Old 10-14-2011, 02:52 PM   #1
oink OP
oink's Avatar
Oddometer: 14
DR200 carb issue
My wife's little DR200 got running shitty from not being ridden. I pulled the carb. It didn't look that bad inside. The one jet was clogged (low speed I think). I cleaned the clogged jet out but I didn't totally tear the carb down because it looked so clean otherwise. So I put it back together and it runs great....except now when you slow for a corner or to stop the idle increases substantially before returning to normal. Although I didn't mess with the float level I'm thinking that has to be it as I'm thinking it has to do with the fuel level changing as the fuel slops forward in the bowel when slowing. Any ideas?
Mine: 02 ZG1000, 13 DL650A, 09 DR Z400S, 99 DR350SE
Shared: 09 DR650
Wife's: 09 KLE650, 06 DR200SE
Son #1's: 06 KLR650
Son #2's: 06 SV650S
oink is offline   Reply With Quote
Old 10-14-2011, 04:00 PM   #2
qkenf4u
Oddometer: 201
make sure there is PLAY IN THE THROTTLE CABLE and make sure its fully seated in the cap on the carb.. do ya have the idle set to high on the carb ?
qkenf4u is offline   Reply With Quote
Old 10-14-2011, 06:12 PM   #3
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,850
Do the checks.
Make sure the throttle has enough slack for the carb to return to idle.
Make sure the choke isn't hanging open a little.
Make sure the carb boots are tight and there are no vacuum leaks around them.
Idle should be set after a quick 10 to 20 minute warm up ride.
A bad O ring on the needle seat or leaking needle can cause a high idle.
High float level can also cause the same issue.
The most common issue that causes high hanging idle is a severe lean condition.This is usually caused by a clogged low idle circuit or jet in the carb.Also,vacuum leaks around or inside the carb can cause the same issue.The jets are cheap for the DR so I would just change them.It's fairly difficult to completely clean the low speed jet.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 10-14-2011, 06:15 PM   #4
Trailrider200
Trailrider200's Avatar
Oddometer: 372
idle hanging up indicates a lean conditiion. either a vacuum leak or most likely the idle mixture screw is closed too much. lightly seat it and then open it up 2 turns out for starters. epa brass plugs needs to be removed if not done already.
go to www.factorypro.com and see tech section for carb tunning guide
1981 CB900C, 1998 GL1500C Valkyrie
2007 DR200
"Our Constitution was made only for a Moral and Religious people. It is wholly inadequate to the goverment of any other."
John Adams 10/11/1798
"If we ever forget that we're one nation under God, then we will be a nation gone under" Ronald Reagan
Trailrider200 is offline   Reply With Quote
Old 10-14-2011, 06:34 PM   #5
oink OP
oink's Avatar
Oddometer: 14
Thanks guys. At least initially it seems the throttle cable was too tight. That's after a short test ride in the neighborhood. Wife will have to give it a longer test. It seems that a tight throttle cable would make it run high all the time rather than just when slowing, but that seems to have done the trick.
Shared: 09 DR650
Son #1's: 06 KLR650
Son #2's: 06 SV650S
Old 10-14-2011, 06:39 PM   #6
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,850
I hope that was it.I'm all for easy fixes.
Times are GMT -7.   It's 03:16 AM.
