Old 11-07-2011, 03:20 PM   #91
Chet Jr
Oddometer: 33
Great thread!
Would like to hear opinions on potential setups for a reliable big bore GB500 street bike.
Chet
Chet Jr is offline   Reply With Quote
Old 11-07-2011, 04:54 PM   #92
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
Wicked
Originally Posted by Chet Jr View Post
Great thread!
Chet
Add a XL600R cylinger to have the same bore and stroke the 600 has.
Building it with a 105mm-106mm 9.5-10.5 CW piston will give you a 649cc-661cc short stroke engine. It will have a great rod to stroke ratio and bore to stroke ratio. Just swap a stoke 100mm XL600R cylinder and head on it. You want the dual carbs for sure if they fit. The 105mm-106mm big bore kit will give you add quench to the combustion chamber so it can run on good pump gas. Add a cam with the head ported to make it have a sweet powerband. 60+ horsepower is easy reached. The throttle response will be bog free and pull hard from idle to 8000+ rpm.
If you can't run dual carbs use a 600 or 650 single carb head with a pumper carb.
I have been planning a somewhat similar build. I'll be using a XR650L bottom end with a XL600R 75mm crank. My plan is to useXR650L bottom end for the wide gear spread you get when you add a NX/FMX650 gear and a NX650 2nd gear to eliminate the gap between 1st to 2nd gear. The only stumbling block is I loose the electric start... Unless I can find a good GB500 engine to keep the magic button. The odds on finding one here in the states seems pretty slim.... I basicly listed the rest of my engine build plan above.
CW should be able to answer any questions you have and be able to use his years of building this engine series to use his magic to help you build exactly what you want.
xladv.com
MentalGuru is offline   Reply With Quote
Old 11-07-2011, 05:04 PM   #93
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
Any details about the roller rockers that were mentioned that you made??
Are you still making them or will you be making more? Do you grind a nice steep ramped cam to match? It would be some nice icing on the cake a big bore motor makes.
Your input is greatly appreciated.
xladv.com
Old 11-07-2011, 05:11 PM   #94
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,333
Originally Posted by cyclewizard View Post
we lucked out, I actually found the specs, I had them logged into my computer and forgot I had them...
So they are still available if you want one..
When I checked Mikes cam something was fishy with the specs they didn't seem right"weak" so I checked a hotcam I had laying here and sure as shit they were the same..I feel bad for Mike, I'll grind him a HRC cam and throw the hotcam in the scrap pile. his cam was galled and so was his rockers.
Hey CW........ be real careful when throwing that hotcam in the scrap bin........they bouce like an old indian rubber ball.......remember those
B
techforlife is offline   Reply With Quote
Old 11-09-2011, 05:27 PM   #95
tractor4play
Oddometer: 113
cam
I'm building a long rod 10.5.1 724cc motor for katbeanz right now, they work real good with just the CVcarb and and aftermarket pipe or just a plain ole slipon. that's the beauty of it.
i just bought 1983 xl600r motor from a breakers in scotland.its probably half way accross the irish sea now (hopfully) i want to spice it up a bit and slip it into my 600lm.if i shipped you a core would you be willing to do the hrc grind.i would need a suitable piston also.if this is possible can you give me a price for labour and piston before shipping.or pm me with your thoughts.sorry for the hijack.T.
tractor4play is offline   Reply With Quote
Old 11-15-2011, 07:56 AM   #96
brucifer
brucifer's Avatar
Oddometer: 2,532
Originally Posted by MetalGuru View Post
I have a feeling my XL600 has some work done to it already. With 14/45 sprockets it will power up wheelies in 1-3 with my chest on the crossbar and wheelie in 4th-5th just by staying centered and pulling up some. At 270#'s I'm not a light weight either...
I was asking how a single carb head with a pumper carbs throttle response is compared to a twin carb set-ups response.
I would like to combine my XR650L's engine with my XL600R crank and kickstart. I know I loose the majic button unless I can find a GB500 crank to use. I think the XRL's primary gearing and wide ratio trans with NX gears, the 75mm crank and a 105mm/106mm piston would be great. It would have a great rod to stroke ratio and bore to stroke ratio. Do you know if this is possible???
