Old 11-12-2013, 08:42 AM   #676
biker2hiker
4dirt
biker2hiker's Avatar
Oddometer: 102
The BMW NAV connects to the harness behind the headlight. There's an empty connection that mates with the GPS plug. It may be cable tied to prevent hanging loose . Hope this helps.
biker2hiker is offline   Reply With Quote
Old 11-12-2013, 11:14 AM   #677
pklop
shit happens
Oddometer: 71
Navigator V problem
My Nav V has a problem with the calculation of routes that contains rivers. This problem occurs when i select that he should avoid highways (while everything else is allowed). Under these circumstances he calculates ridicules routes that are hours and hundreds of miles longer then needs to be. The Nav IV does not have this problem in comparisons.
I live in The Netherlands so we have a lot of rivers. Because of this problem i won't sell my Nav IV so i can fall back on it.
My BMW dealer has seen and confirmed the problem. Garmin Europe won't acknowledge the problem however and i am not inclined to pursue this matter further. I did install the latest software and maps but to no avail.
pklop is offline   Reply With Quote
Old 11-13-2013, 07:18 AM   #678
Brahma
Oddometer: 312
I can't believe the purpose-designed, most expensive motorcycle GPS in the world has problems.
Brahma is offline   Reply With Quote
Old 11-13-2013, 07:47 AM   #679
IB1
IB1's Avatar
Oddometer: 988
Have you tried to put "veerboten" on? I recently had a problem in the netherlands and found out it tried avoiding the ferries.
Past bikes: 09 BMW F800ST
Current ride: 2013 BMW R1200GS
On order: 2015 BMW R1200GSA
Yes, still a rookie
IB1 is offline   Reply With Quote
Old 11-13-2013, 07:56 AM   #680
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,007
New to Garmin, are you?
Old 11-13-2013, 08:16 AM   #681
mefly2
mefly2's Avatar
Oddometer: 1,201
Although there are two connectors leaving the Nav harness, the Nav cradle only connects to one on the bike ... I took off all of the Tupperware looking for the other connection and finally gave up. Then, my dealer tech told me that the same Nav harness is used on the K-bikes with an audio system.
----------------> jer-
30+ years with RTs...then to F/GS; now *Finally*
the BMW: R1200GSW, factory low seat & lower crash bars;
Touratech: Upper Crash Bars, big foot, pannier rack, ZegaPro panniers;
Fuzeblock, Rigid Dually D2 + yellow covers; Wunderlich bar risers w/ Q-adjust
mefly2 is offline   Reply With Quote
Old 11-13-2013, 08:44 AM   #682
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,007
Yes. You can get turn-by-turn audio directions out of that smaller connector, if you want.
Old 11-13-2013, 09:35 AM   #683
Amania
Amania's Avatar
Oddometer: 104
ear buds
would this be a way to get music and phone
using ear buds ?
I don't ride a BMW GS because I want to
I ride one because I need to
2014 r1200gs
Amania is offline   Reply With Quote
Old 11-13-2013, 09:53 AM   #684
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,138
using ear buds ?
No!
Only nav instructions.
There are some marvelous Bluetooth headsets on the market that allow for music and phone audio........and turn by turn as well.
Remove chocks and chains.
JetSpeed is offline   Reply With Quote
Old 11-13-2013, 11:24 AM   #685
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,007
Originally Posted by JetSpeed View Post
No!
This is one that works: http://www.amazon.com/Jabra-CLIPPER-...etooth+headset (although there may be better similar products out there, I don't know).
You could use a patch cord (instead of headphones) from the output to whatever sort of audio system you have, if you wanted to.
Old 11-13-2013, 02:15 PM   #686
Brahma
Oddometer: 312
Old 11-13-2013, 03:39 PM   #687
pklop
shit happens
Oddometer: 71
I indeed did made sure that ferries where allowed. At first i too thought it was a settings issue like that, but that wasn't the case. Today my dealer told me they are going to pursue it further and when/if there is more information from Garmin i will post it here.
Old 11-14-2013, 11:02 PM   #688
Desert John
Desert John
Oddometer: 205
I nearly filled a 16GB card with music from my iTunes via my MacBook Pro and enjoyed music via my Sena bluetooth headset . . . and I took a phone call today, too. It works great, especially toggling between maps, fields, My Motorcycle and the music. Perfect!
'15 R1200GS LC
'14 Harley-Davidson FLHTK—yes, slightly liquid cooled
'05 Aprilia Tuono Factory R
Desert John is offline   Reply With Quote
Old 11-15-2013, 04:45 PM   #689
B00001
B00001's Avatar
Oddometer: 188
Quick question on Nav V before I drop the better part of a grand on this thing. How big of a PITA is it to set up a route on the computer and dump it onto the navigator for a trip? What is the EASIEST way to do this?
I currently use handwritten notes, basically a turn sheet, and works ok. I will look at the map and write out my route with dirt/gravel roads, rural routes, highways, etc. would be cool if I could build my route EASILY and have it on this new fangled technological wonder.
Side question- what if you are well into the route and decide you want to bypass a road or two? I guess it would just reroute you back to the route you had set up?
Thanks in advance!
2014 R1200GSLC
2013 ElectraGlide Classic
B00001 is offline   Reply With Quote
Old 11-15-2013, 07:51 PM   #690
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,007
Thanks in advance!
Well... Garmin's software is not terribly intuitive. It is fairly easy once you know how, but it will take you a bit of effort to learn how. Watch the BaseCamp tutorial videos. http://gpstracklog.com/2012/02/garmi...tutorials.html
Times are GMT -7.   It's 02:32 AM.
