Old 10-29-2013, 06:19 AM   #571
MarcParnes
Tinkerer
MarcParnes's Avatar
Oddometer: 437
Originally Posted by JetSpeed View Post
Have you put your Sena in "Phone" mode?
What exactly are you referring to when you say "phone mode"?
Marc
Marc Parnes
'14 R1200RT
BMW Wheel Balancer and Tools
A life of bikes
MarcParnes is offline   Reply With Quote
Old 10-29-2013, 06:21 AM   #572
BMW_Ken
BMW Rider
BMW_Ken's Avatar
Oddometer: 49
Originally Posted by mefly2 View Post
Thank you Paul and JetSpeed ...it was, indeed, on auto and it needed my touch to get the display brightness up to where it is more useful ... darn, it is heck getting old! Great bike, great Nav, great forum, with great folks!
For some reason, I am not able to select the "auto brightness" in the display settings menu. It is grayed out. My unit is on a 2011 R1200RT in the BMW Nav V cradle.
Wonder if my unit is defective, or does it have to be on a GS or KGT for this function to be activated??
Ken Martin
2011 R1200RT, 2007 Aprilia Tuono, 2004 R1150RT(sold), 2002 Ducati 748(sold)
BMW_Ken is offline   Reply With Quote
Old 10-29-2013, 06:31 AM   #573
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,340
Marc
On my F5XD I can scroll thru settings such as Intercom, Music Streaming, Phone etc. I would suspect that the SMH10 has similar menu capability?
One other thing is make sure that your Sena has the latest firmware installed.
If you remove the Nav-V from the cradle is the Auto Brightness selection available?
Although I have found that full bright works best for me.
Pull chocks.
JetSpeed is offline   Reply With Quote
Old 10-29-2013, 06:38 AM   #574
BMW_Ken
BMW Rider
BMW_Ken's Avatar
Oddometer: 49
No, I have never been able to select it, even out of the cradle.
Ken Martin
Old 10-29-2013, 07:45 AM   #575
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,340
Upon further review it appears that Auto Brightness is only available if connected to the BMW cradle on certain model bikes, the GSW for one and probably the large K bikes, there must be an ambient light sensor that the GPS has to interface with on the bike.
Pull chocks.
Old 10-29-2013, 08:53 AM   #576
MarcParnes
Tinkerer
MarcParnes's Avatar
Oddometer: 437
Ok, I did the 2.50 update, cleared all the pairings and tried again. Same result, it rings but the gps won't answer it. I've tried HFP between the Sena and the Nav but it doesn't change anything. I'm beginning to think the issue is between the Android phone and the Nav but there aren't really any options to fool with. The Sena direct to the phone works fine, put the Nav in the middle and no dice. I HATE to give up!
Marc
Marc Parnes
'14 R1200RT
A life of bikes
Old 10-29-2013, 08:54 AM   #577
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,080
Did you do the upgrade yet? Maybe it would help?
Old 10-29-2013, 09:08 AM   #578
gr8ridn
gr8ridn's Avatar
Oddometer: 405
Thanks for the heads up on the update. There are some significant upgrades in this software. I'll update mine today.
2014 R1200GSAW
Racing Blue, Premium Group, DWA
gr8ridn is offline   Reply With Quote
Old 10-29-2013, 09:26 AM   #579
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,340
Marc
Have you cleared the phones cache and done a hard reset on the Nav-V?
Pull chocks.
Old 10-29-2013, 09:29 AM   #580
MarcParnes
Tinkerer
MarcParnes's Avatar
Oddometer: 437
Cry
Just got off the phone with Garmin's OEM tech support. They don't have a compatibility list of phones yet for starters so they don't know if it should work. He noted down the problems and will submit them to the IT team for resolution. In the meantime he recommended hooking up to Express periodically to see if there are any new updates that might address this. In the meantime it looks like its a no-go :-(
Marc
Marc Parnes
'14 R1200RT
A life of bikes
Old 10-29-2013, 09:38 AM   #581
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,340
Marc
So you're not going to try anything suggested then?
It's not a compatibility issue between your phone and the Nav-V or SMH10, I promise.
Pull chocks.
Old 10-29-2013, 09:41 AM   #582
MarcParnes
Tinkerer
MarcParnes's Avatar
Oddometer: 437
Actually I tried everything suggested to no avail. I did wonder what you meant by putting the Sena in "phone mode". I'd love to get this thing working but I just don't know what else to try.
Marc
Marc Parnes
'14 R1200RT
A life of bikes
Old 10-29-2013, 10:08 AM   #583
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,340
Marc
You cleared the phone cache? Very important.
SMH10 headset has latest firmware, what version?
Make sure that "Discoverable" is not left on in Bluetooth menu on Nav-V as well after everything is paired, this caused me some problems.
Evidently your device doesn't have a selectable phone mode, just wondering how you go about placing a phone call if you don't have a phone mode?
Pull chocks.
Old 10-29-2013, 10:22 AM   #584
MarcParnes
Tinkerer
MarcParnes's Avatar
Oddometer: 437
I have not cleared the phone cache yet. I'll do that this afternoon and try pairing again. I made sure to take the Nav out of discoverable mode. A phone call is placed by touching the phone button on the side of the unit which puts the phone in voice command mode. If a call isn't made it times out of this mode. The newest firmware also gives three speed dial options. I have the very latest firmware loaded. Its the beta version which gives you music sharing.
I do appreciate the help.
Marc
Marc Parnes
'14 R1200RT
A life of bikes
Old 10-29-2013, 10:40 AM   #585
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,340
Also hard reset the Nav-V and you may want to try resetting the SMH10 first insert a paperclip into the small hole in the back of the unit then push and hold the Phone button for 12 seconds to completely reset the device.
I had a hard time getting mine working correctly but after resetting everything I was able to and it has worked perfectly ever since.
Pull chocks.
Times are GMT -7.   It's 10:53 AM.
