filled at some point, nothing to worry about. Just don’t let the fluid get on painted surfaces.
Also, it sounds like you need a new rear rotor. I bet it is out of spec, that is why your caliper pistons are extending so far.
I've got to be cool
Relax
Take a long long ride on my motor bike
Untill I'm ready
Mudcat is offline   Reply With Quote
Old 10-07-2011, 07:08 PM   #3
Tslepebull OP
Snakecharmer
Tslepebull's Avatar
Oddometer: 265
Thanks Mudcat. I made the same conclusion that the fluid was because I had pushed the pistons back in (the pads were completely gone). I can't find any evidence of wetness on the ABS unit but the drip was definately under it. My question is where did the fluid get out? I was concerned that if fluid could get out, air or water could get in. If there is a problem will I get an ABS fault?
BTY I measured the rotor and it is still in spec; the pads were really really worn. The observation holes in the front were worn through. It has been nearly 40 K miles since I replaced the first set and I wouldn't have wanted to drive 100 more miles on them or I would have scored the rotors. I got lucky.
I checked the front pads also and with nearly 60K miles they still look fine.
Tslepebull screwed with this post 10-07-2011 at 07:24 PM
Old 10-07-2011, 07:38 PM   #4
Mudcat
Unregistered
Mudcat's Avatar
Oddometer: 4,472
Originally Posted by Tslepebull View Post
. I can't find any evidence of wetness on the ABS unit but the drip was definately under it. My question is where did the fluid get out? .
It came out the drains at the top of the ABS servo unit, they are just below the filler caps. They converge into one line going down the right side of the unit. Where it ends I could never tell.
BTW overfilling the unit is not a problem, under filling it is.
I've got to be cool
Relax
Untill I'm ready
Old 10-07-2011, 08:07 PM   #5
Tslepebull OP
Snakecharmer
Tslepebull's Avatar
Oddometer: 265
Thanks again Mudcat. I had just found a post by JVB using the search function that referred to the overflow tube and this is exactly what I was seeing. I will go relax and drink a homebrew now.
BTY Mudcat or (bullhead catfish) is also known as Ameiurus natalis for the yellow bullhead or Ameiurus melas for the black bullhead -- both common here in Texas. Not that most of the world beyond the American Fisheries Society cares.
Old 10-08-2011, 02:32 AM   #6
Mudcat
Unregistered
Mudcat's Avatar
Oddometer: 4,472
I had just found a post by JVB using the search function that referred to the overflow tube and this is exactly what I was seeing. I will go relax and drink a homebrew now. .
Yes, overflow tube is a much better description then what I posted. JimVonBaden is very good.
When you compress the caliper pistons this raises the fluid level in the ABS servo unit. If the unit had been overfilled some fluid will likely be expelled. This is relatively harmless.
An indicator of low brake fluid in the ABS servo unit is a shut down of the ABS servo unit under hard braking. Very unsettling and very dangerous.
If you should ever drop your bike, especially on the right side, there is a substantial chance you have lost fluid from the servo.
I've got to be cool
Relax
Untill I'm ready
Times are GMT -7.   It's 09:04 PM.