Is the HRC grind cam availiable for the XL's different cam and head design?
I have a 94 XR650L that would be the chassis and engine doner. It has a bad 2nd gear right now. My XL600 will donate itself just to be in a better frame/chassis.
That dual carb engine with one pumper carb is sweet, but probably overkill. It looks like it has a XR650L jug on it. They probably are opening the secondary carb sooner.
I have 2 XL headers and slip ons I use.
My friend has 6 XL600R's so I wil get spare parts from him.
I like a big thumper with a light flywheel and a hefty powerband.
So are you up to building an CW649XLR engine for me?
I've done this swap except I used the XRL crank.
If you haven't already seen it, it's here. http://www.thumpertalk.com/forum/sho...d.php?t=585568
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2002 Husky TE570-2001 Husaberg FE650E-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 12-05-2011, 02:52 AM   #97
Wattner OP
Wattner's Avatar
Oddometer: 5,452
Hey Dad, I have received a few PM's on carbs, and I would like for you to address your ideas and experiences. Not only for stock, but modified motors. We played with the Mikuni, but I know you prefer the KeiHin pumper.... Can you explain the benefits of aftermarket v. Stock CV?
Also, in addition to Dave's mods, are there any tricks for the stock CV carb if someone wants to retain it?
What about air filers/ exhaust and intake mods when going with a big C-dub motor?
It looks like several have been sending their motors in to you, and I wonder what additional mods you are suggesting to get the motors to breathe
I think I speak for a few, that we hang onto your words and await what you have to say with great anticipation!!!
Wattner is offline   Reply With Quote
Old 12-05-2011, 04:10 AM   #98
cyclewizard
cyclewizard's Avatar
Oddometer: 4,814
sorry for not getting back to you guys I forgot about this thread, I'll pm you all..
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 12-05-2011, 04:12 AM   #99
cyclewizard
Oddometer: 4,814
Yep I am but still need to make a cam to match the different base circle
C-dub......
Old 12-05-2011, 04:30 AM   #100
cyclewizard
Oddometer: 4,814
What we need to do is turn the Hemi style head into a pent roof head, the 106mm piston helps here but we still need more squish band area to give us a more complete burn.
The CV carbs works really well on the big motors due to the fact that they the 106mm piston SUCKs more air through the ports and jets.
The bigger motors need to be jetted leaner due to this effect.
It's like a needle and syringe effect I've talked about in the past, the bigger the needle/syringe the more it can pull at a faster rate with less effort.
The big motors can get hard to jet not knowing this.
I still prefer the down exhaust but I'm an old school flat tracker and I like the performance and looks from them.
Spilt the twin pipes in to two and have one cone out on each side..looks like the ones by yosh for the DR400.
You really need a larger carb like a 45mm to 48mm to reach the big motors potential but thats not a bolt on which most people want, I'm making billet intakes right now to do this so stay tuned for some pics, it will be a bolt on piece.
They will allow for more radical intake porting due to the fact that there will be extra material there to remove and will be able to match the new streighter ports on the head.
CW
C-dub......
Old 12-05-2011, 04:34 AM   #101
cyclewizard
Oddometer: 4,814
I'll pm you some prices
C-dub......
Old 12-05-2011, 04:36 AM   #102
cyclewizard
Oddometer: 4,814
I agree with ya what a great combo that would be.
C-dub......
Old 12-05-2011, 04:38 AM   #103
cyclewizard
Oddometer: 4,814
Great thread!
Chet
I really like the ballistic battery you sent me, way better than the others we have tried.
C-dub......
Old 12-05-2011, 04:41 AM   #104
cyclewizard
Oddometer: 4,814
B
I do remember that...
C-dub......
Old 12-05-2011, 05:06 AM   #105
Wattner OP
Wattner's Avatar
Oddometer: 5,452
CW
Were gonna meet up right after you do this to the "Fun" bike, right???
I know, I know.... Just PM me the cost, I'll add it to the stack o' cash heading' your way..... Use the new 41 on the "Burn", Sparkster or Garry bike builds....
I HAVE to give up reading... it is EXPENSIVE!!!!!
Wattner screwed with this post 12-05-2011 at 05:12 AM
Times are GMT -7.   It's 09:43 AM.
