Old 03-14-2013, 07:17 AM   #151
Airhead Wrangler OP
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,548
Originally Posted by naginalf View Post
You can also adjust the bottom out level with a spacer behind the hydraulic stop right? I haven't opened mine up yet to learn it's dark, mysterious secrets. I will this weekend tho .
There's a PDF file I linked to in the first post that discusses how to both shorten the forks as well as revalve them for an F650 which is similar in weight. Worth a read:
http://crossroadz.com.au/F650GS/Modi...orkNotesWP.pdf
Also, here's WP's service manual for the 4860s so you can get a preview of what's inside before you crack them open yourself:
http://slorider.com/KTM/manuals/WP4860MXMA2003.pdf
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 03-14-2013, 07:40 AM   #152
naginalf
Handy Schtroumpf
naginalf's Avatar
Oddometer: 250
Personally, I plan on doing both lowering in the trees and lowering with a spacer, so thanks Prutser for reminding me to check the bottom out measurement.
Also, being from 2003, that manual may need some revision for newer models of forks. For instance, Kelvin mentioned that one of the manuals (not sure about this one) had the oil filling method all wrong unless you are working on 5060s which is where it was copied from apparently. If so, check Slavens vid on the matter, he has it right.
Thanks for posting that again AW. I had glanced at it once before a long time ago, but hadn't noticed the valving guide. One thing I'd like to nitpick about that however, it specifies a midvalve float of 1.5mm. From what I've read about the 990s, which are closer in weight (480lbs), 1.5 is stock and WAY too much float. Most seem to have better luck with more like 0.8mm of float.
'91 R100GSPD
Adventures with a Type1 TARDIS.
naginalf screwed with this post 03-14-2013 at 08:00 AM
naginalf is offline   Reply With Quote
Old 07-10-2013, 07:03 PM   #153
ontic
Oddometer: 1,070
Kinda quiet in here...
how's things going in upside down land?
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 07-10-2013, 07:30 PM   #154
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,548
No kidding. Am I the only one who's actually put one together yet with the R-dubb triples?
Old 07-10-2013, 08:27 PM   #155
igormortis
igormortis's Avatar
Oddometer: 1,372
I only did a mock up. Convinced that they would work well, but I wasn't confident I'd get them set up right before the big trip. Just finished riding on the HH-Racetech inserts through Mongolia. Pretty happy, but still a long way to go! R-Dubb triples will have to wait for Battle Panda 2.0
Sent from my GT-I9100T using Tapatalk 4 Beta
igormortis is offline   Reply With Quote
Old 07-10-2013, 10:42 PM   #156
Clay Spinner
Clay Spinner's Avatar
Oddometer: 709
As soon as the next batch are completed I'll be fitting two pairs to my bikes... so that will make two (?!) of us. I'm hoping you sort out all of the problems first though... so crack on mate!
Clay Spinner is offline   Reply With Quote
Old 07-11-2013, 06:27 AM   #157
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,548
Apart from some forks that need a rebuild, zero problems with mine, but I only have 160 miles on them, so we'll see. My forks feel incredibly stictiony at a standstill when pumping them up and down, but the stiction is barely noticable when riding. I'm pretty sure it's just a matter of buying cheap forks straight off ebay and putting them right into service without even so much as opening them up to see what's inside. I've ordered new bushings, seals, wipers and oil to rebuild them next time I'm up north. The spring rate didn't feel too far off if at all. I might be able to get away with the springs I have.
Airhead Wrangler screwed with this post 07-11-2013 at 08:40 AM
Old 07-11-2013, 08:04 AM   #158
naginalf
Handy Schtroumpf
naginalf's Avatar
Oddometer: 250
I would have had mine installed by now, but I got stuck in a hell of constantly waitng for parts. I asked for an unorthodox service, and I was promised, enthusiastically even, all the parts and advice that I needed to rebuild these forks. Well, not only did that not happen, but I guess I was just cursed this spring because my order for a new rear shock got lost in the shuffle as well, and I had to wait 13 weeks for that as well. Once I got the rear shock, I finally gave up calling for more excuses and no action on the fork parts. They are now in Alex's capable hands over at Konflict. 2 more weeks , I can't wait! It'll probably end up being the same price or cheaper anyway and I don't have to worry about screwing it up. But the latest event in my curse came when I rebuilt the used wheel I bought; the damn rim was way out of true, had several flat spots, and the spoke nipples under the protection strip were completely rusted. I couldn't check for true or possibly correct it because the bearings were slammed in shipping (single wall cardboard, no padding at all), so I couldn't check it until I replaced them. So now I need a new wheel, damnit. Arg. I JUST WANT TO RIDE !
Does anyone have any experience with the warp 9 wheels? It'll cost me $200 for a new rim, 70 for spokes and hardware, another 100 for building it up, and the warp 9's are only $360 for a whole new wheel, but I've read mixed reviews. Or should I risk buying another used wheel?
'91 R100GSPD
naginalf screwed with this post 07-11-2013 at 08:55 AM
Old 07-12-2013, 08:03 PM   #159
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,605
I feel your pain, man. I've lost 2 months to waiting on parts this summer already.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 07-19-2013, 12:37 PM   #160
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,978
EDIT
I posted the note below in the wrong thread (working from my phone) so just ignore it. Sorry AW!
Hyperpro is doing suspension evaluations here at the national really and looked aver my G/S. The front suspension has enough friction that small pushes down on the handlebars actually has no effect on the front at all and makes the (undesprung) rear shock bounce.
The tech told me the stiction is common to these forks and suggested replacing the seals with one from from HKC, which are apparently very low drag seals. He also thought the springs may be too soft as well.
The low speed damping on my rear Ohlins isn't working and the spring needs more preload at best and a stiffer spring at worst. The shock will require a rebuild to deal with the lack of low speed damping.
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo screwed with this post 07-19-2013 at 03:56 PM
Solo Lobo is offline   Reply With Quote
Old 07-19-2013, 01:21 PM   #161
naginalf
Handy Schtroumpf
naginalf's Avatar
Oddometer: 250
Originally Posted by SOLO LOBO View Post
Hyperpro is doing suspension evaluations here at the national really and looked over my G/S. The front suspension has enough friction that small pushes down on the handlebars actually has no effect on the front at all and makes the (undesprung) rear shock bounce.
Did Alex use SKF seals on your forks (are they green)? Those are much better than stock, which is why the stiction is so common, as you can see in this video.
'91 R100GSPD
Old 07-19-2013, 01:25 PM   #162
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,978
SKF, that's what they said. Thanks.
I'll check the color of the seals later today or when I get home...don't know what's in there
R65LazaruS
Old 07-19-2013, 01:57 PM   #163
Prutser
Prutser's Avatar
Oddometer: 1,017
The SKF seals are not made in the WP50 sizes.
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is online now   Reply With Quote
Old 07-19-2013, 02:14 PM   #164
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,548
Maybe you could find a way to make Marzocchi 50mm USD seals work??
Old 07-19-2013, 02:33 PM   #165
Prutser
Prutser's Avatar
Oddometer: 1,017
That might be an option but the outside diam of the WP sliders could be to thin to make a bigger outside diam seal fit.
Ride Report 2012
Times are GMT -7.   It's 08:30 AM.
