Old 03-19-2013, 07:33 PM   #271
cognugget
cognugget's Avatar
Oddometer: 243
Originally Posted by rolexgmt View Post
I challenge anyone to kick start these things. A lot have tried and a lot have cried. I have a standing $20 bet with anyone who comes to ride mine.
Safest $20 in the world.
That does not seem right at all, haha! 450f's start easy 1 kick, heck, my 650r starts in 1-3 kicks.
Plated XR650R
cognugget is offline   Reply With Quote
Old 03-19-2013, 07:36 PM   #272
JTucker
JTucker's Avatar
Oddometer: 2,270
If it's that hard to start the carb jetting is off.
http://www.ktm-parts.com
03 Aprilia Caponord 06DR650
13 GasGas EC300 05 WR450F 87 T-dub
JTucker is offline   Reply With Quote
Old 03-20-2013, 02:41 PM   #273
PeteN95
PeteN95's Avatar
Oddometer: 2,680
Mine would kick start with the stock carb, but it wasn't consistent. With the FCR carb, it kicks first time, just like my CRF did!
"If you ain't slidin', you ain't ridin'"
SVN/XRR/XC-W
PeteN95 is online now   Reply With Quote
Old 03-21-2013, 02:59 PM   #274
njsurferlarry
njsurferlarry's Avatar
Oddometer: 49
What carb is on the start 450 ds? I'm hoping to go over it this weekend. And nj motor vehicle still won't register mine. Christini sent me a fan and switch for the radiator. And a straight header pipe and looks like the muffle that comes off the 450 enduro. Which is really cool of him. The fcr carb I have in my garage is junk. Came off a wr 450. So I can't use that one. So I'm going to stick with the stock carb for awhile. Just not sure what brand carb it is and if the is jets available. Any info? And since the cat exhaust is so choked up. What jets have been tried with the stock ds carb with a better flowing exhaust?
njsurferlarry is offline   Reply With Quote
Old 03-21-2013, 03:46 PM   #275
PeteN95
PeteN95's Avatar
Oddometer: 2,680
The stock DS 450 carb is some 28mm CV carb, just say no! I have a 40mm FCR off a CRF450R on mine and it is waaaay better.
SVN/XRR/XC-W
Old 03-22-2013, 04:22 AM   #276
njsurferlarry
Oddometer: 49
wow, a 28 mm carb? thats tiny. i guess not much could be done with that carb. i guess im going to have to find another carb. the only other carb i have is a 34 cvk off a klr 250. still alot better than the 28mm
Old 03-22-2013, 06:16 AM   #277
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,724
Wow Pete, Congrats.
I am glad it isn't EFI and doesn't have a 6 speed tranny. I am safe for now.
How is the subframe?
Mr. Fisherman is offline   Reply With Quote
Old 03-22-2013, 01:46 PM   #278
X1Glider
X1Glider's Avatar
Oddometer: 597
It's actually a 38mm CV.
Bob Krzeszkiewicz - 2013 Christini 450E - 2011 Kawasaki Ninja 1000 - 2000 Harley Davidson FXDX - 1999 Buell X1
X1Glider is offline   Reply With Quote
Old 03-23-2013, 02:18 AM   #279
X1Glider
X1Glider's Avatar
Oddometer: 597
Handguards?
A quick look at the manual appears to me that the upper trees are similar enough to the 450 X that I could use the same tree pinch bolt mount for the Cycra Pro-Bends. See this pic. This worked very well for me for 4 years on the X. Anyone using this on their Christini?
If not, what is the bar diameter so I can order the correct clamp size?
Old 03-24-2013, 09:47 AM   #280
njsurferlarry
Oddometer: 49
With the new exhaust it fires right up with the kick start. Now time to go thru the carb. Think there would be a way to get that thing out easier. With just the exhaust change the power was hugely increased. Wheelies no problem now
Old 03-24-2013, 12:13 PM   #281
Capt. Egregious
Capt. Egregious's Avatar
Oddometer: 369
Good to hear.
Got my first batch of parts from Christini . New ratio and chain for the front. Gear box all back together, clutch rebuilt.
Pulled the forks to replace seals and found all the drop out bearings bad and drive hubs destroyed. Also found one of the upper fork legs dented(stiff spot in the stroke, damn PO). Waiting for more Christini parts.
On a good note, dealing with Christini has been good so far. KTM Hutt on the other hand, VERY BAD!
Capt. Egregious is offline   Reply With Quote
Old 03-24-2013, 04:06 PM   #282
PeteN95
PeteN95's Avatar
Oddometer: 2,680
Definitely larger than 28, but I measure only 35mm?
SVN/XRR/XC-W
Old 03-24-2013, 07:51 PM   #283
PeteN95
PeteN95's Avatar
Oddometer: 2,680
That is odd, since it is supposed to be "50 state street legal"?!
SVN/XRR/XC-W
Old 03-25-2013, 04:03 AM   #284
njsurferlarry
Oddometer: 49
i think its actually legal in 49 states. and it is on the m.i.d. list for the nhsta. just new jersey motor vehicle hasnt put it on there list yet. hopefully today the only person who updates the motorcycle approval list will be in today. i got my fingers crossed but i aint gonna hold my breath.
Old 03-25-2013, 04:18 AM   #285
njsurferlarry
Oddometer: 49
got the carb out and on the bench. forgot to measure it though. the carb is very light weight. lol. it has a plastic slide. not really looking good inside. i did a very slight opening on the holes on it. not really much there to work with. the needle is snapped into place. so shimming aint gonna happen. i had a slightly softer spring and it seems to work good. took the bowl off and that has to be the worst fitting gasket down there. stuck the gasket in the freezer to get it to contract for installed. as for jetting. it had a 140 in it. went through my drawer full of jets. after lots of labor and playing around i left in the 150 dynojet jet in. it seems to be alot more responsive and runs so much smoother. that carb will have a very short life on there. working on getting that air pump valve thingy off next. when i had that hooked up it would just let the bike run a little like shit. bypassed it and so much better.
Times are GMT -7.   It's 01:06 PM.
