Old 10-21-2011, 09:46 PM   #1
Airhead Wrangler OP
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,469
An Unholy Union III: WP 4860 USD Forks on an Airhead
Since I happen to know there will be (at least) 6 people fitting WP 4860 forks to various airheads in the VERY near future and since I know Solo doesn't want us cluttering up his thread with our BS, I thought it'd be a good idea to have all the USD folks solve our problems in the same spot.
I'm using "open chamber" 4860s off of a 2006 KTM 250SXF. They'll be going on a reinforced ST frame by way of HPMGuy's triple clamps. I plan to build my own front wheel using a 1.85"x21" rim on an aftermarket KTM hub and use the stock KTM master cylinder and caliper.
Here's a good writeup of the differences between various years and models of 4860 (and 4357) forks as well as servicing data and some relevant info about fitting them to other bikes.
http://crossroadz.com.au/F650GS/Modi...orkNotesWP.pdf
A good service manual available free from KTM:
http://slorider.com/KTM/manuals/WP4860MXMA2003.pdf
Two videos detailing all the considerations of fitting 4860s to the F650 (but plenty of relevant info):
http://www.garagenight.tv/ep-11-ktm-forks-on-a-bmw/
http://blip.tv/garage-night/garage-n...part-2-2375953
Anyone else?
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 10-27-2011 at 03:27 PM
Old 10-21-2011, 10:12 PM   #2
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,476
Thanks for doing all the research on this, man. I'm hoping to do this next year.
For anyone that didn't get in on the group buy you can get triples for these forks from EMIG racing. They make triples that have 30mm of offset. I'm sure they can machine the stem down to BMW specs.
http://emigracing.com/
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 10-22-2011, 08:41 AM   #3
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 8,725
Ouch
Lookin' forward to seeing this thread move ahead!
"punkrocks what it's all about" - J. Strummer
SOLO LOBO is offline   Reply With Quote
Old 10-22-2011, 10:07 AM   #4
Renner
infamous wrench
Renner's Avatar
Oddometer: 2,180
subscribed
thanks for initiating this AW.
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner is online now   Reply With Quote
Old 10-22-2011, 02:41 PM   #5
igormortis
igormortis's Avatar
Oddometer: 1,305
Yeah, I'm in.
igormortis is offline   Reply With Quote
Old 10-22-2011, 03:39 PM   #6
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,773
BMW engineered this bike to be PERFECT in every way, if there seems to be a flaw in your machine, it is because YOU are not worthy!
This thread can now be closed.............
Old 10-22-2011, 03:51 PM   #7
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,469
...yeah, exactly how the fine bavarian craftsmen built it 35 years ago:
Old 10-22-2011, 03:58 PM   #8
Houseoffubar
fine beer sampler
Oddometer: 1,773
Nobody likes a smartass!
I like to think, how they intended, you know, budgetary, and marketing concerns aside.........Oh, alright, I'm full of shit as usual!
Old 10-23-2011, 07:21 AM   #9
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,225
I looked at this a year or two ago. I think the forks I have are from a 450EXC.
The biggest issue was that the clamping distance on the forks was barely short enough to cover the BMW head tube length. The KTM has a longer head tube, and in order to mount these they would have been too far down in the clamps. I'm not looking for a tall bike, nor 300mm travel.
The stem was also too long; it had a taper in the middle and the 29mm diameter parts (for the KTM bearings) weren't close enough together. Even machining them down to 28mm (for the BMW bearings) barely brought them close enough together. But a new stem is not so hard.
I think different, shorter forks (like on the 950SE) would have a much easier fitment for my purposes.
Old 10-24-2011, 08:39 AM   #10
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,469
Here's what we did about the stem:
The 950 uses the same forks, but with shorter springs and a spacer under the topout spring to make it top out earlier. Other than that and the clamps for the larger axle and dual discs, they're the same.
Old 10-24-2011, 11:15 AM   #11
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,469
can anyone with a pair of 4860 forks measure both the length of and distance between the two clamping areas on their fork legs? I would measure mine, but my forks are in Seattle and I'm in Mexico.
Also, a bottom of bearing seat to bottom of bearing seat in the steering head would be a useful measurement as well. I'd like to do up a quicky CAD drawing to see how much height adjustment we can get sliding the fork legs up and down.
Old 10-24-2011, 11:19 PM   #12
igormortis
igormortis's Avatar
Oddometer: 1,305
I was led to believe that the 950 outers (legs? sliders?) were longer than ‘standard’ 4860s. See here.
Old 10-25-2011, 07:19 AM   #13
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,469
That's a new one on me. Everyone so far has told me they're the same. I guess they definitely aren't. Thanks for pointing that one out. One more consideration to add to the list when choosing your forks.
Being a bit caught off guard by that, and the ground clearance concerns in the thread you linked to I ran a few numbers:
R100GS forks:
Top of leg to axle center (fully extended): 831mm
travel: 225mm
Top of leg to axle center fully compressed: 606mm
WP 4860 (SX model):
Top of leg to axle center (fully extended): 935mm
travel: 300mm
Top of leg to axle center fully compressed: 635mm
To sum it up, using dirt model KTM forks as opposed to 950/990 (S model spec, long travel, not short) forks will not hurt your fully compressed ground clearance as compared to stock R100GS forks. You'll still gain 29mm of fully compressed fork length.
I'd still like to get measurements on the machined clamping sections of the fork legs though as they appear to be dramatically different between the 950/990 and dirt model forks pictured above.
Airhead Wrangler screwed with this post 10-27-2011 at 08:40 AM
Old 10-25-2011, 08:42 AM   #14
espressodrinker
Cape Town Wanderer
Oddometer: 199
Take cartridges out of modern forks - put into R100
Small hijack!
I upgraded my R80G/S forks to the R100GS, and put in a Gold Valve. Easy painless conversion. Would it be possible to take the cartridge out of one of these modern forks and then fit them inside the standard R100 forks? Similar to the hugely expensive HPN cartridge that isn't available any more?
Seems to me to be an easy upgrade without the pain of all the extra machining mods - although you don't gain any extra suspension stroke.
espressodrinker is offline   Reply With Quote
Old 10-25-2011, 08:49 AM   #15
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,469
Originally Posted by espressodrinker View Post
Small hijack!
Anything's possible, but there would be a lot of machining involved probably. Also, the stock r100gs forks are 40 or 41mm or thereabouts if I recall correctly. Most modern USD forks are significantly fatter, so fitting one of their cartridges inside might be tough. It'd probably be easier to fit a new front end rather than going to so much trouble machining the cartridge/forks/damper rod
Times are GMT -7.   It's 10:33 AM.
