Old 11-02-2011, 03:47 AM   #16
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
The fastest, easiest, lasting repair
is right here. I've used these for years, recently on a Honda tractor differential. Reusable and leak free. I have machine shop skills, love Heli-Coils and STILL choose these when I can. A brilliant design. First oversize solves most all problems. Can be shortened. http://www.dormanproducts.com/p-25749-090-174.aspx available at fine auto parts stores everywhere. Ask for Dorman P/N 090-174.
Old 11-02-2011, 05:21 AM   #17
hardwaregrrl OP
ignore list
hardwaregrrl's Avatar
Oddometer: 7,572
Yeah, they seem like an easy solution. I also stumbled across this: http://www.cgenterprises.com/drain_p...ize_repair.htm
I think I'd go with the piggy back.
Old 11-02-2011, 05:34 PM   #18
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,075
The piggy back style is what I was describing, whether homebuilt or bought as the kit.
I had forgotten about the straight oversize like concours posted in the link.
Either choice has merits. Most important issue will be not to exceed the "bury depth" of the original plug. If either style repair exceeds that depth, it should be simple enough to grind or mill off the offending mm without sacrificing the self-tapping characteristics.
I would be stuck in indecision for days trying to choose which way to go.
Oh yeah, the comments about punching something new in there square to the original threads to get sealing at the crush washer is true. The workaround on good quick and cheap fixes would be to set the threads in epoxy like JB Weld. And that would seem to limit the choice to the piggy back option for absolute certainty of a good seal.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 11-02-2011, 05:56 PM   #19
hardwaregrrl OP
ignore list
Oddometer: 7,572
Plug in a plug didn't work out so well for me. The tap broke in the plug. So I just red loctitied it back in and now there is a definate weep from the tap. Shit. I wish i could just find a piggy back plug with the proper thread pitch and length. Oh well.
Old 11-02-2011, 06:30 PM   #20
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,809
Big please don't do the JB Weld "fix" you want to do it once and do it right don't ya??? JB will be temporary at best!! I'd go next size bigger, or thread insert. Most likely the thread insert as this would allow the stock drain plug to be used.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 11-02-2011, 06:35 PM   #21
trophymoto
MACDADDY!
trophymoto's Avatar
Oddometer: 446
I'll say it again...
tap it to the F/D drain plug size, then grind down a F/D plug shorter .
I bet I've done it 30 times in my shop days (other peoples F up's)
NEVER had one leak!
trophymoto is offline   Reply With Quote
Old 11-02-2011, 07:06 PM   #22
hardwaregrrl OP
ignore list
Oddometer: 7,572
NEVER had one leak!
My understanding is that I would need to take the FD apart in order to tap the threads. I do not have the knowledge to do that otherwise I would.
Old 11-02-2011, 07:14 PM   #23
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
$3 and 3 minutes. Dry, removable, reusable, looks orig, etc....
Old 11-02-2011, 07:54 PM   #24
One Less Harley
Oddometer: 4,809
You said the drive shaft drain plug, all you need to do is separate the drive shaft housing from the final drive. Easy to do. Once separated the drain plug is visible and no further dissassembly is needed. Look again at wireworker's post/picture.
Only thing is that you may have to remove some material from the 10 mm boxed end of a wrench to remove the four bolts attaching the FD tot he drive shaft housing.
For the FD (looky here) all you need to do is pop the inner cover off, that is only removing the perimeter bolts around the inner housing then using long 5x30mm bolt in two holes in the housing and tightening them to pop the housing loose.No further dissassembly to get rid of shavings.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 11-02-2011 at 08:15 PM
Old 01-20-2013, 10:09 PM   #25
brocktoon
brocktoon's Avatar
Oddometer: 257
Hardwaregrrl, wondering what you ended up going with and how it's worked? Looks like I'm also going to be dealing with this issue... While getting my /5 gussied up for its first outing, I noticed the FD drain plug not tightening up and, sure enough, the threads are stripped.
brocktoon is offline   Reply With Quote
Old 01-21-2013, 05:00 AM   #26
hardwaregrrl OP
ignore list
Oddometer: 7,572
I took it off and ran it out to Boxwerworks, and they walked me through the drill and tap, and then insert. Pretty boring....now wishing I had sent it to Wirewrk to have a little of his DNA in my bike.
Sorry it wasn't a more exciting fix.
Old 07-23-2013, 06:54 PM   #27
benthic
glutton 4 punishment
benthic's Avatar
Oddometer: 397
i'm kind of resurrecting an old one, but I found this thread to be pretty helpful as I had to fix a stripped shaft drain too.
I got one (actually 2 since i didn't understand how they worked) of the Dorman self-tapping oversize drain plugs. it mostly went alright, but i bent a part of the final drive (crap!). i did exactly what I was afraid of doing. the length of the oversize plug hit the FD and pushed it in. you can see it in the pictures. luckily it is not a problem any time soon. on the plus side I think it is sealing pretty good though.
in the pics, the large plug is a 14x1.5 which i bought first because i didn't understand that the oversize was built in. I thought I had to buy a larger size plug. the little one is an oversize 12x1.75 (which is not the correct plug of 12x1.5, but i figured it would work) that I used to tap the hole (i had to keep shortening the plug) and then cut down to the correct length.
thanks for the help all!
Spencer
1978 BMW R80/7
"all we need is time and courage." - Renner
"A lightened flywheel on your bike is like me getting into Spandex and putting on track shoes to walk the dog." - M
www.blindfishz.com
benthic is offline   Reply With Quote
Times are GMT -7.   It's 04:42 AM.
