Old 03-18-2014, 11:24 AM   #1366
atg
Oddometer: 224
BMW's BT helmet system with NAV V on a GSW allows MP3 an directins volume control through the GS "wheel".
Can anyone please inform if there is any other BT system where the GS's "wheel" also controls listening level ?
Thanks,
Andre
atg is offline   Reply With Quote
Old 03-18-2014, 12:20 PM   #1367
BruceWA
Oddometer: 574
Originally Posted by DRTBYK View Post
Currently NuShield's recommended DayVue protector for the NAV5 does not fit. It is 2mm to narrow and 2mm to long. The proper screen size is (108mmx65mm) -1mm variance is acceptable. I have conveyed this to NuShield and have not heard from the yet.
As was previously noted the Vikuiti 3M ARMR220 for BMW Navigator V does fit (107mmx65mm) and can be acquired either at an Amazon.com seller or Protectionfilms24.com.
Installed the Vikuiti DQCM30 today.....size is correct, but the install wasn't as easy as it should have been. Of course this is about me not the protector. Not sure I can live with the final result.
Figures don't lie, but liars can figure
BruceWA is offline   Reply With Quote
Old 03-18-2014, 01:58 PM   #1368
Bails
Bails's Avatar
Oddometer: 402
Thanks,
Andre
I am not sure if any other systems do allow volume control via wheel . I cannot do this, nor do I want to, with my Senna. I have looked at all the BT headsets and IMO the Senna is the best unit. Very simple ti adjust volume by quick turn of one large dial ?
If it has to Be then it's up to Me!
Bikes Multi Strada 1200 BMW GSA
Bails is offline   Reply With Quote
Old 03-25-2014, 05:53 PM   #1369
Voz
Voz's Avatar
Oddometer: 491
So, did we work out how to blank the screen when riding?
Sometimes I just don't want the screen on, cheers.
Sydney, Australia
2013 R1200 GSW Red - Blown Engine & Gearbox (clutch basket nut issue) - AUG 14
2015 R1200 GSW White - NOV 14
Voz is offline   Reply With Quote
Old 03-25-2014, 06:14 PM   #1370
eap
El Adventurero Solitario
eap's Avatar
Oddometer: 3,266
Post #1197
eap '14 R1200GS-LC Thunder Grey
Chesapeake Bay Watershed, Surf Your Watershed
Support Mammograms
"Over the Mountains Of the Moon, Down the Valley of the Shadow, Ride, boldly ride," -From 'Eldorado', Edgar Allen Poe (1849) http://www.eapoe.org/works/poems/eldrdoa.htm
eap is offline   Reply With Quote
Old 03-25-2014, 07:05 PM   #1371
GeorgeKingGeorge
Oddometer: 100
iOS 7.1
Originally Posted by StefanoN View Post
I'm not able to use properly my iPhone5 anymore with the Nav V after updating to iOS 7.1. Bluetooth disconnect, can't place call, etc. etc.
A couple of days ago before updating anything was working!
Anyone had the same problem? Any solutions?
Thanks a lot friends!!!
iPhone 5s with 7.1 pairs just fine with my Nav V. No issues but I did have to disable search for BT devices in the Nav. Music playback paused randomly if find new devices was on.
George
'14 R1200GSW
'92 K75s -- original owner, '10 Daytona 675 -- track bike
GeorgeKingGeorge is offline   Reply With Quote
Old 03-26-2014, 12:48 PM   #1372
mefly2
mefly2's Avatar
Oddometer: 1,228
Screen Protection
Oversized screen protectors (for the 760) on the big auction site ... 3 for $7.98 shipped. Cut them to fit - works great!
http://cgi.ebay.com/ws/eBayISAPI.dll...X:eRTM:US:1123
----------------> jer-
30+ years with RTs...then to F/GS; now *Finally*
the BMW: R1200GSW, factory low seat & lower crash bars;
Touratech: Upper Crash Bars, big foot, pannier rack, ZegaPro panniers;
Fuzeblock, Rigid Dually D2 + yellow covers; Wunderlich bar risers w/ Q-adjust
mefly2 is offline   Reply With Quote
Old 03-27-2014, 04:13 AM   #1373
Voz
Voz's Avatar
Oddometer: 491
Originally Posted by eap View Post
Post #1197
Thanks.
Sydney, Australia
Old 03-27-2014, 06:50 AM   #1374
BruceWA
Oddometer: 574
My Nushield's arrived a few days ago, haven't even looked at them yet, but will to see how they fit. AFter the Vikuiti has dried they are OK. A little dark in the sun but I can see the Nav V it is matte finish and it has a slight tint.
BruceWA screwed with this post 03-27-2014 at 09:28 AM
Old 03-27-2014, 06:57 AM   #1375
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,345
New version of Garmin Express 3.0.12.0 is available, couldn't even begin to tell you what fix's, features or updates it incorporates.
Pull chocks.
JetSpeed is offline   Reply With Quote
Old 03-27-2014, 07:33 AM   #1376
Kevin Dixon
Motorrad Abenteurer
Kevin Dixon's Avatar
Oddometer: 818
Anyone played with the new curvy road navigation option yet? It is amazing!
Kevin Dixon is offline   Reply With Quote
Old 03-27-2014, 09:59 AM   #1377
Amania
Amania's Avatar
Oddometer: 106
nav five
Tell us about it
I don't ride a BMW GS because I want to
I ride one because I need to
2014 r1200gs
Epoxy Garage Floors
Amania is offline   Reply With Quote
Old 03-27-2014, 11:17 AM   #1378
Kevin Dixon
Motorrad Abenteurer
Oddometer: 818
BMW Navigator V on GSW
Before you had 2 navigation options; fastest route and shortest route. Version 2.60 has added the functionality of curvy route. You put in your destination and it gives you a couple of options with the curviest roads. I have found it at minimum doubles the transit time. Sometimes 3-4x longer!
Probably wouldn't do much for the Midwesterners but out here in CA living near all the good roads lets just say it takes awhile to calculate the route sometimes
Old 03-27-2014, 11:19 AM   #1379
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,337
Does it seem to also pick smaller roads?
Old 03-27-2014, 12:06 PM   #1380
RichBMW
RichBMW's Avatar
Oddometer: 2,104
Does anyone know if there's a setting to avoid town/ city centres? I normally put fastest route in, which should avoid busy cities, but it doesn't always.
2015 BMW S1000R Sport
2015 BMW R1200GSAW
RichBMW is offline   Reply With Quote
Times are GMT -7.   It's 11:30 PM.
