Old 04-10-2012, 04:31 PM   #181
danedg
Horizontally Opposed
Oddometer: 5,294
Crustacean
So this appears dead. Am I wrong?
danedg is online now   Reply With Quote
Old 04-10-2012, 05:29 PM   #182
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,110
Pull the dust seal off and have a look ?
Brembo 08 piston kits are readily available.
Les .. 1968 Husqvarna MF250 and MF360 - 1971 Norton Commando Fastback - 1973 Kawasaki H2A - 1973 Ducati 750 GT - 1973 Moto Guzzi Eldorado - 1974 Kawasaki H2B - 1974 Triumph TR5T Trophy Trail - 1981 Ducati 900 SD - 1986 Husqvarna 400 WR - 1998 Suzuki TL1000S - 1998 Suzuki TL1000S - 2007 Ducati Hypermotard 1100S - 2008 Suzuki DR780.
ADV8 is offline   Reply With Quote
Old 04-10-2012, 06:06 PM   #183
danedg
Oddometer: 5,294
It ain't gonna kill me to get a fresh new one,whereas it probably WOULD kill me to try and use this corroded lump again.
Two Craftsman screw drivers didn't budge a thing.
The instructions suggest blowing compressed air into the bleeder hole to gently blow the pistons out to replace the seals...
Polar bears ain't gonna get them seals outta those holes!!!
Old 04-10-2012, 06:17 PM   #184
richarddacat
breaking wind
richarddacat's Avatar
Oddometer: 2,582
I had one like that on a old BMW ATE and filled it with Liquid Wrench, sealed it and left it in a bucket of kerosene for a few days.
It worked, make sure you point it in a trash can when you apply air pressure and not outside towards the car.
* 05FJR/74R90s *
If we concentrated on the really important stuff in life, there'd be a shortage of motorcycles.
richarddacat is offline   Reply With Quote
Old 04-10-2012, 06:19 PM   #185
F_Sahms
mostly paved
F_Sahms's Avatar
Oddometer: 203
Heat to smoking with a propane torch. Heat more. Spray piston edge with penetrating oil of choice. Clamp caliper half in a vice with some kind of soft jaws. Twist piston out with vicegrips. I haven't lost one yet.
I have had to ditch calipers for snapped-off bleeder nipples, though.
Life's too short.
F_Sahms is offline   Reply With Quote
Old 04-10-2012, 06:28 PM   #186
danedg
Oddometer: 5,294
MAPP gas is all I use for that sort of thing!
The bleeder didn't actually look that bad. It was embedded in a greasy goo, probably not a bad thing. But I didn't try a wrench on it yet....
Old 04-10-2012, 09:15 PM   #187
Nick in PRC.
Nick in PRC.'s Avatar
Oddometer: 267
Lots of heat on the bleeders first.
_________________________________________
Nick in PRC.
CJ M1s & some two wheel Guzzi's.
Chang chat: http://cj750.forumcircle.com
Nick in PRC. is offline   Reply With Quote
Old 04-11-2012, 02:26 AM   #188
wmax351
Oddometer: 740
Soak in pb blaster, or whatever. ATF and acetone is great.
Then use a grease gun to put grease into the caliper. I just put a grease nipple on the inlet side. However you do it, a hand grease gun can put 3000 psi out without problem, and it is hydrostatic, so you don't blow a piston through the wall.
wmax351 is online now   Reply With Quote
Old 04-11-2012, 03:52 AM   #189
hunter_greyghost
XS650 Allroads Traveller
hunter_greyghost's Avatar
Oddometer: 5,505
Like the way you think, very practical solution,
Cheers
Baza
1981 XS650SH "Tourer" [ For Sale - when / maybe?], 1975 XS650B "Adventure" ['Kenny Krazyhorse'], 1982 XL500R 'Project'
www.aussiegreyghost.smugmug.com
Couldn't afford a 'GSA', so now it's an 'XSA' "I didn't do it! & whoever said I did, is a liar!"
hunter_greyghost is offline   Reply With Quote
Old 04-11-2012, 05:13 AM   #190
danedg
Oddometer: 5,294
Thank You Gentlemen,
This is all great stuff! While the particular nuance of each bike/brand keeps us entertained, I especially enjoy the basic methods of work that apply to them all!
I'm getting the feeling here that once the pots have been extracted that the caliper housing can be reused? I was concerned about the corroded receivers losing their ability to contain hydraulic pressure...
Old 04-11-2012, 05:44 AM   #191
sjc56
Oddometer: 820
The one advantage of my 74 Eldorado project with the four leading shoe drum brake.No hydraulics to worry about. On my 77 Lemans I replaced all the calipers. At the time it wasn't that much more over a rebuild with new seals and piston.
Steve
sjc56 is online now   Reply With Quote
Old 04-11-2012, 08:12 AM   #192
danedg
Oddometer: 5,294
Mission Accomplished
I love the smell of NutsOff in the morning! It smells like...Victory!
They looked a lot worser than they wuzzer.
New aluminum pistons, pads, bleeder on the way...
Old 04-11-2012, 01:02 PM   #193
wmax351
Oddometer: 740
Cheers
Baza
Worked great on my '73 Triumph TR7V, even after 15 years sitting in santa cruz.
Old 04-11-2012, 02:55 PM   #194
danedg
Oddometer: 5,294
Love It!
Friggin' brilliant!
Old 04-12-2012, 06:37 AM   #195
sjc56
Oddometer: 820
We used the grease method on a frozen piston on a /5 BMW had.
Steve
Times are GMT -7.   It's 01:43 PM.
