Old 02-24-2013, 09:11 PM   #391
wmax351
Oddometer: 743
In regard to blasting cases, you could have it vapor blasted (dry ice) or soda blasted. Either one does not leave residue.
wmax351 is offline   Reply With Quote
Old 02-25-2013, 01:07 AM   #392
MeinMotorrad
MeinMotorrad's Avatar
Oddometer: 1,493
Anyone tried rice blasting? I've heard of it being used to clean up delicate parts/finishes. Might work for aluminium.
MeinMotorrad is offline   Reply With Quote
Old 02-25-2013, 04:31 AM   #393
F_Sahms
mostly paved
F_Sahms's Avatar
Oddometer: 360
Originally Posted by danedg View Post
But wait! The rocker assemblies have no gasket. That's why the rings are in the head. But why at the base?
The o-rings are to prevent oil from creeping up/down the studs. The two studs at noon and 6 are exposed at the top, so oil can't get in there, so the rings are at the base.
The other four are beside the oil galleys to the rockers, and there's no gasket between the head and rocker carriers, so the o-rings keep the oil out.
Life's too short.
F_Sahms is offline   Reply With Quote
Old 02-25-2013, 05:43 PM   #394
danedg
Horizontally Opposed
Oddometer: 6,666
Rockers
The tiny rings go on...
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic
danedg is offline   Reply With Quote
Old 02-25-2013, 05:49 PM   #395
danedg
Oddometer: 6,666
Rocker assembly
N0. 6
And the funky 10mm allen Head bolt at 12 oclock. Way down inside.
danedg screwed with this post 02-25-2013 at 06:01 PM
Old 02-25-2013, 06:07 PM   #396
danedg
Oddometer: 6,666
The threads in the 12 bolt were particularly crusty and needed cleaning, as did the manifold bolts, etc. Just all crudded up.
That bolt is exposed to the elements. It doesn't seal out oil. It seals out water.
Once all 6 head bolts are in place the cap is placed on 12oclock. It keeps water from coming up into the rocker arm area.
To Arms!
With pushrod in place set the arm
Bronze washer and flat spring in place and drive the piston home
The 4mm bolt holds it altogether.
The rocker arm will come back out soon enough as none of the head bolts got set, much less torqued.
Tough to reach 2 and 10 under the arms!
danedg screwed with this post 02-26-2013 at 12:17 PM
Old 02-25-2013, 06:34 PM   #397
danedg
Oddometer: 6,666
Glam Shot
Old 02-25-2013, 07:35 PM   #398
JonnyCash
turd polisher
Oddometer: 1,601
Very nice! Must feel good to be at that point.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 02-27-2013, 05:08 PM   #399
danedg
Oddometer: 6,666
Generator Bracket
I got adventurous today and modified the generator bracket as per Greg Benders' instructions...
Further comments regarding my welding skills will be ignored.
It had been broken and remangled long since.
The battery tray is/was a work of art.
I've added some extra strengthening.
The thing is bolted to the tranny, swingarm cross brace and rear fender. Add a tractor battery and this flimsy piece of sheetmetal is true overacheiver...!
danedg screwed with this post 02-27-2013 at 05:20 PM
Old 02-27-2013, 06:52 PM   #400
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,860
And it looks awesome in person.
Hey Dan, I think another reason forthe dowels is so the bearings dont spin. It is good to have a garunteed smaller amount of oil than a spun bearing and no oil, right?
Have some good pics, might be a little while befoer i can upload them
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 03-01-2013, 04:09 PM   #401
danedg
Oddometer: 6,666
Rear Drive
'74 Eldorado.
Fresh out of the box from Zydeco Racing.
I am not worthy!
Spline sublime
Old 03-01-2013, 04:23 PM   #402
danedg
Oddometer: 6,666
Spline Meets Gear
Mom...Dad!? Don't let the kids see this!!!!!!
Old 03-01-2013, 04:42 PM   #403
JonnyCash
turd polisher
Oddometer: 1,601
ribbed(splined) for her pleasure!
Old 03-01-2013, 04:49 PM   #404
danedg
Oddometer: 6,666
They Were Made For Each Other
Old 03-02-2013, 11:08 AM   #405
CafeRacer
CafeRacer's Avatar
Oddometer: 260
So excellent.
The pictures of Charley's work makes me jealous. He's got my tranny.
Motorcycles are awesome. Yay motorcycles.
CafeRacer is offline   Reply With Quote
Times are GMT -7.   It's 12:07 AM.
