Old 03-12-2014, 03:30 PM   #1351
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,897
Originally Posted by Nick 187 View Post
Sir
Where did you get your car kit?
Also, a few weeks ago you gave a very detailed explanation regarding pairing iPhone 5s, Sena SMH10 and NAV 5. I followed instructions and was successful however Siri does not activate when I hold down phone button. This did not work prior or after iOS 7.1 upgrade.
Thank you.
Nick
Purchased the NAV5 Automotive Kit at my BMW Dealer--only place they are available.
On my SMH10-R, I hold the phone (middle) button down until I hear a Medium Tone followed by two Low Tones and then a High Tone at which point I release the button and wait until I hear the Siri (Voice Control) Chime from the phone. Then I speak....
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 03-12-2014, 03:31 PM   #1352
StefanoN
StefanoN's Avatar
Oddometer: 18
I'm not able to use properly my iPhone5 anymore with the Nav V after updating to iOS 7.1. Bluetooth disconnect, can't place call, etc. etc.
A couple of days ago before updating anything was working!
Anyone had the same problem? Any solutions?
Thanks a lot friends!!!
StefanoN is offline   Reply With Quote
Old 03-12-2014, 03:39 PM   #1353
Nick 187
Oddometer: 204
Are there any differences in the car cradle and a car cradle for a 660/665?
I paired my iPhone to the Sena prior to getting my NAV 5 and it worked as you advised. Once paired the 3 together as you advised Siri wouldn't activate. I would hold down the phone button and eventually it would go into pairing mode.
Nick
Nick 187 is offline   Reply With Quote
Old 03-12-2014, 04:53 PM   #1354
BruceWA
Oddometer: 572
I just ordered one from the EU company that packages them and will compare the two--I'm expecting they are the same 3M Vikuiti film be good to know if there are differences/options.
Ordered the DQCM30 earlier today. Will report on fit, etc after installation.
Figures don't lie, but liars can figure
BruceWA is offline   Reply With Quote
Old 03-12-2014, 07:51 PM   #1355
DRTBYK
DRTBYK's Avatar
Oddometer: 5,897
Nick
You're holding down the "phone" button to long. I would suggest reading your Sena manual.
Cheers,
Dan
All Things GPS
Old 03-12-2014, 09:40 PM   #1356
Desert John
Desert John
Oddometer: 198
16 GB card works fine. Just "slid" my iTunes selections onto it and plugged it into the Nav V. My problem, as stated 5-6 weeks ago, is that I could not import Playlists and the solution outlined on this forum worked just fine except it was on only one track at a time! At that rate I'd have all my Playlists organized by Christmas. Bummer.
'15 R1200GS LC
'14 Harley-Davidson FLHTK—yes, slightly liquid cooled
'14 Aprilia Tuono V4
Desert John is offline   Reply With Quote
Old 03-13-2014, 05:42 AM   #1357
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,305
Are there any differences in the car cradle and a car cradle for a 660/665?...
Unlike the 660/5 the Nav V has no speaker, so the Nav V car cradle has a speaker in it. (as far as I am aware, I have not seen one in person yet)
Old 03-13-2014, 07:07 AM   #1358
mountainguy
Oddometer: 536
My car has bluetooth. I wonder if I can bluetooth the Nav 5 to the car and have it use the car's speakers, just like my phone does?
mountainguy is offline   Reply With Quote
Old 03-13-2014, 08:24 AM   #1359
DRTBYK
DRTBYK's Avatar
Oddometer: 5,897
Why not? It's an HFP/HSP device.
Cheers,
Dan
All Things GPS
Old 03-13-2014, 08:25 AM   #1360
DRTBYK
DRTBYK's Avatar
Oddometer: 5,897
Nick
As Emoto speculated, there is a speaker in the NAV5 Car Kit Mount.
Cheers,
Dan
All Things GPS
Old 03-13-2014, 09:21 AM   #1361
DRTBYK
DRTBYK's Avatar
Oddometer: 5,897
If you create your play list in iTunes you can convert it rather easily with a text editor so that the NAV5 can use it. I have multiple playlists and one with over 2200 tracks in it.
There is a post of mine with the "how-to" somewhere around here or the other four or five NAV5 threads. Basically, change the path to the tracks to match your location in the NAV5. Use 2:\ as the "drive" letter when you edit the iTunes Playlist entries if you put the music on the SD Card.
Your iTunes Playlist entries will look like this:
/Users/...../...../iTunes/Music/Andrea Bocelli/The Opera Album~Aria/11 Cielo E Mar! 1.mp3
Once edited your Playlist entries will look like this if you put your music in the MP3 folder:
2:/MP3/Andrea Bocelli/The Opera Album~Aria/11 Cielo E Mar! 1.mp3
Easy enough to use a mass "Find/Replace" to make the changes.
Cheers,
Dan
All Things GPS
Old 03-17-2014, 03:40 PM   #1362
DRTBYK
DRTBYK's Avatar
Oddometer: 5,897
NAV5 Screen Protector
Currently NuShield's recommended DayVue protector for the NAV5 does not fit. It is 2mm to narrow and 2mm to long. The proper screen size is (108mmx65mm) -1mm variance is acceptable. I have conveyed this to NuShield and have not heard from the yet.
As was previously noted the Vikuiti 3M ARMR220 for BMW Navigator V does fit (107mmx65mm) and can be acquired either at an Amazon.com seller or Protectionfilms24.com.
Cheers,
Dan
All Things GPS
Old 03-17-2014, 06:43 PM   #1363
DRTBYK
DRTBYK's Avatar
Oddometer: 5,897
I just tried a new Bluetooth configuration based upon the proposed Scenario in the Sena SMH10R Manual. This actually works.
I have music from the Monterra and it gets it's Internet [Pandora] Radio connection via Wi-Fi Hotspot on the iPhone.
Cheers,
Dan
All Things GPS
DRTBYK screwed with this post 04-04-2014 at 06:02 PM
Old 03-18-2014, 06:34 AM   #1364
mefly2
mefly2's Avatar
Oddometer: 1,228
Some vehicles will connect via Bluetooth to the Nav V; some do not. The BMW auto cradle not only provides a speaker, but also changes from mc mode to car mode.
----------------> jer-
30+ years with RTs...then to F/GS; now *Finally*
the BMW: R1200GSW, factory low seat & lower crash bars;
Touratech: Upper Crash Bars, big foot, pannier rack, ZegaPro panniers;
Fuzeblock, Rigid Dually D2 + yellow covers; Wunderlich bar risers w/ Q-adjust
mefly2 is offline   Reply With Quote
Old 03-18-2014, 08:55 AM   #1365
DRTBYK
DRTBYK's Avatar
Oddometer: 5,897
Screen Protectors
I think the NuShield folks have it sorted out now on their website. They have the correct sizing and they are listed under BMW, Navigator V 2013. You get two protectors in a package which makes the price pretty reasonable.
Cheers,
Dan
All Things GPS
Times are GMT -7.   It's 07:12 PM.
