Old 09-09-2013, 04:54 AM   #46
McJamie
STROMINATOR
McJamie's Avatar
Oddometer: 1,389
Originally Posted by johnnyc14 View Post
I finally got a new fuel tap installed and the lines connecte. I filled the trans with 1.2 l of Belray gearsaver. I put 5 l of 20-1 premix in the tank so there's lot of oil until the oil pump is bled. Two kicks and away she went. Checked the timing and it was spot on but I think I'm going to need to richen the idle mixture screws as the idle sounds little flat/lean. Good to have it running though.
http://www.youtube.com/watch?v=wR1tA...ature=youtu.be
It is one of the best feelings to have something run, that you have been slaving over for a long time. It looks and sounds great.
We just wrapped up our annual "Triples in Tweed" meet at Ian's ( H2 Dude )place, this past weekend. It was great to see so many triples gathered in one place. Even better when we rolled through a small town, and the locals would step out side to see what the racket was all about.
It would be really cool if you could make it one year. I know it's a long, long, way for you for you to go , but I think you'd really enjoy it. Great bunch of guys.
Pictures on the Canadian Triples site soon.
If you get far enough away, you'll be on your way home.
Piss off, I'm in my Happy place.
McJamie is offline   Reply With Quote
Old 10-18-2013, 06:31 PM   #47
skrapper
Oddometer: 1
Fork tubes
Hi, I'm working on a '67' a7, frame #A7-000795, how do the tubes come out of the upper stanchion? Also I need a key # 530 any idea where to find one?
skrapper is offline   Reply With Quote
Old 10-19-2013, 12:15 AM   #48
johnnyc14 OP
Oddometer: 205
Try this guy on ebay for the key.
http://www.ebay.com/itm/Kawasaki-Key...d46a1a&vxp=mtr
The fork tubes should just slide out of the upper triple clamp after the lower triple clamp bolts are loose and the fork cap bolts are removed. They could be seized into the fork ears by rust. Penatrating oil is your best bet to get them free.
John
1971 Honda CL450
http://advrider.com/forums/showthrea...ight=johnnyc14
1972 Kawasaki F9 Bighorn
1973 Kawasaki H1D Mach III
http://advrider.com/forums/showthread.php?t=634816
1974 Yamaha DT250
http://advrider.com/forums/showthrea...ighlight=dt250
2003 Suzuki DRZ400S
2008 Kawasaki ZG1400
johnnyc14 is offline   Reply With Quote
Old 06-12-2014, 06:46 AM   #49
Zammy
Zammy's Avatar
Oddometer: 201
More please ?
Zammy is offline   Reply With Quote
Times are GMT -7.   It's 06:43 AM.
