Old 10-24-2011, 01:28 PM   #1
thomasac92 OP
Oddometer: 20
Yamaha RD350 clean up/rebuild *Help*
I just purchased this 1973 Yamaha RD350 a few days ago for $750. It's not running, and it needs a lot of work, e.g. carbs, points, gas tank, brakes, rust, greasy mess. This is my first motorcycle so, I figured I would go all out.
I downloaded the original manual for it online but it didn't explain how to remove the carbs for cleaning. I tried for a while earlier but I don't have an allen wrench that can fit between all of the hoses and tight corners. I tried just loosening the clamps at the y-boot and on the other side but there wasn't enough play to remove it. Am I doing this wrong?
thomasac92 is offline   Reply With Quote
Old 10-24-2011, 01:33 PM   #2
gloud
Oddometer: 158
You need to loosen the clamps next to the carbs, try to rotate them first. that will loosen them up. then the fun parts it to get the 35 year old rubber on the back of the carbs to the airbox to bend a little so you can move the carbs back and then
twist them to the outside. take the sidecovers off and the tank and you will have a better go at it.
Make sure to take the oil injector lines off too. the clamp on them slides off and then you can twist the line a little to help break it free.
Oh and do yourself a favor and buy a few cans of engine cleaner and a scub brush and start cleaning it BEFORE you take the carbs off.
That thing is Nasty.
gloud is offline   Reply With Quote
Old 10-24-2011, 01:36 PM   #3
thomasac92 OP
Oddometer: 20
That's what I was doing earlier but I could only get the right carb to move. I guess I'll just mess with it some more.
Old 10-24-2011, 01:39 PM   #4
thomasac92 OP
Oddometer: 20
It probably looks a lot worse than it is since it's painted black. But its still pretty gross.
Old 10-24-2011, 01:58 PM   #5
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,349
I don't think that is black paint, probably 2 stroke oil caked all over the carbs. DON'T remove the oil lines! Take the carb top after you get the carbs clamps loose and remove them and we will go from there. FIRST I would take it to a quarter car wash, and apply a half gallon of degreaser and let it sit for a half hour and go for it with the high pressure hose.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 10-24-2011, 02:01 PM   #6
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,301
theres a rubber line between the 2 carbs that might be rotted/stiff and stopping them from rotating...
current bikes
stainlesscycle is offline   Reply With Quote
Old 10-24-2011, 02:12 PM   #7
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,349
Part of the reason I suggest a big time cleaning before trying to rip it apart.
Old 10-24-2011, 03:29 PM   #8
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,819
Get the rubber GOOD, and warm, this will help too.
Old 10-24-2011, 05:07 PM   #9
hrcs90
hrcs90's Avatar
Oddometer: 29
Yes, clean the S.O.B first. Also a can of silicon spray to help with the petrified rubber pieces. I have always had good luck with Honda's silicon, if they even sell it anymore.
hrcs90 is offline   Reply With Quote
Old 10-24-2011, 05:13 PM   #10
Bloodweiser
honestly
Bloodweiser's Avatar
Oddometer: 2,628
Sweet!
I just started an RD project myself.
Did this like a month ago:
pulled everything that was going into the carbs,
got the throttles off
loosened the clamps
and pulled it away from the boot and intake.
I didn't have to use it,
but if I met with any resistance I woulda reached for some WD.
So, why are we telling this guy not to take the oil lines off?
Thomas - how long has the bike been sitting?
Bloodweiser is offline   Reply With Quote
Old 10-24-2011, 07:07 PM   #11
stainlesscycle
Oddometer: 2,301
the little oil lines nipples are not available (or weren't least time i looked) - and i've seen broken ones...
current bikes
Old 10-24-2011, 07:48 PM   #12
JonnyCash
turd polisher
Oddometer: 1,651
I think what people are trying to say about the oil nipples is that you should pull them out of the carbs, instead of pulling the lines off of the nipples. That's how I deal with mine when I take my RD's carbs off. I would also recommend putting a small dab of threebond around the nipples when you put them back into the carbs. I had one vibrate out once. I looked down and I had oil all over the side cover and my shoe. Miraculously, the engine was okay. I still can't see how that would be. I would say the most important thing you can do towards RD understanding and happiness, is to check out 2strokeworld.com. Not to shit on folks here, but there is a good group of RD obsessed folks like me over there. Without them, I would have given up on trying to get mine running well. Have fun with your RD. Every time I ride mine, I just can'r believe what a blast it is.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 10-25-2011, 03:44 AM   #13
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,432
OP, tell us a bout yourself, specifically your skillset. We need to know at which level you will begin. Past repairs? Lawnmowers? Cars? Boats? Cylinder index? more info please...
Old 10-25-2011, 04:51 AM   #14
Mattbastard
Lazy ass
Mattbastard's Avatar
Oddometer: 2,182
Don't worry about taking the lines off. There's these things called Corbin Clamps. They work great for spring clamping down hoses.
When I bought my first RD350 project I just took it apart, cleaned everything, then modified as I put it back together.
Also, http://www.HVCcycle.com
Mattbastard is offline   Reply With Quote
Old 10-25-2011, 06:54 AM   #15
Skowinski
Primate
Skowinski's Avatar
Oddometer: 6,220
Looks pretty original, nice find. Had a friend who had a 350 and a 400 back in the day, and I alway kinda wanted one myself. If you get tired of messing with it just PM me and I will give you my address for forwarding it to...
"A person needs a little madness, or else they never dare cut the rope and be free."
~ Nikos Kazantzakis
Skowinski is offline   Reply With Quote
Times are GMT -7.   It's 10:30 AM.
