Old 11-05-2011, 04:10 PM   #1
scorch OP
Poser
scorch's Avatar
Oddometer: 3,442
finally hard cases and topcase on my ninja 250 *pics*
first step was to drill 2 holes into the rear passenger peg.. I dont use them anyway
flattening out with a hammer the iron pannier cage.
one arm on the side. Right now only being secured by two bolts. Just to see how it works.
the two bolts now tightened. This was probably the hardest part. And getting both sides to match
both arms on there
the arms come with attachments for the givi top case, but the thing wont match the 250. So the first thing to do is cut them out
here they are off the cage. Now we need to cut them again, and make them shorter so they can fit the top case.
here they are welded a little shorter
bike without the rear fairings
The top case is a little high up .. but i am going to test it out and see. If it bopthers me, then ill mount it a little lower
good thing is that both blinkers do not have to be relocated
additional support in the frame of the rear of the 250.
welding onto the frame
so there are two steel poles on each arm welded to the rear subframe supporting all the weight, and the weight is also supported in the rear footpegs
im pleased with it, my father does great welding
scorch is offline   Reply With Quote
Old 11-05-2011, 04:37 PM   #2
Cat0020
El cheapo
Cat0020's Avatar
Oddometer: 5,552
Looks nice, .. must have no place to put your stuff most of the time.
All that effort and weight (+15-20 lb. or more) added to your lightweight Ninja to carry another 30-40 lb. of stuff.. additional stress to the subframe.. more potential to bend the subframe when a dump occurs... I wonder if the handling is affected.
Mankind is doomed & Physics do not lie
Chances favor the prepared mind.
Cat0020 is offline   Reply With Quote
Old 11-06-2011, 03:03 PM   #3
scorch OP
Poser
scorch's Avatar
Oddometer: 3,442
the welds broke on the ride today. The brackets holding the rack were not strong enough. But the boxes were still good. Now its rewelded extra strong and it should.. hopefully last :)
tommorow first day commuting with the bags.
Old 11-06-2011, 03:58 PM   #4
studad
studad's Avatar
Oddometer: 934
Looks great. One day I'll have a ninja 250. One day. I almost bought one Friday. I love the black/white ones and the 2010 green SE.
studad is offline   Reply With Quote
Old 11-06-2011, 05:18 PM   #5
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,270
Good god that's hideous
Oh well...when you gotta carry a ton of crap around, ya gotta...
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 11-07-2011, 03:56 AM   #6
scorch OP
Poser
scorch's Avatar
Oddometer: 3,442
i was expecting some praise lol. I think it looks pretty good. But function over form for sure :)
Old 11-07-2011, 03:59 AM   #7
scorch OP
Poser
scorch's Avatar
Oddometer: 3,442
Thanks studad. You should definatly get a 250. A great bike to commute on, and even tour. everyone told me it was going to be too slow etc.. and id get bored with it within 6 months, but 3 years later i still love riding it, and cant see myself riding anything else. good enough power for everyday riding, great mpg 70 avg, 300 miles to the tank, easy maintenance, very reliable.. and the tires last forever :)
Old 11-07-2011, 12:20 PM   #8
Joe?
Joe?'s Avatar
Oddometer: 689
I think it looks awesome. Its those hippo hands that are hideous Seriously, awesome setup
Joe? is offline   Reply With Quote
Old 11-07-2011, 12:48 PM   #9
scooterspirit
Ilovekitty
scooterspirit's Avatar
Oddometer: 729
Scorch rules! Well you always said you'd do it someday, so what you waited like 50k miles before you got on that. Now you really can carry too much stuff! Nice job.
scooterspirit is offline   Reply With Quote
Old 11-07-2011, 01:02 PM   #10
studad
studad's Avatar
Oddometer: 934
A guy has to have luggage to ride every day. Maybe one could get by riding every day as simply hobby riding, but to really get out there and be a motorcyclist day to day, you have to have a place to put all the things that you get, deliver, and use throughout the day/week/year.
Old 11-07-2011, 01:31 PM   #11
Mr.Goose
Velvet Steamroller
Mr.Goose's Avatar
Oddometer: 1,230
load up those cases and go pull some wheelies!
Mr.Goose is offline   Reply With Quote
Old 11-07-2011, 04:38 PM   #12
Steelybeast
Steelybeast's Avatar
Oddometer: 551
Good, creative job you did there Scorch
Always like to see where someone can modify or build something, to make it work out for their needs.
2007 Suzuki Bandit 1250S
2004 Honda ST1300
2000 Honda Nighthawk 750 (past)
2008 Kawasaki Versys (past)
Two-Up, Two-Wheels, Two-gether:Switzerland
Steelybeast is offline   Reply With Quote
Old 11-07-2011, 09:34 PM   #13
Kestrel
Gear Driven Cams!!
Kestrel's Avatar
Oddometer: 181
That mount would be significantly stronger if you had it connected to the rear subframe / rear seat area, rather than suspended above the rear seat like it is now. It will no doubt break again in short order. You've created a huge lever with insufficient support. Find a way to support integrate a support under that top box and you're going to get a significantly stronger setup. Right now, as it is... you're just asking for it to break into pieces again.. I realize you actually welded a portion to the rear subframe, but those pieces still seem rather prone to flex, given that they are welded in somewhat perpendicular to the subframe. Not that strong of a design, I'm afraid.
Kestrel is offline   Reply With Quote
Old 11-08-2011, 06:09 AM   #14
scorch OP
Poser
scorch's Avatar
Oddometer: 3,442
yup, i need to re work that subframe part because one of them broke again.
Ill figure it out im sure. But too much far back on th ebike and too much weight with vibration. But when it idoes not snap, it works great :)
I have 55k miles on the ninja now. Ill wait to 100k to get a aftermarket exhaust
Old 11-08-2011, 06:24 AM   #15
Yostwerks
Oddometer: 189
You did a great job on the racks and I think the bike looks good as a result.
The Givi E21's have long been my favorites due to their top loading utility.
I made pannier racks for my Aprilia using aluminum tubing ... no welding, and they attach at the rear pegs and grab handle.
They've been trouble free for two years ... Regards, Tom
Snowshoes are optional ...
Handlebar muffs only look hideous to those who have never learned to use them .... I never leave home without them
Don't let anyone tell you what you can or can't do
Yostwerks screwed with this post 11-08-2011 at 06:52 AM
Yostwerks is offline   Reply With Quote
Times are GMT -7.   It's 03:26 AM.
