Old 10-27-2011, 08:30 AM   #31
cyclewizard
cyclewizard's Avatar
Oddometer: 4,811
Originally Posted by willys View Post
Did you forget about me or did I miss something somewhere?.....augh......which usually happens, me missing the point......augh!
My cams have a .410" lift 250degree at .040"
As said before...KLR685, 1 mm larger valves all round, ported and polishedhead and also the rest of the system to the can from air cleaner, stock base gasket to keep compression stock, same for head gasket, better needle klx needle and 145 main, UNI air cleaner, BigGun header, opened up stock can(soon to be aftermarket) FCR-MX slider 39mm carb.
Now it's possible compression time....can't adjust the cam timing at all easily. the sprockets are single dowel located, it really needs 4 degrees added to it. But that is a very complicated deal by repositioning the dowels to get half a tooths distance or slightly more seeing as each tooth results in 7 degrees of timing.
Please advise....?
Still perched on the edge......
What comp are you running?? You may even have to weld the pin hole closed and drill a new one at -4 degrees to accomplish this.
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 10-27-2011, 08:34 AM   #32
cyclewizard
Oddometer: 4,811
Slotting the pin hole only works if you are retarding the timing, if you need to advance it you will have to relocate the dowel pin hole in the gear, I would relocate the pin hole even when retarding the cam for safty's sake.
C-dub......
cyclewizard screwed with this post 10-27-2011 at 08:43 AM
Old 10-27-2011, 08:38 AM   #33
Wattner OP
Wattner's Avatar
Oddometer: 5,272
I've tried many of times myself and I gave up....I usualy just listen and not say much but Mike started a post here that people need to read so this is my .02
I hope this is ok... The hours of conversation and philosophy is always answered with knowledge and experience by you, he master.... I was/am hoping the collective masses may gather as much as I have from you.. The information is priceless!!!!
KUDOS Dad!
Wattner screwed with this post 10-27-2011 at 09:33 AM
Wattner is offline   Reply With Quote
Old 10-27-2011, 08:49 AM   #34
cyclewizard
Oddometer: 4,811
Originally Posted by Wattner View Post
I hope this is ok... The hors of conversation and philosophy is always answered with knowledge and experience by you, he master.... I was/am hoping the collective masses may gather as much as I have from you.. The information is priceless!!!!
KUDOS Dad!
Be back latter son have to go to work..
C-dub......
Old 10-27-2011, 10:34 AM   #35
willys
willys's Avatar
Oddometer: 2,904
I'm running just above 9.2, I think whatever stock is on a KLR650 2004....sorry don't know off the top of the old bean....I too am interested in the choice of decking the head or shaving the cylinder....?
Thanks for the cam timing info, already figured that part out as you have suggested. The issue is, by increasing the compression I'm moving the timing a tad aren't I? That is bringing the two systems together, crank and timing sprockets via the chain. It's moving in the wrong direction also isn't it? Which compounds my newly wanted timing ...?
This is the reason I haven't upped my compression up to now......worried about the timing issue as it isn't the easiest thing to adjust. Yes it's just a matter of boring a few new holes etc in laymans terms but it has to be extremely precise!
I'm really enjoying learning all you have to offer...it's great when a knowledgeable person shares what they know instead of hoarding that knowledge and not teaching the other up and coming mechanics so to speak.
Again thanks.
willys is offline   Reply With Quote
Old 10-27-2011, 10:39 AM   #36
willys
willys's Avatar
Oddometer: 2,904
I have another question if you can help or not I would be very gratefull for you insight.
I have a 39mm FCR-MX carb...I have it in bits at the moment and have taken it totally apart and I mean totally. I have pressed out the accelerator nozzle to clean it when cleaning the rest of it. All gaskets are still 100% intact and everything else is now perfect....BUT...in my haste to get this damned nozzle out I have damaged the slot that is meant to turn it to direct the spray. Do you know of anywhere that I can get a replacement or an aftermarket nozzle for this carb....I've been searching for hours. No my PC searching skills aren't that great as Ifound it a few days ago and now can't repeat that find.
I would be eternally grateful if you did know where....thanks again.....or to anyone else who may know.
Old 10-27-2011, 11:05 AM   #37
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,289
cycle wizard,
Where are you located in michigan ?? Do you have a shop and/or offer machine shop services such as cylinder boring and cylinder head work ??
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY is online now   Reply With Quote
Old 10-27-2011, 12:29 PM   #38
MichiganMachete
Oddometer: 85
have you tried Sudco? I used to get all kinds of parts from them back in the two stroke days. Last time I tried to get something small (fcr fuel screw stuff) from them they kinda got upset because my order wasn't big enough, and at first denied it, sending me to a dealer that purchased from them, but after a couple "nice" emails they said I could place my order if I paid a $5 fee.
So either a dealer that works with them, or direct if you must!
www.sudco.com
http://www.sudco.com/Diagrams323728/expfcrmx.gif
MichiganMachete is offline   Reply With Quote
Old 10-27-2011, 12:30 PM   #39
cyclewizard
Oddometer: 4,811
Originally Posted by imjinscout View Post
cycle wizard,
yep sure do I live by Frankenmuth Mi.
C-dub......
Old 10-27-2011, 12:33 PM   #40
cyclewizard
Oddometer: 4,811
When I first tried to get a dealer agreement with them they told me to go fly a kite that I wasn't worthy..
They have a lock on the market...them turkey's
C-dub......
Old 10-27-2011, 12:37 PM   #41
MichiganMachete
Oddometer: 85
haha nice!
PS good to see Michigan representing so solidly here! Please continue to enlighten/confuse/amaze us!
Old 10-27-2011, 12:41 PM   #42
itsatdm
itsatdm's Avatar
Oddometer: 4,825
Again thanks.
I think what you are doing may result in problems. Back in the day when Patman Racing was going to build the ultimate KLR with either the 685 or 705, gaining compression by that route resulted in retarded timing that lost HP Lots of good info on his site, but the project fizzled at that point.
I understand degreeing the cam sprockets is a solution, I hope there is another.
Old 10-27-2011, 12:45 PM   #43
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,158
.... the pump on an XR does not pump enough fluid at low RPM's sitting in traffic........
How do you know this?
I don't doubt that it's true, but am wondering how I could find out if some other type of motor has the same problem. Preferably without ruining a bunch of cams and journals.
Luke is online now   Reply With Quote
Old 10-27-2011, 12:47 PM   #44
MichiganMachete
Oddometer: 85
I've heard similar regarding the Aprilia rxv and sxv motors.
Old 10-27-2011, 12:56 PM   #45
cyclewizard
Oddometer: 4,811
Because I did just that toasted cams and head journals...lots of them, I got purdy good at repairing heads and cams..
What you do is measure the amount of oil the pump puts out with a measuring cup or a glass burette per minute or break it down in 10/20/30/40/50/60 second intervals..
C-dub......
Times are GMT -7.   It's 10:39 AM.
