Old 11-02-2013, 01:57 PM   #616
R1200GSA
R1200GSA's Avatar
Oddometer: 352
Picked mine up this morning.
It is currently updating... now to go and mount the "mount" and wire it up.
Duke
R1200GSA is offline   Reply With Quote
Old 11-02-2013, 02:25 PM   #617
R1200GSA
R1200GSA's Avatar
Oddometer: 352
well that was a quick trip to the garage.
I pull the mount out of the packaging and it has 2 proprietary plugs.
Does anyone know of a harness that I can purchase (or the mating plugs) so I can just wire it up to my fuse block. I am going to share this between my 2006 GSAdv and my 2002 RT.
I will be getting a new GSAdv next year so I don't want to cut the wires on the mount if I don't absolutely need to.
Duke
R1200GSA screwed with this post 11-02-2013 at 02:45 PM
Old 11-02-2013, 03:02 PM   #618
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,007
Originally Posted by Emoto View Post
UPDATE: I have received a plug and given it a quick test fit to the one on the GPS Prep harness. It fits!
The next step will be to run it to some sort of headset or speaker or something and cause the Nav V to give some sort of spoken direction to confirm that audio is indeed output from that lead. Will update again after I have done that.
The plug is part number:
83 30 0 402 342
TL;DR: Success!
I have confirmed that the Nav V puts out turn-by-turn spoken directions via the smaller plug on the mount harness. I wired a 3.5mm socket to the wires off the mate to the small plug, and zip tied it up near the cockpit power socket. A patch cord takes its output to my MixIt2. I just went for a little ride and punched in a destination and it happily directed me along the route. What a relief. Now I don't need to dick around with Bluetooth unless I want to.
To R1200GSA: See above in this post for the smaller plug you need. Any BMW parts department should be able to ID the other one for you, as it is stock on a 2013-14 R1200GS harness.
Old 11-02-2013, 03:27 PM   #619
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,137
Install a mount on each bike.
Remove chocks and chains.
JetSpeed is offline   Reply With Quote
Old 11-02-2013, 04:02 PM   #620
gr8ridn
gr8ridn's Avatar
Oddometer: 395
Your 2006 GSA will have a power plug for the supplied cradle. As mentioned get a 660 cradle (it fits and charges the Nav V) for your other bike and wire that in as you would with any add on. The additional cradle will cost about $45.00 from GPS city or any other outlet. Now you have the GPS for either bike and you are ready for your new bike.
2014 R1200GSAW
Racing Blue, Premium Group, DWA
gr8ridn is offline   Reply With Quote
Old 11-02-2013, 04:38 PM   #621
R1200GSA
R1200GSA's Avatar
Oddometer: 352
TL;DR: Success!
Thanks for the help all.
I have a 660 cradle ordered for Bike #2 ('02 RT), and I have mounted the 4 button BMW mount on my GSAdv by just posi-tap'ing the 12v wires from the supplied harness.
I am officially retiring my old 376c....
PS. This thing is still updating!!!!!
EDIT: 17:50
Duke
R1200GSA screwed with this post 11-02-2013 at 04:48 PM
Old 11-02-2013, 05:25 PM   #622
Strelnikoff
Oddometer: 1
Nav 4 & 5
Originally Posted by labenske View Post
BSing with the dealer a couple days ago. Said he learned at the recent BMW conference that the Navigator V will be based on the zumo 665. He didn't have a release date.
Is it worth the wait or is it better to just go with the 665?
They are both made by Garmin. If you get a Garmin you apparently have life time upgrades. I just picked up the counter demonstration model Nav 4, after my old one went electronic psycho, in a really good deal. If you wire a GPS up hot to the batt. put a cutoff switch in line to cut off power to the key pad / mount when not in use. There is circuitry in the cradle that will stay on and lead to early failure. Does anyone know how to hook up audio to the brown & white wires ?
Strelnikoff is offline   Reply With Quote
Old 11-02-2013, 08:12 PM   #623
Voz
Voz's Avatar
Oddometer: 465
Originally Posted by Bails View Post
Why not run the music from the NAv, you can change tracks shuffle and do all this and don't have to be running the phone battery down.
I do not want to be bothered transferring music to the Nav V, I want to leave the music in my iPhone. So, can this be done? To reiterate, I would like to know if the Nav V can do the following:
1. Iphone 5 IOS 7.03 Bluetooth connect to NAV V
2. Scala G9 Bluetooth connect to Nav V
3. Access Music on iPhone and use Scala G9 next track buttons
4. Access Siri & other normal iPhone functions accessable from the Scala G9 to the iPhone as if the Nav V was not even there.
Thanks.
Sydney, Australia
2013 R1200 GSW Red - Blown Engine & Gearbox (clutch basket nut issue) - AUG 14
2015 R1200 GSW White - NOV 14
Voz is offline   Reply With Quote
Old 11-03-2013, 03:00 AM   #624
erey
erey's Avatar
Oddometer: 60
Any idea how to change the splash screen on the Navigator V?
erey is offline   Reply With Quote
Old 11-03-2013, 05:04 AM   #625
Jarvis
DC GSer
Jarvis's Avatar
Oddometer: 10,702
Thanks.
I do not know re: Scala G9. You can with Sena. I explain the procedure in a post earlier in the thread.
Support DC voting rights.
Jarvis is offline   Reply With Quote
Old 11-03-2013, 05:56 AM   #626
ScooterME
Oddometer: 5
Thanks.
+1
I'm looking for this functionality too. Heck, I'd love them to go the whole hog and include the iOS in the car features.
ScooterME is offline   Reply With Quote
Old 11-03-2013, 07:05 AM   #627
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,137
Don't mount it just yet.
You may want to try just shaking hands with it, until you see how you like it.
Old 11-03-2013, 10:36 AM   #628
R1200GSA
R1200GSA's Avatar
Oddometer: 352
Ha.. I LOL'd
Duke
Old 11-03-2013, 11:28 AM   #629
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,137
Well hell yeah you did. That's funny shit right there.
Old 11-03-2013, 12:08 PM   #630
atg
Oddometer: 202
Yesterday I went for a ride and when I got back checked my "V" to see my top speed: It registerd that I reached 515 Km ( 320 miles ) !!!
I new that the GSW fast fast but didn't think it was that fast...
Seriously, has anyone seen such errors in the "V" ? Mine is updated to 2.50 and I believe that there must be some bug in its software.
Andre
atg is offline   Reply With Quote
Times are GMT -7.   It's 11:26 PM.
