Old 11-24-2013, 06:48 AM   #736
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,023
Originally Posted by JetSpeed View Post
I use the Nav-V in my truck with the Garmin 010-11270-02 Zumo cradle and it works perfectly receiving power via the pins.
So there has to be something wrong with your mount as previously mentioned.
Is there audio with that mount?
Old 11-24-2013, 07:49 AM   #737
Smoke Eater 3
Oddometer: 693
Alright, you guys have sold me. Getting my credit card out and placing an order today. Where should I order it from?
'14 GSW
'02 Aprilia Mille
'66 R50/2 with hack
Smoke Eater 3 is offline   Reply With Quote
Old 11-24-2013, 07:58 AM   #738
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,211
Negits.
I prefer to not use audio guidance, it drives me crazy.
I have an old Garmin GPS-V (not Nav-V) that simply beeps when a new instruction pops up, has worked very well for me for many years, still use it on my WR.
Pull chocks.
JetSpeed is offline   Reply With Quote
Old 11-24-2013, 04:34 PM   #739
Liquidape
Liquidape's Avatar
Oddometer: 71
Annoying startup screen
So how do you get the Nav V to stop asking you to Accept the End User License Agreements every time it starts up?
Liquidape is offline   Reply With Quote
Old 11-25-2013, 07:25 AM   #740
despistao
Oddometer: 101
Not sure with the Nav V but, on my previous Garmin Device, it stopped itself after several annoying restarts. But can't remember how many were them.
despistao is offline   Reply With Quote
Old 11-25-2013, 12:13 PM   #741
despistao
Oddometer: 101
Originally Posted by gr8ridn View Post
I checked it on the car cradle. The pin assignment should be the same for both car and motorcycle cradles for the power. If you are sure of your wiring I would suggest using a microfiber cloth dampened with a little rubbing alcohol and wipe the contacts of the cradle and Nav V. I would also double check the 12 V connection from the bike and verify power being supplied.
Ok, I think I finally found what was wrong.
As I understand, the Zumo's cradle needs 12v input and transforms it to 5v.
And i was connecting the cradle's wiring to another wiring from my previous satnav wich is on my bike, connected to the battery. But I didn't notice it has a built in 12v to 5v converter.
So i was feedind the Zumo cradle with 5v instead of 12v.
Old 11-25-2013, 02:38 PM   #742
Liquidape
Liquidape's Avatar
Oddometer: 71
Heh -
I have an old Quest ( actually 2 or 3 of them, but that's another story ) that I use on my WR as well. (X variant) Same basic size and layout as the GPS V. Perfect sized GPS for a small dual sport.
I need to take the lil' WR out soon. It hasn't seen any action since I got the GS at the end of August.
Old 11-25-2013, 07:04 PM   #743
gr8ridn
gr8ridn's Avatar
Oddometer: 409
Good to hear you found the problem.
2014 R1200GSAW
Racing Blue, Premium Group, DWA
gr8ridn is offline   Reply With Quote
Old 11-26-2013, 12:33 PM   #744
despistao
Oddometer: 101
Confirmed
The Zumo motorbike cradle is compatible with the BMW Navigator V and powers the device when connected to the battery (if you do connect it correctly )
Old 11-28-2013, 08:59 AM   #745
Mike M
Over Here Now...
Mike M's Avatar
Oddometer: 1,697
Confirmed
I'm going to get the Zumo car mount kit shown. I'm hearing the mount has a USB port on it to connect to power. Is that true or do you need a cig lighter power cord?
Mike M
2014 R1200GSA White
Mike M is offline   Reply With Quote
Old 11-28-2013, 09:30 AM   #746
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,211
The mount does have a mini-USB port on the back BUT for some reason it will not power the Nav-V via the port.
Pull chocks.
Old 11-28-2013, 11:12 AM   #747
Smoke Eater 3
Oddometer: 693
A&S Cycles has 15% off everything for Thanksgiving. I just bought a Nav V for $680 and free shipping.
'14 GSW
'02 Aprilia Mille
'66 R50/2 with hack
Old 11-28-2013, 11:25 AM   #748
Exos
Oddometer: 121
That makes thprice much more palatable.... But I'm still not convinced its worth it.
Exos is offline   Reply With Quote
Old 11-28-2013, 01:56 PM   #749
despistao
Oddometer: 101
Yep, i've found something strange about powering the Navigator V out of the cradle, e.g., when I'm just playing with it, uploading routes, ...
In fact, af first, i though it was something wrong with the battery as I wasn't able to charge the Nav V neither when connecting it to my computer (if the computer was switched on) nor with a wall charger wich worked ok with my previous sat nav.
But i noticed i can charge the Nav V via my computer only if the computer is
switched off, using one of those usb ports with permanente power delivery.
Strange.
Old 11-28-2013, 02:04 PM   #750
Bails
Bails's Avatar
Oddometer: 401
Negits.
You must have young eyes, I could not read a screen that small with that text interface. One of the reasons I purchased a Zummo 660 was it was the biggest screen available at the time.
If it has to Be then it's up to Me!
Bikes Multi Strada 1200 BMW GSA
Bails is offline   Reply With Quote
Times are GMT -7.   It's 10:37 AM.
